04-03-2008, 02:41 PM | #5 |
300
Rep 1,771
Drives: AW E92 M3/AW F87 M2
Garage List 2016 BMW F87 M2 Coupe [10.00]
2014 BMW F20 M135i [9.00] 2011 BMW F10 5 series [9.00] 2008 BMW E92 M3 Coupe [10.00] |
AWD. I remeber doing all the power slides in my old STi effortlessly, it had tons of traction.
E92/// M3 Coupe 6MT Alpine White/Fox Red ----- My US car
F87/// M2 Coupe DCT Alpine White/Black ----- My ride in Asia |
04-03-2008, 03:19 PM | #7 | |
Moderator
94
Rep 1,920
Do you want to keep the tail out, eg: drift and look "cool" or do you want to correct the slide asap and continue on your way?
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket 2014 F30 328i -- Kids car 2008 E90 M3 -- Sold 2004 GT3 -- Sold 1997 M3/4 -- Sold 1995 M3 -- Sold |
04-03-2008, 03:22 PM | #9 |
24
Rep 404
I'd say RWD is the easiest to throttle steer with. AWD makes true tail slides difficult, and I've NEVER had a FWD go loose at the back, understeer is the FWD problem!
04-03-2008, 03:55 PM | #10 |
75
Rep 1,288
LOL, that's not a simple question to THIS forum. You are just starting another debate.
AWD is the easiest to drive fast, I have no doubt in my mind. A noob can take an EVO and turn fast lap times right away. Problem is, the guys who always drive AWD on the track learn very little about car control... therefore when the tail actually does begin to come around, they have no idea what to do.... = big trouble. I guess that didn't really answer your question, because it depends on who's driving the car. AWD is like Superman IMO. But with great power comes great responsibility. Or was that Spiderman?
2009 135i 6MT Euro Delivery 9/5/09
BMW Performance Power Kit - Exhaust - Short Shifter - Suspension |
04-03-2008, 03:59 PM | #11 | |
Racying Dynamics
118
Rep 4,391
04-03-2008, 03:59 PM | #12 | |
126
Rep 4,144
kbk_75's response is probably the best response here, with the caveat that it is a generalization and there will be exceptions.
2017 F80 YMB.
04-03-2008, 04:29 PM | #14 | |
24
Rep 453
When you say it snaps out I assume you mean this was unexpected, you are starting to spin and you would like to catch it and correct it. In that instance you back off the throttle and steer into the skid. So if you back off the throttle I would think that there would be only a small difference between the three drive types as no power is being applied. Having said that, a rear wheel drive car with a manual tranny (therefore having a direct mechanical connection to the rear wheels) will put a little pit of engine breaking to the rear helping to slow it down and pull it back in. I would think that an FWD would do the opposite and and AWD car would be neutral. If an auto tranny were involved, and it unlocked its torque converter, I would think that there would be no engine breaking and it would make no difference. Also if you put the clutch in on the manual there would be no difference. |
04-03-2008, 05:10 PM | #15 |
75
Rep 1,288
If someone's truly interested, I highly recommend the book "Going Faster" by Carl Lopez/Skip Barber. Much better place to read about car control than on "the internets"
04-03-2008, 05:14 PM | #16 | |||
1121
Rep 8,017
The best for this situation is actually fwd, unlike a rwd car which only has controlling power of the over the wheels which are already swinging in the wind, the fwd chassis has an ace up it's sleeve, yeah that's right it's understeer, with it you apply full throttle to pull the nose wide (understeer) which has the desired effect of pulling the rear back into line and thus disaster controlled. Awd to a lesser extent will do the same thing, only it will take a little long and this will depend on how much power can go to the front wheels, the more the better. Rwd is the one which is hardest to control in this situation and unless you are bloody quick with the wheel it's rear-end bye, bye the soonest too. Not the outcome some might have expected but the consolation is you are having the most fun up to that point. GT3 Tim, would you concur. |
04-03-2008, 05:24 PM | #17 |
75
Rep 1,288
Footie, did you pose this question just to express your "knowledge" on car control and "what's best"? Because you missed some key points in your summary. Mainly that the way you correct a slide depends on what caused the slide in the first place. Was it power-on oversteer? Did you lift? Big difference in what you need to do next.
Not that I know everything.... just pointing this out.
04-03-2008, 05:39 PM | #18 | |
1121
Rep 8,017
My point was that when either done on purpose or by accident, if the rear goes beyond the point of little or no return (say 35degree) adding more power to the rear only adds to the problem and on a lot of occasions killing power will also add to the problem. No, with rwd you really have to on your game and on your toes which is why some many people regard it as a challenge to drive well and drive quickly. |
04-03-2008, 05:43 PM | #19 |
75
Rep 1,288
Agreed... esp RWD with a lot of power!
04-03-2008, 05:47 PM | #20 | |
817
Rep 7,887
Thats me in about 1975 in Quebec ice racing in a Fiat 128.There is no windsheild because I rolled in the morning. Last edited by Gearhead999s; 04-03-2008 at 06:03 PM.. |
04-03-2008, 06:12 PM | #21 |
13
Rep 40
So looks like on Public ROads
1) with avergae driver skill, RWD is diffucult to drive fast around corners over AWD, is this true? 2) If the above is true a Good Awd car like Audi RS4 are better over M3, I dont think so because many reviews like M3 over Rs4 I think from all reviews the M3 had huge grip around corners for pure fun cornering wise which is more ideal AWD or RWD? I heard that if AWD spins it is very difcult to get it back and with traction ON is it possible to spin the M3? |
04-03-2008, 10:03 PM | #22 | |
99
Rep 2,000
In fact, "Gas it!" is pretty much what you do when you get into nearly any kind of trouble with a fwd car. Same advice for a tail-out awd car. On the other hand, they'll understeer when you're whacking the gas in a corner, so get out of it if you're about to drive off the track. Porsche? Whatever you do, don't let off! Bruce |
