03-26-2008, 09:21 AM | #1 |
67
Rep 579
E90 vs. E92
Other than the fact that the E90 has 4 doors and the marginal weight difference, are there any other differences mechanically between the two? Say the steering ratio? Thanks
03-26-2008, 09:24 AM | #2 |
Reincarnated
245
Rep 4,227
03-26-2008, 11:54 AM | #4 |
236
Rep 3,303
+1, I would love to know whether with the CF roof does the coupe truly have a lower center of gravity and thus have slight better performance through the twisties / the track.
"...it's not about the money and not about the brand of the car, it's about handling,performance and passion......And that, no other car has all together like an M3........when you talk about the most complete car the M is invincible." --Tony Kanaan. |
03-26-2008, 11:57 AM | #5 | |
532
Rep 5,498
Jason
Instagram: jellismotorwerks |
03-26-2008, 01:47 PM | #8 |
126
Rep 4,144
I've searched but have not found any info on steering ratio. Remember that both models have the variable ration steering.
I did confirm that driveline ratios are the same. The sedan is about 25 lbs heavier, but don't know in which configuration. It's also roomier inside. I don't know about the trunk; I would think that is is smaller since the cabin is bigger and the sedan on a whole is shorter than the coupe.
2017 F80 YMB.
03-26-2008, 01:57 PM | #9 |
126
Rep 4,144
Just found more info. I take this with a grain of salt as I've seen slighty different numbers. The coupe data comes from Edmunds, sedan comes from Motor Trend.
Steering ratio: 12.5:1 for both (looks like the same) Turning circle: 38.4 ft coupe/36.1 ft sedan (typo? s/b same considering same wheelbase) Cargo: 11.1 cu ft coupe/12 cu ft sedan (sedan has more?)
2017 F80 YMB.
03-26-2008, 02:23 PM | #10 | |
1310
Rep 6,311
probably cars are pretty much the same, with difference felt only by some testers like STIG or whatnot.
997.2
F30.F11.E86.E90.E90.E36 |
