09-29-2016, 01:12 PM | #1 |
23
Rep 141
Anyone have rubbing issues with 305 R888's?
Recently put some 265/35/19 and 305/30/19 R888's on the F80.
I have found it rubs some in the rear and up front. The setup is: KW HAS, vorsteiner vff101 , 5mm spacer up front to clear HAS collar. Front 19x9.5 offset 22 Rear 19x10.5 offset 34 The fronts I should be able to resolve by switching suspension and getting rid of the spacer, however the rear I am unsure about. Id love to hear more from those running 305 R888's in the rear on ride height, suspension, offset, etc. Last edited by zbrit00x; 09-29-2016 at 01:32 PM.. |
09-29-2016, 02:57 PM | #2 | |
3138
Rep 2,953
Most people just run a 295/30/19 R888 to avoid the headache |
10-01-2016, 07:49 PM | #3 |
533
Rep 1,415
Are those modifications only necessary for his particular setup are for anyone wanting to run a 305 in the rear?
10-01-2016, 08:30 PM | #4 |
45
Rep 110
I run my MT 305's with no issues at all.
2016 F85 race chip, er dps, resonators deleted, KW's
2016 F82 JB4, mid pipe,kn filters, bms cp's, alcohol 2016 5.0 Jpc built, horsepower enough to beat you |
10-02-2016, 03:26 AM | #5 | |
3138
Rep 2,953
We did a lot of work to get the 305 MPSS to fit which are square but not as wide/thick as the R888. - 3 degrees of camber - modifications to fender lining - switched to coils, raised the rear still rubbed lightly |
10-02-2016, 08:48 AM | #6 | |
704
Rep 1,917
Matt
10-02-2016, 06:25 PM | #7 |
78
Rep 818
OP -
Since you have the HAS kit, can't you just raise the rear a bit or are you maxed out? As others have said, running more negative camber should help but I think it'll be tough with 19s. I'm running 305/35/18 R888s and no rubbing (yet) on Macht Schnell springs.
2016 F82 ZCP / 6MT / SSR Intake / Volk ZE40 18x9.5 et20 & 18x11 et34
Nitto NT01 265/40 & 305/35 / Macht Schnell Sport Competition Springs |
10-02-2016, 09:57 PM | #8 |
721
Rep 2,342
Camber for rear should be fine for you. Your setup isn't what I'd call aggressive. I'd prefer to run an 11 for a 305 R888 since the extra half inch would stretch that tire more but if you can't camber should be enough.
265/35 on a 9.5 et22 shouldn't rub within the stock front camber range. I run a 265/35 on a 9.5 et22 with no issues even with 10 or 15mm spacers. |
10-02-2016, 11:16 PM | #9 | ||
1428
Rep 1,984
GoodtoGo68.50 |
10-03-2016, 06:47 PM | #10 |
23
Rep 141
Will be switching to kw v3's since the HAS is limited on the front for this setup.
The rears dont rub too bad, I raised it up some more, however I do believe a bit more camber should resolve the rub. As for the front, I am not sure if a wider spacer would be a good idea. Seems like it would cause the tire to poke out more. These 265/35 r888's are meaty. |
10-03-2016, 11:09 PM | #11 |
B.E.
444
Rep 761
I just put on my FI-Rs with the same tires and a 12mm spacer up front (I have -2.5 camber) and the rears rub under compression or even backing out of my driveway at an angle. I'm on KW Clubsports and I'm fairly low. I'm going to try and see what I can do tomorrow and I'll get back to you
Current: 2022 TRX & 2010 GT3RS
Past: 2016 M3 Individual Grigio Telesto Pearl, Sakhir Orange/Black Full Leather w/ CF trim, 6MT, ZCP, CCB, etc... Previous: 2011 E92 M3 Melbourne Red on Black 6MT ZCP. --> now 2010 dedicated track car |
10-04-2016, 07:43 AM | #12 | |
704
Rep 1,917
If you're using a spacer up front the only way to counter it is more camber.
Matt
10-04-2016, 07:28 PM | #13 |
B.E.
444
Rep 761
Ok so I am no longer rubbing. Added more negative camber in the rear and a bit of toe in. Front camber is -2.9, rear is -2.3
10-04-2016, 10:15 PM | #14 |
3138
Rep 2,953
10-04-2016, 10:50 PM | #15 | |||
69
Rep 267
10-05-2016, 08:27 AM | #17 |
1106
Rep 1,085
Toyo Proxes R888 – R Compound is very wide compared to MPSS. We recommend 19x11 ET44 rear for proper fitment.
On the front, we would recommend 275/30/19. 275/30/19 front / 305/30/19 rear. The logic is OEM F8x tire size rear is 2.5-2.7% taller in the rear. If you run 265/35/19 front, the rolling diameter in the front and rear will be the same. This creates a lot of ECU intervention as it thinks the rear wheels are slipping, so power is reduced to attempt the slipping sensation. A forum member ordered our track setup to mount the R-Compound tire sizes above, we'll post photos soon. Respectfully, Jimmy, Signature Wheel - BMW Specialist
Jimmy | BMW Addict | Signature Performance Wheels | OBSESSED WITH PERFECTION | IG: Signature_BMW | Email: jimmy@signaturewheel.com
sly1types431.50 |
10-05-2016, 11:47 AM | #18 | |
23
Rep 141
Also, have you tested putting it in mdm mode and seeing if it still pulled power. Typically thats the mode I drive in when needs be. |
10-05-2016, 01:45 PM | #19 | |
1106
Rep 1,085
Try to get Euro MDM coded if you haven't done so, it does help and less intervention with tire diameter delta. Even with Euro MDM, the traction control light isn't flashing but members have reported interventions. You can detect the intervention using OBDII BT enabled app that monitors throttle/brake application.
10-05-2016, 09:43 PM | #20 |
3138
Rep 2,953
Here's Shmelgy's car with the 305/30/19 R888 Rear.
We did 265/35/19 | 305/30/19 because the rolling diameter is exactly the same at 26.3.... . |
WarMachineM355.00 |
10-06-2016, 04:19 PM | #21 |
B.E.
444
Rep 761
So I was rubbing in some places at first. Added more negative camber in the rear and a bit of toe in. Front camber is -2.9, rear is -2.3, rub free
shay2nak1070.00 |
10-06-2016, 08:26 PM | #22 |
23
Rep 141
