06-23-2016, 08:09 AM | #1 |
152
Rep 458
Soft-Close Door Bulletin
All X5 option packages in Canada include soft close doors. Since I have small kids I find this option extremely useful - they can't always close the doors well.
I'v heard about doors popping open in the US bit Canada says they have never had a reported case (don't know how true this is). I am worried about the doors popping open and feel if I wait for it to happen knowing there was a bulletin it would be partially my fault. Does anyone know if this has been fixed for 2016 MY and if not should I just ask the dealer to apply the SIB? Thanks for your thoughts. |
06-23-2016, 08:12 AM | #2 |
521
Rep 5,483
I personally have never heard of the doors popping open, and I cant even understand how that would be related to the soft door close but who knows?!
The dealer can only apply the Service Bulletin if your VIN calls for it..they can't do it unless your VIN is one of those affected by the fault.
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather 2020 Range Rover HSE - Black/Black 2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black |
06-23-2016, 08:44 AM | #3 |
5450
Rep 8,815
this never happened on my 2015 X5. Even on the cases where it did open for others it not to the point where the door actually swings open. It just open to the secondary latch (like if you didn't shut the door hard enough)
Alan
06-23-2016, 10:57 AM | #4 |
627
Rep 1,181
Many documented cases of this, including myself. I brought my car in for normal service along with reporting that the soft close actuator on the rear passenger door popped open ONCE. As Alan mentioned, the door will not fully unlatch/open at speed, but it's still a safety issue.
They not only replaced the failing part, but replaced all four with an updated part that always operates, regardless of whether the door is partially or fully shut. You can hear the motors operate even if you fully slam the doors shut. I posted about this in a thread a few months ago, but the search function on the app isn't really functional so will have to find it and edit this post with the link later.
A little mod here, a little mod there...
06-23-2016, 12:46 PM | #5 |
Self-Deprecating Narcissist
7266
Rep 6,561
SIB 511614 states there was an issue on some vehicles (IIRC) but i believe there wasn't a fix at that time... then there were updated actuators installed on vehicles that experienced an issue... so in theory the newest vehicles should have the updated actuators/motors but i am not certain.
06-23-2016, 02:04 PM | #6 |
145
Rep 409
EPC doesn't show when they changed the soft close door parts, but the early ones are NLA.
"Old" parts: 10 Lock, Bowden cable, front left SCA 1 51207323781 ENDED 10 Lock, Bowden cable, front right SCA 1 51207323782 ENDED "New" parts: 10 Lock, Bowden cable, front left SCA 1 51207419839 10 Lock, Bowden cable, front right SCA 1 51207419840
Jon Maddux
coupenut.blogspot.com x5nut.blogspot.com 16 X5d | 08 M3 Sedan | 06 M Coupe | 01 M coupe | 99 M coupe |
06-23-2016, 09:10 PM | #7 |
152
Rep 458
Thanks for all your comments.
From what I am being told the service bulletin was mainly for 2014 and early 2015 models. Apparently they changed the actuators. Not sure I should just take their word on it or just keep searching. |
06-26-2016, 01:33 AM | #9 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
Really, it's not something to obsess over. It's not like the doors would just go flying wide open. A very small percentage would become partially unlatched. They were still partially latched so they didn't fly open. This happened to a very small percentage of people and if it did happen, you would get a warning gong and a warning light on you dash so you could pull over and properly close it. And if that were the case, take it to the dealer and they will replace them. Nobody was ever hurt. And the problem seems to have been fixed. There are other, much more likely things in this world to worry about.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
06-26-2016, 08:56 AM | #10 | |
521
Rep 5,483
Current:
