M5POST
Go Back   M5POST - BMW M5 Forum > F10 M5 Forum > Wheels | Tires | Suspension | Brakes | Chassis
      06-24-2016, 06:23 AM   #1
evilb
evilb's Avatar
167
Drives: McLaren MSO 570S, 18 Raptor
KW HAS - Coil Bind Solution
Hi Gents --
I'm running the KW HAS on my M5. I had my car looked at the other day due to the relatively common noises heard during low speed turns, specifically on uneven pavement. The tech showed me that on the passenger front side, the coil actually binds when the wheel turns and creates a knocking sound. Interestingly enough, this isn't duplicated on the driver side.
He recommended thrust sheets, potentially the ones with bearings, to prevent or reduce this.
Have any of you done this mod on your KW HAS or Dinan HAS setup? It's clearly not a safety issue, just "one of those things," but wanted to ask for feedback on anyone with a similar issue.
Best,
Brad
2016 McLaren MSO 570S | 2018 Ford Raptor | @alpha7even
jonsnowm3104.00
      06-24-2016, 07:37 AM   #2
v3n0m
57
Drives: 2013 MCB M5
From the looks of the dinan kit it includes thrust sheets.
      06-24-2016, 08:44 AM   #3
M5Beast_NYC
158
Drives: 15 M5
maybe its missing a washer on the bottom that can spin freely when you turn the wheel left and right? how about the top and bottom spring end, is it seated properly?
      06-25-2016, 05:49 PM   #4
Blkthght
28
Drives: 2015 F10 M5 CP Singapore Grey
I also have the KW HAS setup and have been running it for a month. Springs perform great and I haven't heard the noise that you describe. My first guess is that you have an installation problem. If it was a matter of some kind of defect created by the springs that only materializes after wear, then I would have expected others who have been running these springs for a few years now to say something. But this is the first I have heard of this. I suscribed to this thread since I'm definitely interested in hearing others' experience.
      06-28-2016, 10:27 AM   #5
JtheW
113
Drives: 22 m850gc
I've got the HAS on my car for about a year and never had any issues with them.
22 M850i gran coupe
m5post
