06-21-2016, 03:14 PM | #1 |
518
Rep 788
Stock ZCP Dyno?
Anyone have a stock ZCP on a dyno, preferably back to back with a non-ZCP, to see if it is truly only a 14hp increase? It sure feels like more than that on the butt dyno...
06-21-2016, 07:52 PM | #3 |
2634
Rep 2,809
06-21-2016, 08:12 PM | #5 | |
BimmerPost Supporting Vendor
8254
Rep 18,843
Drives: BMW
We've dynoed a few ZCPs now, numbers are pretty consistent. Hope this helps.
domino_z1254.50 |
06-21-2016, 08:22 PM | #6 |
2634
Rep 2,809
06-22-2016, 03:00 PM | #9 |
1009
Rep 1,388
06-22-2016, 04:18 PM | #12 | |
1009
Rep 1,388
CARS = ZCP/Comp - Non-Comp DYNO = EAS - VF Engineering - Reach(unknown dyno location/type) Dyno results can vary (even with the same car) if you dyno them on different days based on weather, airflow, the way the vehicle is strapped down, fuel quality, etc... Make them different cars altogether, being dyno'd on different days, and you get what you see above which are wildly varied results. The most consistent use of a dyno is to measure the same car, on the same day, under the same conditions for weather and airflow, without removing it from the dyno in between the modifications. The 2016 BMW M4 ZCP car we have here today is being measured using that exact process. We'll be posting the results with the HEX Tuning Stage ONE ECU Software shortly. |
06-22-2016, 04:31 PM | #13 | |
2634
Rep 2,809
What fuel was used on these pulls? 91 octane? Also, where both of these cars dynoed on the same day? Can you post the uncorrected graphs? |
06-22-2016, 05:38 PM | #14 | |
1009
Rep 1,388
Both cars were dyno'd on different days, which is why I specified the "Stock non-ZCP" dyno as being for reference use only. NOTE: We also dyno these cars in 4th gear because we like the shorter pulls and lower drum speed. We know we can get slightly better numbers in 5th, but we dyno for deltas, not for max values. Uncorrected plots will be posted in our Master Thread by the end of the day. (click to jump) |
06-22-2016, 09:56 PM | #15 | |
89
Rep 116
06-23-2016, 09:33 AM | #16 | ||
21122
Rep 20,741
Drives: 2021 911 turbo
425hp -> 444hp (US units) 431ps -> 450ps (EU units)
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
06-23-2016, 09:41 AM | #17 |
2634
Rep 2,809
It appears the ZCP car was overshooting its boost target. Without a datalog or at least a boost plot, it's hard to say for sure. The DME could also be pulling timing as well.
