06-07-2016, 10:31 AM | #1 |
Supreme Czar
309
Rep 779
"flush"
Why does (almost) everyone refer to changing transmission and differential oil as a flush? There's nothing being flushed. It's the same as changing the engine oil. Why don't people say they flushed their engine oil?
Flush: "A transmission flush is a maintenance process where all of the oil in a transmission is removed, new oil (and sometimes cleaning solutions) is run through it using a special machine to push out grime and sludge and then it is filled up with new oil. The process is used to remove debris and sludge and replace 100% of the used oil with fresh, clean quarts." Last edited by kb9uwu; 06-07-2016 at 12:38 PM.. |
06-07-2016, 10:45 AM | #2 |
594
Rep 4,488
Why do some parts of the world call it a boot rather than a trunk when it clearly looks more like a trunk (chest) than a boot (footwear item)? Why are these the types of threads being created on M3Post these days?
At least in the case of the trans, to FLUSH it properly you actually have to run a pump rather than just letting it drain, so that more active process could be part of it.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
06-07-2016, 12:23 PM | #4 | |
Supreme Czar
309
Rep 779
As for the using the pump on the transmission, how is that flushing? "A transmission flush is a maintenance process where all of the oil in a transmission is removed, new oil (and sometimes cleaning solutions) is run through it using a special machine to push out grime and sludge and then it is filled up with new oil. The process is used to remove debris and sludge and replace 100% of the used oil with fresh, clean quarts." |
06-07-2016, 12:24 PM | #5 |
Supreme Czar
309
Rep 779
06-07-2016, 12:30 PM | #7 |
Supreme Czar
309
Rep 779
ok, well thread fail.
just trying to explain there's a difference between changing oil (what we do with our diffs/trans/engine) and a FLUSH. delete thread, carry on |
06-07-2016, 12:57 PM | #9 | |
594
Rep 4,488
06-07-2016, 01:01 PM | #10 | |
Supreme Czar
309
Rep 779
06-08-2016, 07:49 PM | #12 | |
Stop the hate, get a V8
3851
Rep 8,625
No, I think your point is perfectly valid. There is a very big difference between a flush and a drain + refill. If people want to be obtuse and argue for no reason, well, that's the Internet for you. I guess the pushback is to the effect of, "what do you want us to do about it?"
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
06-08-2016, 08:24 PM | #13 |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
With the toilet my favorite is the dry dock. Upper decker funny but the execution is difficult.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
06-09-2016, 08:39 AM | #14 | |
Supreme Czar
309
Rep 779
06-09-2016, 10:34 AM | #16 |
514
Rep 3,482
If you run cleaning solution and/or fresh oil through the motor BEFORE adding in the final amount, then you're flushing the engine oil. I denno. I've always been under the notion there was a difference.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
06-09-2016, 11:04 AM | #17 | |
Supreme Czar
309
Rep 779
Normally you only do a flush if you find lots of metal/contaminants inside engine/tranny/diff etc. |
06-09-2016, 11:06 AM | #18 |
514
Rep 3,482
BMWCCA:518970 |
06-09-2016, 03:28 PM | #19 |
4985
Rep 11,891
They're referring to the flushing of one's wallet due to the M tax
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
