Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M4 GTS Discussions
      06-11-2016, 07:41 AM   #1
Paul-Bracq-BMW
Moderator
Paul-Bracq-BMW's Avatar
Australia
4097
Drives: 1981 323i, sports M5, LSD
M4 GTS full test in Autobild Sports Cars July 2016
Enjoy!
1981 323i, 143 Kashmir-Metallic, 0094 Pergament, Sports M5, LSD.
Appreciate 2
redrumm3417.00
      06-11-2016, 07:42 AM   #2
Paul-Bracq-BMW
Moderator
Australia
4097
Google translation here... You'll get what they mean...
Just in time for Thirty Years now also mutated the M4 for whole blood
Racer. Thanks to water injection strengthened its Reihensechser on
500 hp, the true fire blazes but especially lateral dynamics
Development work seems to be a
terribly simple matter
to be. At least
You might think so,
when the fathers of the new
BMW M4 GTS as listening. The engine tinkerer
about, the very one
hypocritically tells that he indeed
cook only with water; the lightweight construction,
the recently his door panels
from renewable resources
pressed. The aerodynamics,
the - addressed to the attachments
- Forthwith his wrench
draws. And of course the
Jörg Weidinger, of 7: 27.88 minutes
ultimately on the Nordschleife
burning and us to
Kick off the Super tests once
expecting an easy three-set, calculates.
Logically, if you
Consider that he on about 20 kilometers
Nordschleife around 20 seconds
moves out to a normal M4,
then should be obvious where
one to nearly four kilometers
Sachsenring lands. Ah, okay. said
Normal-M4 is 1: 37.22
Minutes in our list. Power
According to Adam Riese ...
You know what? we lift us
the better for later. Because no
as loose as this the M-boys
just reckon here was the
course of the M4 GTS not way. 20
Seconds can be found on the Nordschleife not just; above all
not in such a strong base
as the M4. According holistically
had the M GmbH their
So protégé umkrempeln. instead
the series set-ups depends now
a three-way coilover suspension
adjustable compression and rebound
and nachjustierbarer height
Wheelhouse. Stabilizers and support bearings
modified, cycling and
Axle at the front also;
the front axle is also dependent on
backlash-free ball joints, what their
the last remnants of blur
casts, while the support of the
Rear axle - as was the case M3
GTS - rigidly bolted to the body
has been. Ofcourse the
GTS also somewhat wide-gauge on
the road (+17 mm front, +1 mm
behind), the growth front
especially on the new set of wheels
decreases. In contrast to the base,
the on-255mm front and 275er-
Rear tire is, it makes the
GTS on 265ern front and 285ern
back comfortably. And of course not
on any but on specially
for him the mixed Cup-
Michelins that on at that gaudy
painted forged wheels in 19
and rotate 20 inches, not so
leaden cast Alus.
Which brings us "already" when
Lightweight would, to the M GmbH
similarly sexy staged. In shape
the hood, for example, the
as the trunk lid and numerous
other small parts now made of carbon
consists; the bucket seats with
pay twelve per kilo to fighting weight
and a clear one at that
place deeper. In the form of
almost obscene sounded strong titanium
Muffler, the twenty
Percent weighs less, or
the back seat, the old for good
Clubsport model does not even
was mounted. Reads quite
impressively added, shows the
End but unfortunately not quite the hoped
Effect. are 1599 kilos
on our scale - just
25 less than the normal
M4. So all just window dressing?
Definitely not! Bring the boys
certainly around 60 kilos out.
Just come in the form of extra free
Clubsport package (brackets,
Six-point belts, fire extinguisher)
and the water injection just
again around 35 to!
longitudinal dynamics
The Clubsport package would have
as one of the (long since found)
700 buyer omit course
can, water injection
but is an integral part
the overall performance boost -
and therefore indispensable. In this city of its civil
Appearance hovering the GTS already
quite confident in cost-orbit;
considering his performance
However, in the best (GT3) society changes on twincharged
Reihensechser purely mechanical
Once virtually nothing. The
More power is more likely to completely
classic regarding the charge pressure. 1.2
Bar moves the base, 1.5 now the GTS.
Problem: With increasing charge pressure
also increases the intake,
which in extreme cases lead to palpitations
can.
And here now is the water injection
at. Once you beyond
5000 tours fully on the gas
pinselt, squirt three injectors a
fine spray into the intake manifold,
of the air addition
cools down to around 25 degrees.
Thus, despite the higher charging pressure
Next early ignition
be driven, which the combustion
efficient and the
Lowers exhaust temperatures, which
turn the combustion chamber temperature
benefits. The catch: The water
must of course be carried.
