06-18-2016, 02:12 PM | #1 |
905
Rep 2,651
Drives: M4 Comp Pack
Exhaust Flaps and their intricacies!
OK guys, I'm a little confused at the operation of the exhaust flaps on the ZCP and the various criteria for their opening protocol.
Tell me if i'm right on the below here please:
Thanks for taking the time to answer for those who do. |
06-18-2016, 02:53 PM | #2 |
372
Rep 189
Valves are fully closed on a close start
Eco - always shut, sport - open more of the time, Sport plus - open a bit more than sport. Valves will never be open all the time in any mode switch ignition on, put into sport plus and press Pedal. Valves now open on cold start Valve controller has diff options, I have mine as default set to oem settings. When I switch it on it opens valves fully Valves can be disconnected for more noise but I wouldn't recommend. Had this done until last week for the last 5 months. Connections in the connections were all corroded despite me taping them up to stop this Valve controller is the way forward, fitted mine last week and it's great. Quiet when u want and balls out when u don't. I have the secondary cats removed also along with backbox mod I bought from here: http://m.ebay.co.uk/itm/NEW-BMW-2015...123?nav=SEARCH Basically cost me £150 delivered and I've not been hit with customs charges. |
06-18-2016, 02:55 PM | #3 | |
905
Rep 2,651
So You reckon the CG controller is the way to go? Can i ask where you purchased? Edit: just saw link! |
06-18-2016, 02:58 PM | #4 |
763
Rep 948
Hello,
Not sure about all the questions , however I'm running a CG controller on default open and activated OEM, so on start up and all day running its open and only if I activate they will close, this never happens btw it's loud so I assume CP will be better, if your near Glasgow at some point I can let you hear it You can configure any way you want so you could do default closed and activated open to give you the standard start, less noise. Roughly 200 pounds delivered with the tax paid on delivery, fitted in 30 minutes, just done my second one of a friends vert. Hope this helps John |
06-18-2016, 03:00 PM | #6 | |
372
Rep 189
06-18-2016, 03:03 PM | #7 |
763
Rep 948
06-18-2016, 03:06 PM | #8 | ||
905
Rep 2,651
Im based just outside of Glasgow too so would be well up for a Scottish meet. I dont get my car until September though so you'll need to bare with me! Lol. |
06-18-2016, 03:07 PM | #9 |
905
Rep 2,651
06-18-2016, 03:21 PM | #11 |
905
Rep 2,651
06-18-2016, 03:33 PM | #12 |
763
Rep 948
Your welcome to meet up anyway, give you a look round a few cars while you wait!
06-18-2016, 03:34 PM | #14 |
905
Rep 2,651
06-18-2016, 03:36 PM | #15 |
905
Rep 2,651
06-18-2016, 03:50 PM | #16 |
372
Rep 189
He makes trips up quite often for forum members as long as enough people want it done.
Yes bud very happy. It sounds very close to the mpe and is not too obnoxious which is what I was after |
06-18-2016, 03:51 PM | #17 |
905
Rep 2,651
06-18-2016, 06:24 PM | #18 |
642
Rep 1,700
http://www.cgprecision.com is where I bought the controller from.. Defo a great buy.
You're spot on with your observations. Ask Gtsussex as he has pretty much sussed it out I love it when you start up with valves closed and then press 'on' and the valves open and the depth of sound more than doubles.. And if you put it in sport straight away and drive off before the revs regulate the exhaust sound is amazing.. Everyone can here it and turns for a second look I had my valves unplugged left open for a few weeks but found I wanted them closed on motorway runs to stop drone. CG controller is spot on. I paid about £200 including import taxes from the US. I believe the valves stay open on oem start up when warm in all settings and then close. But remain open in sport +? Can Guy confirm? When in sp+ you get the lovely pops and crackles on the over run so assume valves are open then too?
Current - 2016 McLaren 650s Spider, Aurora Blue
Current - 2016 Range Rover Sport SVR- Black Current- 2018 Aventador S. Nereid blue Gone - 2016 F80 CP, 2015 991 Turbo S, 2016 LCI M135i. 2015 F10 CP M5. 2015 X5, 2012 E92 CP M3. 2009 E92 335i |
06-19-2016, 12:50 AM | #19 | |
905
Rep 2,651
06-19-2016, 01:56 AM | #20 | |
1854
Rep 3,983
In efficient, the valves will open over 4k with foot down. Sport and Sport + - valves close at constant speed or low revs. I've kept my CG controller so far as noise at startup is hilarious. But with the CP, it's not needed anywhere as much as standard car as software already opens valves a lot more anyway.
San Marino Blue M3 Competition Package with Carbon tat, ACS RS suspension, uprated brakes, 'modded' exhaust and a weeny bit more power courtesy of JF Automotive; M235i Convertible with ACS Sports Suspension; Disco 5 HSE Lux
06-19-2016, 02:41 AM | #21 | |
905
Rep 2,651
I had watched your video where you thought the CG was not that necessary due to the CP differing from stock. I think i'll make some use out of the CG controller so took the plunge anyway! |
06-19-2016, 02:44 AM | #22 | |
306
Rep 633
