BMW X5 and X6 Forum 2014-Current
      06-10-2016, 08:24 AM   #1
NPickles
71
Drives: F15 40D SE Space Grey/Terra
Parking brake on MY15 F15
Has anyone else noticed that when you stop and apply the park brake with the engine running it appears to apply and hold, but when you turn the engine off it appears to release and the vehicle rocks on the transmission park pin?
Mine has done it since day one, if you are stopped on a slight hill when you turn off the ignition it rolls ever so slightly.
The park pin holds it but if there is a park brake why not have that hold all the time otherwise whats the point of it?
      06-10-2016, 10:05 AM   #2
r33_RGSport
r33_RGSport's Avatar
12971
Drives: G09 XM, G05 X5 40, 991.2 T
@NPickles , yeap. Complained about it at the first week of ownership and the SA just said, that's how it is designed.
But since I have worked on the brake system, I think it is because on the first initial engagement, the e-brake and rear brake are both engaged. And after the engine is off, the rear brake is let off and the whole car is only held by the e-brake.
Which the e-brake is using the old school brake shoe system.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      06-10-2016, 10:20 AM   #3
spike5150
422
Drives: 2020 X5 M50i
Same on both of our F15's, and also did the same thing on our 2013 X3. My 2012 X5, however, did not have this issue.
      06-10-2016, 10:22 AM   #4
AntMan
Drives: BMW F15 X5 40d M Sport
Coincidentally, I took my X5 to the dealer a couple of weeks ago for exactly the same complaint, saying to them that surely the electronic brake should hold the vehicle securely once activated......they said that they couldn't find any fault
I've had other cars with an e-brake and never once experienced this problem. I know none of us park one inch away from any other parked car or fixed obstacle on an incline, but a 2 ton car shouldn't roll at all once the e-brake is activated, surely?!?!?
My kids now know to wait a few seconds once I park before they open the doors to jump out......
      06-10-2016, 12:33 PM   #5
m_alnimah
Qatar
70
Drives: 2016 Mini Cooper S 5 Door
2015 BMW X5  [10.00]
I've also noticed that back when I had my beloved X5!! Whenever I'd start the car with the Parking brake On and put on my seatbelt it would automatically go into "Hold" (discovered the Auto-release that way too) and whenever I'd park and engage the parking brake, it would hold untill the engine is off.
Whenever id turn the engine off id hear the sound of the Parking brake engaging at the Rear Left Tire (which I assume is that the Left Rear brake holds and the rest release)
Am I right?
2015 X5 xDrive35i M Sport, Black Sapphire on Terra Dakota Leather, Lane Change Warning, Lighting Package, 6WB, ConnectedDrive Services... (Sold) 2016 Mini Cooper S 5 Door Fully Equipped. (Sold)
2016 Audi A6 35 TFSI
2017 X6 xDrive50i Pure Extravagance, Space Grey on Coral Red, Fully Equipped.
      06-10-2016, 05:30 PM   #6
coolidge
56
Drives: X5 xDrive 35i
A parking brake that disengages when you turn off the engine would be retarded. Especially when parking on a hill.
      06-10-2016, 06:44 PM   #7
IvanLZ
IvanLZ's Avatar
139
Drives: 2015 X5 35i
Same here. Passengers in my car tend to get scared for a moment when getting off the car
      06-10-2016, 08:59 PM   #8
Samurai of 2day
Samurai of 2day's Avatar
2115
Drives: '22 X6M/'21 S1Krr
My F16 does the same thing. I don't use the parking brake often, but I have noticed that when it's engaged while the car is one, once it shuts down, it does a slight "jump".
Looks like it is common among all of our vehicles.
Too smart for my own good...
      06-11-2016, 08:34 AM   #9
MotoWPK
189
Drives: '13 128i vert, '14 X5 40i
Happens on our '14 as well. While the failure to hold most commonly occurs when the engine is turned off, it some times occur after a few seconds with the engine continuing to run.
Had the dealer check this recently and the tech's response was that there were no errors reported by the system (which is not exactly the same as actually trying it to observe the symptom, is it). I've also noticed that some times I can feel the brake pedal being depressed slightly when I apply the e-brake but not other times. It appears as if the system is applying the brake inconsistently.
Will have them look at this further the next time our X5 is in for service because it's certainly undesirable for the vehicle to rest on the transmission parking pawl.
      06-11-2016, 09:11 AM   #10
artem123
artem123's Avatar
250
Drives: G30
Bingo! That is exactly how my acts. It feels like a car releasing the parking break the second the engine turned off. Definitely strange. Although i barely use it since everywhere i park regularly is absolutely flat.
