08-08-2016, 11:20 AM | #1 |
427
Rep 957
18" Apex Arc-8 w/ MPSS tires
$550 picked up or $650 shipped. Can't beat this deal. Don't want these sitting all winter so scoop them up! Up for sale are a set of Apex Arc-8 wheels with Michellin Pilot super sports mounted (No TPMS). Wheels: APEX ARC-8 Wheel - HYPER BLACK Diameter: 18" Width: 8.5" Offset: 45mm Lug Pattern: 5x120mm Centerbore: 72.56mm Weight: ~18.20lbs The wheels clean up well and look great. They do have cosmetic blemishes including curb rash in places. One wheel has been repainted, but has since seen a curb :/. Another wheel has a bit of lateral run-out which causes a slight vibration at 80mph when mounted on the front axle only (still in beter balance than my brand new wheels..). Might be able to be balanced out perfectly as it once was prior to the MPSS install. Tires: PILOT SUPER SPORT Size: 235/40ZR18 Sidewall Style: Blackwall Load Range: XL Serv. Desc: (95Y) UTQG: 300 AA A The tires are getting low on tread. There is camber wear that puts the outside and inside tread at around 1.5/32" on two wheels and 2/32" on the other two wheels. The middle tread is around 5/32" and 4/32", respectively. Plenty of life left for the street. Pictures: https://drive.google.com/open?id=0B9...DF0OEVGVGJxTVU Last edited by bNks334; 10-21-2016 at 10:14 AM.. Reason: Price |
08-08-2016, 11:46 AM | #2 |
Bergspyder
1469
Rep 1,212
Price shipped 23229
08-09-2016, 05:13 PM | #3 |
Never Lift
11
Rep 62
Drives: '12 135i, '99 328iS, '70 2000
Dammit, if only they weren't squared!!!
'12 135i - Jet Black/Black, Tracked and Crashed '99 328iS ///iMposter '70 2000NK - Anthracite/Black |
08-09-2016, 11:02 PM | #4 |
Bergspyder
1469
Rep 1,212
Think they are too small for 135i?
Why would square be bad? (Besides the obvious smaller rear tires?)
08-10-2016, 09:37 AM | #5 |
Never Lift
11
Rep 62
235 is the stock rear size but 235s don't fit in front if I recall correctly. 225/255 is the most tire 1ers can fit I think. I'm on Koni yellows and H&R super sport springs and 225 fronts rubbed at about 3/4 of lock. After rolling my fenders, they only rub when they're compressed a bit.
08-10-2016, 09:08 PM | #6 | |
427
Rep 957
These fit fine on a stock 128i (base) and modified 128i (bmwps). They are now on a 135i Msport (waiting on mfactory coilovers).The tire might contact the fender liner at full lock but that only happens at 5mph... fender and strut clearance is more than adequate at Msport height. These pss 235s hook better in the rear than the stock 245 runflats. The more I drive the 135i with the square 235s the more fun I have. I am only selling this setup because I bought kerscher fenders for weight saving and more clearance. Last edited by bNks334; 08-10-2016 at 09:21 PM.. |
08-13-2016, 01:17 AM | #7 |
Never Lift
11
Rep 62
Gotcha. And yeah, the super sports are a VERY aggressive drop. I got my Vorshlag camber plates today, I think with the extra camber, I might be able to actually run these. Sending PM
08-13-2016, 01:57 AM | #8 | |
Bashar
416
Rep 1,121
Do you think it's possible to fit a 245/35/18 tire up front with those Apex wheel offsets? I ask, because right now I'm running 235/40/18 on VMR wheels (18x8.5 et40) and I have to set my coilovers at stock ride height or else the tire will contact the spring perch. |
08-13-2016, 10:04 AM | #9 | |
427
Rep 957
You'd probably need a 5mm spacer (et40) to clear the strut. The question then becomes fender clearance. You'd have to find out what ride height and camber you'd need to clear the fender. |
08-16-2016, 12:33 AM | #11 |
Boost
1354
Rep 3,692
Drives: 135i M-Sport
I run the equivalent of 265 tires square, PSS coils, 8mm spacer and M261 8.5 rim. About -2* up front camber. No rubbing and no fender mods or rolling. It's doable for sure.
Willing to part out the rims? Looking for 2
F80 M3 TrackBoi, Z4MC GarageBoi, 1M Clone StreetBoi
08-16-2016, 08:08 AM | #12 | |
427
Rep 957
I have people interested in them as a set. No ones shown up with money yet. I'll keep you in mind though. |
08-17-2016, 09:45 AM | #13 | |
130
Rep 351
Ohlins Road & Track Coilovers / Apex ARC 8's 245/255-35 MPSS / Wagner Downpipes / Wagner EVOII Intercooler / ER Charge Pipe / Forge DV / PowerFlex RSFB / PowerFlex Differential Bushings / MFactory 3.46 Torsion LSD / MHD Flasher
09-14-2016, 12:37 PM | #17 | |
82
Rep 847
Drives: 2011 135i M Sport
Need a 3mm spacer to run that. I run 255 with Shaved Vender and 3mm spacer.
BMW Performance Kidney Grille, CF Lip Spoiler, CF Diffusser, Blackline LCI Tailights, Magnaflow Full Exhaust, BMS Intake, Jb4 w/ E85, Meth Injection, BMS DP, VRSF 5" Intercooler, CP-E Charge Pipe, KW CS Coilover, M3 Subframe Bushings, VMR VB3 Wheels, Stage 2 Fuel Pump, M3 Control Arms, Dinan Camber Plates, Pure Stage 2.
09-19-2016, 10:16 AM | #19 | |
4338
Rep 6,196
bNks334426.50 |
