03-26-2008, 09:07 PM | #1 |
Mmmmmkay
70
Rep 433
2 noises from my new M3
Just took delivery of my baby monday... the car is F'ing sweet!!! Now onto my OCD about noises from my cars
Not sure if these are normal, but they have attracted my attention. 1 - I have a slight clunking sound coming from behind the driver seat... pretty much center of the car. It is directly related to the gear box and shifting. It is most noticeable when going into second. If the car is in second and I engage the clutch I can sometimes hear it as well. 2 - When i am pulling into my garage I have to make a low speed 90 degree turn from almost a complete stop. When I do this I get a 'squeel' from the front end of the car... It only happens when the wheel is turned past a certain point. anyone else experience either of these? thanks. |
03-26-2008, 09:53 PM | #2 |
Rep 49
Yes, it seems that BMW carried over the infamous clunk from the E46 M3 to the E92--it is normal and has to do with the transmission. (Search the internet for the E46 clunk). Although, the clunk is not as loud on my E92 M3 as on my E46 M3.
As for the squeal with the wheel turned--my car does not make the sound, but it seems like it is a belt or power-steering issue. On some other cars, I have heard the same sound when the wheel is turned to lock. Hope this helps. |
03-26-2008, 10:27 PM | #3 |
M3lover
27
Rep 485
I also hear the clunk on mine. I can hear it going into first, but specially into second gear too. I am glad I am not the only one. does it ever get better with time?
03-26-2008, 10:38 PM | #5 |
75
Rep 1,288
Like Lando said, the clunk is a "feature" of a BMW M-car with manual transmission. My Z4 M Coupe also did this.
Here's how I look at it: When I get a brand new car, I listen closely to all the sounds it makes and deem them "normal" noises. That way, when something really IS wrong, I know to take it in. Congrats... Just relax and enjoy your new car. It's not broken, it's not a Camry, it's an M-car, and it has character.
2009 135i 6MT Euro Delivery 9/5/09
BMW Performance Power Kit - Exhaust - Short Shifter - Suspension |
03-26-2008, 10:46 PM | #6 |
38
Rep 577
this is really good to know... at least I won't wig out when I hear those noises thinking that there's something wrong.... ahhh.. those bmw aficionados come to the rescue again
03-26-2008, 11:06 PM | #7 | |
Mmmmmkay
70
Rep 433
My buddy just got an M roadster, I'll have to go drive it and see if his makes a clunking noise. thanks for the info. G |
03-27-2008, 12:08 AM | #8 |
127
Rep 3,071
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
Geoff, I don't want to insult anyone, but it's possible the squeal you hear is from the tires on the asphalt. If it's concrete then disregard, however some asphalt sealers make the tires squeak bad.
One example is the parking lot of my local REI. The sealed the parking lot like a year ago and every car making a turn in the parking lot squeals going around corners.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
03-27-2008, 12:21 AM | #9 |
374
Rep 8,033
I have the clunk in my E46 325 as well. I was surprised by this too when I bought the car new, and took it back to dealer. The tech rode along to hear to noise, and when he heard it, he smiled and said all BMW manual transmissions sound like that when changing from 1st to 2nd.
03-27-2008, 03:53 AM | #11 |
Rep 149
correct me if i'm wrong, but i've been told that this sound is caused by the twin-plate clutch trying to mesh a low speed. i get this sound only at lower speeds (less than 30km/h) but none at the higher speeds.
i also have another sound. the roof seems to emit a short "creak" at the A and C pillars when the car is flexing, eg going over a hump at an angle. but this only appears to happen when the car has been under the sun for a while, so i suppose it's due to expansion. but is it ok and safe? cheers |
03-27-2008, 04:27 AM | #12 |
61
Rep 908
Drives: em-funf
Garage List 2000 E39 M5 - current [0.00]
2007 E92 335i - SOLD [0.00] 1996 E36 M3-SOLD [0.00] 2000 E39 M5-SOLD [0.00] 2001 E46 M3-SOLD [0.00] 1995 E36 M3-SOLD [0.00] |
E36 M3 had the same clunk. I had it on both M3s.
It's part of the personality haha |
03-27-2008, 07:43 AM | #13 | |
Mmmmmkay
70
Rep 433
Nope, I have a poured concrete driveway... it's definitely coming from the steering system. |
03-27-2008, 07:45 AM | #14 | |
Mmmmmkay
70
Rep 433
03-27-2008, 09:08 AM | #16 |
24
Rep 404
My M3 makes a funny sound when I make a full "U" turn on full steering lock. It's hard to describe the sound. It's almost like a low pitch "Whoo whoo whoo whoo" sort of sound until I unwind some steering lock.
At first I though maybe my tyre was touching the wheel-well or something so I took the car to the dealership and had them put it up on a lift and took a good look underneath, but there was absolutely no sign of any contact between the tyre and any part of the car's body work. The dealership could not explain the sound and since mine's the only M3 around here they have no point of reference either. I wonder if this is the same sound you're referring to? |
03-27-2008, 09:11 AM | #17 |
Rep 4
If you're on full lock, it just may be that the steering system is at full lock--my Grand Marquis(albeit not as sporty or engineered as an M3 or any BMW) makes strange noises at full lock. I believe it's something to do with the power steering pump not being able to turn the wheels farther. Anybody who knows better may correct me if I'm wrong
03-27-2008, 09:17 AM | #18 | ||
17
Rep 172
2015 F82 M4, Alpine White / Black - SOLD
2012 E92 M3 ZCP, Alpine White / Black, M-DCT - RIP 2008 E92 M3 Silverstone / Black, 6 speed, ZCP wheels, Dinan exhaust, software, airbox & Stage 1 suspension - SOLD 2002 E46 M3 Carbon Black / Imola Red, 6 speed, 19s - SOLD |
03-27-2008, 10:50 AM | #19 |
44
Rep 545
You know I havent noticed the clunking sound.....I will check for it later when I drive my car. Might have gotten so use to it from my past e46 ande e36 that I didnt bother to pay attention to it on this one..
08' e92 M3 6MT // Rogue SSK // B&B Tri Flow Exhaust // AA air filter // Mod Carbon Skirt extensions // Amuse Front/Rear Bumper // Amuse Trunk // Gloss Black Grills w/ M colors // gloss black side vents // M5 Stick with IND custom stitched boot // Carbon Firber wrap steering wheel trim // Avant Garde M364 20' (street) // Advan RS 18's (track) |
03-27-2008, 11:23 AM | #20 |
Rep 50
I don't know about in the States, but when I picked mine up a couple weeks back, it had a little pamphlet stating, that it will indeed make drivetrain noise and it is normal and doesn't have anyy adverse affects on performance, driveability etc. It also says the brakes because they are of the high performance type, will make noise as well. This info is on the little pamphlet called 2008 M3 quick guide or something along those lines.
03-27-2008, 11:57 AM | #21 | |
236
Rep 3,303
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
03-27-2008, 09:56 PM | #22 |
Commander-In-Chief
2122
Rep 8,924
Drives: 2023 M2 Coupe, 2020 GLE 450
Noises
As others have said, the clunk is normal and much less on mine than with my E46. It emminates from the diff, and can be controlled with careful engagement at low speeds. No groan in my steering; I'd have it checked out.
Greg Lake Oswego, Oregon, USA 2023 M2 Coupe - Brooklyn Grey/Cognac/CF, 6MT; 2020 MB GLE 450 |
