05-27-2016, 08:42 AM | #1 |
47
Rep 126
Power lag during fast shifts (6 sp)
I'm fairly new to M3Post, but not to BMW's. I've owned 3 E36 M3's, an e92 328i, and a lot of old Mustangs. Coming from the Mustang world, I've learned to shift extremely quick, especially between 1-2 and 2-3. I've never had an issue in my E36's, but when doing quick shifts at WOT in my 6 speed E90, I often experience a significant drop in power. It's as if there is either A) clutch slip (not likely, the car only has 28k miles) or B) the car is intentionally retarding timing to drop power.
Has anyone else experienced anything like this? Last edited by 91foxbody; 05-27-2016 at 09:36 AM.. |
05-27-2016, 08:55 AM | #2 |
151
Rep 410
Maybe it's the traction control coming on to limit wheel spin during fast changes. Try to do this with DSC off ?? But be careful! Lol
[IMG]http://www.xbimmers.com/forums/image.php?type=sigpic
05-27-2016, 09:05 AM | #3 |
47
Rep 126
05-27-2016, 09:19 AM | #4 |
Stop the hate, get a V8
3850
Rep 8,625
Does the E92 have a clutch-delay valve? I remember those from my Honda days.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
05-27-2016, 09:38 AM | #5 |
179
Rep 112
Drives: 2020 M4 Competition
05-27-2016, 09:54 AM | #6 |
256
Rep 1,174
05-27-2016, 10:20 AM | #8 | |
184
Rep 656
If you want a good intermediate that will allow you maintain full power with a nice little chirp into 2nd gear, rather than a full spin out, then use MDM mode... This will let you maintain full power though the 1st to 2nd shift without getting too squirrely!! I also find that a very calculated and precise shift is needed from 1st to 2nd at the red line point if you drive a manual like me... There is a split second of patience needed before pulling the knob back in order to get this right without missing second- and that is due to the clutch delay valve... Last edited by IIAp3x; 05-27-2016 at 10:30 AM.. |
05-27-2016, 11:37 AM | #10 | |
7494
Rep 12,310
Current:
16 F82 M4 GTS, Black Sapphire/Black, DCT 08 E92 M3, Sparkling Graphite/Bamboo Beige, 6MT 07 E85 Z4M Roadster, Alpine White/Red, 6MT 99 E36 M3, Techno Violet/Dove Grey, 6MT |
05-27-2016, 11:52 AM | #12 |
179
Rep 112
05-27-2016, 11:59 AM | #13 |
184
Rep 656
I'm not 100% on that... I just assumed they maintained that because my e46 m3 had one, and I had it removed to help with rapid shifting on the track.. Sure feels like it though on the 1 to 2 shift at wot... I always rev match but the 1-2 shift is tricky at the redline.. No? Could be just the extremeness of 1st gear versus the synchro action that makes it feel that way... I always have to hesitate a split second before engaging into second because its very easy to miss at the redline..
Am I the only one who notices this? For certain it is OP's traction control kicking in and causing his problem... Unless his clutch is slipping, which is unlikely at his miles... Last edited by IIAp3x; 05-27-2016 at 12:11 PM.. |
05-27-2016, 12:16 PM | #14 |
47
Rep 126
I genuinely doubt it's the clutch slipping, and I do my absolute best to not "pop" the clutch enough to get wheel spin, but the Michelins are quite a bit more quiet than I'm used to....so undetected wheel spin could (and most likely is) the culprit.
Thanks for the opinions everyone! |
05-27-2016, 12:25 PM | #15 | |
184
Rep 656
05-27-2016, 12:46 PM | #16 | |
7494
Rep 12,310
Current:
05-27-2016, 07:52 PM | #18 |
256
Rep 1,174
05-27-2016, 08:44 PM | #19 |
30
Rep 521
what you are feeling is the dual mass flywheel compressing it's internal spring. it is the same reason you don't feel a harsh driveline shock when transitioning between accel and decel.
05-27-2016, 10:07 PM | #20 |
875
Rep 611
Drives: 2013 M3 coupe' 6mt
If you are truly power shifting (right foot does not lift during shift) you are probably hitting the rev limiter. Try the 1-2 power shift at 7900 to avoid hitting red line.
memories: '71 2002 (new), '72 Bavaria, '74 2002tii, '00 540i Sport |
05-28-2016, 12:36 AM | #21 | |
178
Rep 446
2008 E92 M3 6MT |
05-30-2016, 11:33 AM | #22 |
184
Rep 656
May be on to something with this... I have noticed that the 1-2 is much easier around the 8k mark... I also notice that the power curve is flat after 7900 anyways so it does not really offer any gain shifting later, unless you are running a catless system with a tune... Mine is stock...
