05-30-2016, 03:47 PM | #1 |
Rep 79
A/C no longer working on driver's side
Hey guys, just wanted to see if anyone had any ideas about what might be wrong with my 09 135i's climate control system.
Right now, if I set both driver and passenger sides to the coldest setting, cold air comes out the passenger vents and ambient temp. air seems to come from the driver's side (ie: it's not cold but it doesn't appear to be heated either). If I turn the driver's side to the hottest setting, heated air will come from the driver's side air vents. From the googling I've done so far, I have seen the following possibilities: 1) Low A/C refrigerant which can be fixed with a simple recharge. Though this may also indicate a leak in the system. Honestly, this one doesn't make much sense to me -- wouldn't this result in some amount of cooled air coming from both sides but not enough to actually get the interior temp. down? But anyway, it's something that a lot of people are saying. 2) Blend door actuator is not working. This one makes more sense to me. But I am able to get heated air from the driver's side, so does that tell us anything here? I don't really have the money for an expensive A/C repair at the moment, so I'm looking for some of the cheaper solutions I can try first, or some of the easier DIY ones. |
05-30-2016, 04:28 PM | #2 |
European Editor
10589
Rep 22,992
My money is on #2. Get a scan tool reader and check for faults for the HVAC system. It will tell you whats wrong. Or go to a indi or dealer and have them read it for one hours labor rate.
05-30-2016, 10:39 PM | #3 | |
Rep 79
If I do need to replace the blend door actuator, is it a total nightmare involving disassembly of the entire dash? Or by some miracle is it somewhat accessible? |
05-31-2016, 04:13 AM | #4 | ||
European Editor
10589
Rep 22,992
Or you could buy a BavTech reader or BMWhat app or BMW Carly app and see if those will read the HVAC system. I onky know that the BavTech reader can read the HVAC system. Quote:
06-12-2016, 09:15 PM | #5 |
Rep 27
According to service information all six actuators can be replaced without removal of dash.
My vehicle actually has the opposite issue where cold air comes out of driver side irrespective of the temp setting when ac is activated. Passenger works fine. I don't think it's a blend door my vehicle reports it opens using diag tools but it waits to open until temp is at highest setting. So besides a blend door maybe a air temp sensor somewhere, there are three total in our hvac system. |
06-13-2016, 03:00 PM | #6 |
Rep 11
What if your heater valve was faulty? Coolant leaking past one of the solenoid valves inside the dual-zone heater control valve could warm the heater core on that one side of the car. That could explain the warmer air on just 1 side. I had this happen in an E46 that I had years ago.
06-14-2016, 11:00 AM | #7 |
969
Rep 3,323
I just had this exact same issue. No cold air coming from the drivers side vents.
3 months ago I had the system recharged. All is well now. The independent shop I used put in a dye to check for leaks. It probably has a small leak somewhere. I can deal with a once a year recharge VS. a $1200 bill to remove the dash to replace the evaporator. The evaporator is most likely the problem according to my indy shop mechanics.
Sparkling Graphite Metallic / 6MT / Terracotta Boston Leather / Sport Package / Comfort Access system / Gray Poplar wood trim / Heated front seats / iPod and USB adapter / HD radio / Premium hi-fi system / OE Tuning / VRSF Intercooler & charge pipe / BMW Performance short shift kit / BMW M Performance Handbrake Handle / BMW Stainless steel pedals / V1 hardwired / rear sun shades Pennsylvania 20 electoral votes
07-31-2019, 11:33 PM | #10 |
24
Rep 86
Drivers side a/c not as cold as passenger side.
Going to revive an old thread to try and get some advice. I thought my a/c wasn't as cold as it used to be so I took it in to my local indy and asked them to recharge the system. They told me that the passenger side was normal but the drivers side was not getting as cold. They said it is either the blend door or the actuator and it would be a minimum of 10 hours to take the thing apart to find out. They did not do a recharge because they said it would make no difference.
So now I am left wondering if it needs a recharge or not? When I turn the drivers side temp control to the colderst setting I have hear something shutting closed. Likewise when I turn the drives side temp to the hottest setting I also hear something close. I would assume what I am hearing is the blend door? Does this mean that my blend door is working? I get heat and I get cold... just not very cold. Could it be that the system needs a recharge and the Indy has misdiagnosed? I have the automatic system if that makes any difference. |
08-01-2019, 05:22 AM | #11 | |
4338
Rep 6,196
08-01-2019, 06:08 AM | #12 | ||
245
Rep 439
Year 1 - amazing AC Year 2 - whys my passenger side colder than driver? Year 3 - whats AC?
2008 SGM 128i - 3 Stage IM - 130i Tune - Dinan Camber Plates - BMW PE - Injen Intake - 1M Mirrors - LCI Blacklines - M4 Spoiler - Blacked 263's - Aero Bumper - Aero Side Skirts - OMGSplitter - AFE Intake Scoops
09-07-2019, 10:42 AM | #13 |
24
Rep 86
09-10-2019, 06:46 AM | #14 |
75
Rep 187
The real serious problems are when your heater stops working... That's a sign of a dead water pump. I'll take warm aircon over a dead water pump any day... But then again I've got a vert so there's no shortage of wind to cool me down.