In the form of a five-liter tanks
in the trunk, which on the track
around one, on the road
enough for about five tank fillings
should. Too bad, if - as in
our test car - the water level sensor
something baseless in
Container sloshing around. Regardless of whether
Slalom or on the highway
- The GTS exhorted us spite full
Reserves almost viertelstündig mind
that we yet again a
few liters should nachgluckern.
Besides, slams the buzz
but right. At least then,
if you look at the slightly pointed
Power characteristics of
has series first molar injected.
The GTS is not in the basement
quite as easy going as the
Series, growing from 2500 tours for
but more colossal upwards. to
Center it pushes on a perceptibly more imposing
600 Newton-meter-high,
but which he did not turn
quite as sustainable in the tips
expands. Unlike the series, the
one quasi hesitation on 7600
Tours can fire because even until the very last rung incessantly easy
applied power, you can
in M4 GTS so quiet early as
7000 / Paddling min into the next gear.
Everything about it is rather the
Speed ​​reserve as the best
Propulsion.
Speaking of propulsion: The designed
Also on the part of the transmission
more efficient, especially at the start.
Because unlike earlier where
the M double coupler so happy again
übermotiviert something "around rammed"
operates the Launch Control
the GTS for the first time with feeling. You couples only and then
correctly; on swift and
but also smoothed. given the
massive traction foundation of
Cup tires, the aforementioned sufficiently
More performance, and finished the
3.7 to one hundred, the approximately four-tenths
lower than what we previously
measured with the normal M4
have. At two hundred is the
GTS with 12.2 to 13.2 finally
smooth one second front, where a
but already steals the impression
that aerodynamics and
Wheel upwards out noticeably on
press the accelerator.
lateral dynamics
And we have wings, splitters
and suspension only for rapid
Round in their respective fighting stance
brought. Just as the StVZO
prescribing the most radical respectively
Positions on public roads
actually prohibits. What the
brings Schrauberei? Now, a whole
Quantity (each front: rear): 28
and 93 kilos of downforce at 300 km / h
1.4 and 2.0 degrees negative camber and
almost endless possibilities,
handling in tensile and
Pressure stage to the personal
Things feinstzutunen. Our
Tip: Visit one of these you
Track Days, the whole lot of track time
offer, and why not try
a few clicks in train and pressure
by. It is worth it ..
For this reason alone, because the
all this Porsche Group
can sometimes stir up really.
All the martini snob in their
custom Sparco Einreihern,
which always exaggerate their GT3s gasping to the limit,
because as a 997 just quite
wants to be knowledgeable moved
if it is to be quick. Any bets:
You flocculates the fastest time significantly
relaxed from the sole. Because
compared with as a Porsche
the M4 GTS does not feel long
so rasierklingig on. On the contrary:
He drives in principle more like a
normal M4, just without
which blurs. The steering
angles accurately, the front spurt
determined, the tail is rich.
The suspension absorbs noticeably
firmer, the ceramic brakes yet
balanced, while remaining hardwearing
until the very last lap, while
what is between Kurveneinund
outgoing so everything withdraws, to
really modulate spot-on
leaves.
Usually tend border areas
yes to the narrower to
are, the higher they are screwed.
In GTS, however, now seems the opposite
to be the case. He is lying
highly accurate, yet easy in
hand, leaves a at each time point
feel exactly what
one is, announces oversteer quasi
with forward and erased then,
when a the gas pedal
bit goads, even butterweich
into the sliding friction.
And so we finally stitched to
the course, the curve drills correctly
nice to train down, drops anchor
at the last moment, fires
one, down two gears, spans
the wide-awake Reihensechser again
to the chain and mills the next
Just opposite. round
Round after round. Because once adjusted to 2.1 bar, also keep
the tires really long by where
the fastest shot course
succeeds only on dewy soles.
What we turn to Jörg Weidinger
Three set brings back the yes
a deep 1: 33er had prophesied.
Lo and behold, right there found
the M4 GTS in the end, where
you not believe as a driver
like how such a casual handling
Artists actually end up as
can be fast.
emotion
Well pointed tongues say yes
quite like that M GmbH no genuine sports car, but only
sporting offshoot of Allerweltsmodellen
build. And even if the
M4 GTS this thesis only partially
disproved - because he, despite his outstanding
Dynamics continues to
remains before a child of the middle class
- So is it exactly it also
the special attraction. Or to put it
once something heretical to formulate:
Had the CSL depending on such
a legend has grown,
when it once is not as radical
M3 would have born?