Ones drove a Reliant Robin. )))
      06-11-2016, 09:14 AM   #11
cmyx6go
cmyx6go's Avatar
15763
Drives: 2022 X6///M Comp
2019 X6 ///M  [10.00]
Same here. Happened on my '10 & '13 E71s and current F86. Can be unnerving, especially when parking on an incline. My sweetie's house has that sloped down driveway. I always back in and hold my breath when I set the parking brake and wait for that jerk. I'm afraid I'm going to go through the garage door.
      06-11-2016, 01:31 PM   #12
Pastor Passum
Drives: 2016 X5xdrive
Our '16 is the same. Living in the mountains, the ONLY level space is in the garage. Anywhere else and it's like other's have said, hold your breath and wait for the jerk. Not ideal, to say the least.
      06-11-2016, 04:06 PM   #13
coolidge
56
As this made zero sense to me I just read up on the parking brake in the manual which states, "The parking brake is used to prevent the vehicle from rolling when it is parked." It goes on to state a number of safety situations which the parking brake is supposed to keep the vehicle from rolling, including parking. So imo the parking brake is malfunctioning if its not doing its job and I'd print off that page of the owners manual and slap it down in front of the service manager and tell him to fix it.
      06-11-2016, 04:57 PM   #14
TOPEC
<3 Flat Four
217
Drives: 335is LM Blue
A simple test would be to park on a hill, engage the parking brakes n put transmission into park n shut the car off. Then pull up the gear shifter boot n use the tool to unlock the transmission from the locked park position. If the car doesn't roll then ur parking brake is working.
      06-13-2016, 06:56 AM   #15
pragueX5
pragueX5's Avatar
Czech_Republic
156
Drives: 2021 X5 M 40d mildhybrid
how about you all put the car in P, shut the engine, and engange the parking breake, and presto, no jerk.
      06-13-2016, 09:11 AM   #16
P1
P1's Avatar
11572
Drives: 2004 3/4 ton Duramax
My E70 did that, and so does the F15. I see it as "normal" at this point.
      06-13-2016, 04:58 PM   #17
MysticBlue
369
Drives: '20 M5C, '09 M3 DCT Coupe
It uses the parking brake control as an auto-hold when the engine is running and you are still in gear with the regular brake being held on. So you can come to a stop at a stop light and with your foot on the brake, initiate the p-brake and you can take your foot off the brake pedal. Then when the light turns green, just step on the gas to go... you don't have to turn off the p-brake. This feature means that using the p-brake control in this situation does not actually engage the parking brake, it just holds the regular brake. But if you then shut the engine off, the e-brake does engage, and the regular brake disengages. This is what you are feeling. I think.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra.
      06-13-2016, 05:11 PM   #18
stewy604
stewy604's Avatar
290
Drives: 2014 BMW X5 xDrive 35d M Sport
Agree, not ideal...but seems like normal operation (mine does it too). Definitely a little concerning the first time it happened to me...I was ready to stand on the brake pedal.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey
2007 Suzuki GSX-R 750
      11-29-2019, 07:01 AM   #19
BDO
276
Drives: 2016 X6 40d M-sport
Please check my reply in the other thread - the rolling is not normal operation.
      11-29-2019, 03:22 PM   #20
HydroStream6
88
Drives: F15 X5 50i M-Sport
My parking brake holds solid all the time.
      11-30-2019, 08:23 PM   #21
Qsilver7
Qsilver7's Avatar
4448
Drives: F06 650ix GC / F15 X5 50i
Just an FYI...on how the parking brake functions. When the engine is running and the parking brake is applied...the front and rear "hydraulic" brakes are applied (though DSC)...then when the engine is shut down, the electro-mechanical parking brake (rear axle) is applied.
So if the car appears to be moving...perhaps you should have your parking brakes adjusted or checked out...but it appears that there could be a physical feeling of movement (if the car is on an incline) as the regular front/rear hydraulic brakes are released.
BTW, the 2nd post in this thread (from back in 2016) appears to have mentioned this. See the highlighted text in the excerpt below from the BMW TIS:
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral.
      12-02-2019, 01:55 AM   #22
gvarr03
25
Drives: MY'15 X5 xDrive35d
Unfortunately, it is not normal. In E70 & F15 it is sort of a weak spot. Just have to either deal with it or replace/adjust the parts. Now, I've been fed a BS by the advisor that it was normal operation and technician test drove it and could not find anything wrong etc..
Mine X5 has been doing that kind of "jerking" on little, big hills it doesn't matter. I've been to two different dealerships trying to find out the problem. The result was both if the dealerships couldn't find anything wrong with E-brake.
Fast forward, I tried adjusting parking brake, Bowden cables and finally replaced EMF actuator unit and guess what happened? It's gone.
So I like mentioned I think it is a problem with X5's...BMW knows it but don't want to do anything about it...Kinda like the issues with lower control arms
xbimmers
