03-23-2008, 11:57 AM | #1 |
75
Rep 1,288
How will E90 facelift for '09 affect the M3 sedan?
2009 E90's will have facelifted fronts and new (shape?) taillights.
Will this make 2008 E90 sedans instantly dated? Will they adopt the new taillight look? Any guesses? I wouldn't want to order an 08 if it's going to be dated in a few months.....
2009 135i 6MT Euro Delivery 9/5/09
BMW Performance Power Kit - Exhaust - Short Shifter - Suspension |
03-23-2008, 12:16 PM | #3 |
46
Rep 528
The M3s should have facelift otherwise its a bit ridiculous you pay over your head and someone pulls up next to you at a traffic light with 320d with the new lights...
03-23-2008, 01:43 PM | #4 | |
33
Rep 657
Both the standard sedan and coupe had facelifts during the e46 production run, no changes were made to the M series. Only change I expect, would be tail lights changing to LED or rims, etc. In addition, the e90 3 series already has a different face than the e90M3, as the M3 follows the coupe face anyways.
-Dave
2008 E92M3-Space Gray Eisenmann Sport Exhaust_MT/Loaded Last edited by DJ9; 03-23-2008 at 06:37 PM.. |
03-23-2008, 03:15 PM | #7 |
Moderator
7515
Rep 19,368
My take:
If the rear fenders change then no the E90 M3 won't be updated, but if just the tail lights (LED?) and/or decklid changes then the M3 probably gets them. In the latter case you could probably retrofit them on your MY '08, though it would not be cheap especially if you have to get the decklid. |
03-23-2008, 03:17 PM | #9 |
23
Rep 497
Won't change. Just what the guys above said. The M3 might get LED tail lights is all and I highly doubt that would even happen for at least 2 years.
2008 M3 Space Gray, Black, Syc Ant Wood Trim, DCT
2001 325ci Steel Gray - Sold |
03-23-2008, 08:17 PM | #11 |
33
Rep 657
I always assumed it was merely the front/rear lights and not the bumper, hood, bonnet, etc...actual body panels on the E60. The e90 change is a complete bumper and hood rehaul....different body panels altogether.
Could you elaborate on the 5 Series change please?
-Dave
2008 E92M3-Space Gray Eisenmann Sport Exhaust_MT/Loaded |
03-23-2008, 09:21 PM | #12 | |
4975
Rep 6,241
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
03-23-2008, 10:01 PM | #13 |
532
Rep 5,498
If history repeats itself then NO. M3's traditionally dont receive facelifts throughout their production runs. Look at the E46 for example. The only change I can think of with M3's are some minor trim (nose grills) changes on the E36 and E30....
Jason
Instagram: jellismotorwerks |
03-24-2008, 07:16 AM | #14 | |
62
Rep 403
E39 M5 had the old headlight when it was introduced, then a year or 2 later it got the face lift. though M hardly get face lift in general. back to the subject, the E90 4 door 3 series need more of a rear lift than a front lift, even though the front needs a lift, but the rear even more. |
03-24-2008, 04:12 PM | #15 |
401
Rep 3,288
The M3 in specific would not be affected by any fender or body molding change made to the basic BMW e90, e92, and e93 models. Specifically because the M3's body panels are already unique to the car and the M3 in general shares very little common parts to the normal 3-series cars.
A change made directly to the light-clusters may be a different matter depending on how drastic of a change it is. For example, is the change made alters the footprint for the light cluster to fit into any body panel then that change would likely not be applied to the M model car. A simple LED conversion from normal bulbs could be made on a M model though, since it wouldn't require body panels to be re-manufactured to fit properly. A prime example (mentioned briefly above) of all of this can be found in the e46 model line-up. The M3 was only available in only the coupe and convertible styles and both were labeled under the code e46 back then. The coupe/conv. models received both a front headlamp cluster facelift (along with the front bumper of the normal 3-series cars) as well as a rear taillight LED update from bulbs. The M3 did not take the headlamp cluster changes but did update to LED taillights. The LED taillights also became available to retrofit onto previous non LED e46 cars through after-market brands.
03-24-2008, 05:03 PM | #16 | |
75
Rep 1,288
I'm thinking similarly. From the spy shots of the facelifted E90, it looks like the trunk portion of the rear taillights will change, not the portion on the fenders.
03-31-2008, 08:41 PM | #17 |
Conspicuous consumption
99
Rep 1,183
I truly believe the E90 M3 will receive the facelifted caboose of the upcoming e90. I think those in BMW's marketing department are bright enough to understand the uproar of protest over the current E90 caboose. One must also remember the quick implementation of the face lifted of 5 series to the E60 M5
03-31-2008, 11:54 PM | #19 |
61
Rep 908
Drives: em-funf
Garage List 2000 E39 M5 - current [0.00]
2007 E92 335i - SOLD [0.00] 1996 E36 M3-SOLD [0.00] 2000 E39 M5-SOLD [0.00] 2001 E46 M3-SOLD [0.00] 1995 E36 M3-SOLD [0.00] |
all speculation. nobody knows.
04-01-2008, 07:38 AM | #20 |
Moderator
7515
Rep 19,368
Speaking of which - there exists some E90 3 series facelift spyshots of what appears to be a Space Gray car. If true, this would very likely mean availability of Space Gray for the E90 M3 in MY2009.
04-01-2008, 09:19 AM | #22 |
Moderator
7515
Rep 19,368
Not necessarily. Did you read the other responses before you posted? It is almost 100% certain (based on spyshots) that the E90 3 series gets new tail lights. But that alone does not guarantee that the E90 M3 will change.