Remote such fundamental battles
injected a GTS serotonin
anyway in the highest dose. In front
all acoustically: when its titanium
Muffler tearing the flap,
imperious speed tubes
mingled with steely exhaust-milling
and Schubert's Unfinished
summarily executed on the chainsaw
- Goes more to the Twelve
actually only in Italy! you like
it more civilized? Well, then sit down
and all the finely worked out
anschmachten Touring Car Details
- And the bar included
do not forget!
everyday life
That one not a M4 GTS
just to Obi-parking to
grinding needs, should actually
be clear. Still riding BMW
quite persistent on the subject
Everyday around. And that does not even
wrongly. The offer Semi Slicks
quite passable moisture reserves,
the trunk holds despite water injection
unchanged 445 liters
ready. Not to mention the landing gear,
the streets in the set-up surprisingly
attentive and dampens
squeaky clean straight runs; or
the Reihensechser which this side of the
Full load remarkably efficient
is working. In the end, however, prevented
probably simply the strict limitation
an overly 700 copies
liberal use - and of course
the fact that only two of the expressed
comfortable Sport shells
were used.
Price-performance
Amazingly, less the price
of 142 600 euros (the far more
would have paid over 700 buyers) as
rather what BMW everything possible
mitliefert. Navigation system, Park beeper,
all multimedia Gedöns
including iDrive - guys, with all due respect,
it really would not now
second hand! The carbon wheels for
contrast, EUR 12 500 were many
worth a try.
Longitudinal dynamics ****
The Biturbo unfolds bit rougher and more pointed, but
still extremely spontaneous and effective. The brake
brilliant contrast in every respect.
Lateral dynamics *****
Currently, there is probably hardly be another athlete,
the so active driving and manageable at the same time on a
such a high lateral dynamics level acts.
Emotion*****
Look at it again briefly to the left, then likely
even you to vote to be clear. Full marks, alone
already for the gloomy creaking sound thunderstorm.
everyday ****
Even if it the M GmbH to every trick
radicalized, so it remains clear everyday compliant
as any Lambo. but counter exactly he takes
Price-performance *****
142 600 euros for the fastest BMW ever
really too much? Now, the customers have their say
long been ...
Total **** (4.0)
Appreciate 2
      06-11-2016, 08:48 AM   #3
larryn
2148
Drives: '97 332ti, '21 X5 45e, '16 GT4
I was sitting in one yesterday, revving it to ~6k, and it was an ear splitting, amazing sound. This is a very special car. The orange M666 wheels looked way better in person than any picture I've seen.
Thanks for posting and translating the review.
      06-11-2016, 10:09 AM   #4
PNWM3
535
Drives: 2023 BMW XM
You get to see the one at Seattle BMW? I'm flying home right now and will swing by and see it this afternoon!
      06-11-2016, 06:53 PM   #5
larryn
2148
It is there until tomorrow, Sunday. Pretty cool....
      06-11-2016, 08:56 PM   #6
dawgdog
148
Drives: 2015 M3, 2016 GT3
I saw the car at Seattle BMW yesterday and today. My God what will my neighbors think when (if) I bring home my GTS allocation. Sales manager had to quiet things down so they could continue to conduct business. And the GTS was outside! I want to drive one before making the final commitment. Not sure how it could be much faster than your car LARRY, as you are already faster than the 991GT3s and 997 RSs.
      06-11-2016, 09:09 PM   #7
Bashful
161
Drives: Some Germans
dawgdog..... as an FYI the show/presentation cars are not sorted mechanically, and dealerships are advised to not give drives as they do not represent the actual product.
Thought you should know....so you would have to drive another customers car.
      06-11-2016, 09:31 PM   #8
dawgdog
148
Understood! Another customer that I know should get his well before mine is built in September so hopefully I will get the opportunity.
      06-11-2016, 09:57 PM   #9
Bashful
161
Oh that's perfect!
Can I drive it too?
I put 1400kms on mine, and some other guys have put more, as I had to head home early and couldn't run it to the Nurburgring, but I would be surprised if you didn't love it. I don't want to blow up anyone's spot on the trip, but a few of us who took delivery of our GTS's also own 911's (or multiple 911s/porsches) of various spec incl Gt4's, GT3's, GT3RS's and even 911 cup cars...the list of cars goes skyward as you might imagine...All of us 911/porsche owners were extremely happy with what this car offers. I'm not alone in the sentiment 'it does not disappoint'.
      06-11-2016, 11:44 PM   #10
VCP
VCP's Avatar
1390
Drives: M4GTS BSM/F90comp/BSM M2CS
Oh that's perfect!
Can I drive it too?
And to not disappoint a Porsche owner is testament itself
      06-12-2016, 10:45 PM   #11
M4_GTS
Hong Kong
1153
Drives: M4 GTS
The M4 GTS is just a very impressive car!
      12-29-2016, 12:47 PM   #12
Captain Unknown GT4
Captain Unknown GT4's Avatar
557
Drives: GT4
Indeed👍
f80post
