      05-20-2016, 02:32 AM   #1
wrighty
wrighty's Avatar
50
Drives: BMW 1M
1M spacers
Is anyone running spacers on a standard set up with no issues.
      05-21-2016, 10:12 PM   #2
bdaddylo
bdaddylo's Avatar
168
Drives: 2017 F80 M3
I was running 12.5mm in the rear with the stock tire size with no issues. I recently changed my rear tires to the PSS in 275-35-19 and they rubbed with the 12.5mm spacers, so I'm need to get some 10mm.
_______________________
1991 E30 M3/Brilliantrot
2017 F80 M3/AW
      05-22-2016, 11:04 AM   #3
1&done
1&done's Avatar
247
Drives: 2011 VO 1M
For the street I run 10mm F, 5mm R. Didn't like the look of the 10s on the rear plus would likely rub w/ my suspension
///1M #643 of #740
      05-23-2016, 10:29 AM   #4
GimmeanM
We've landed on the moon!
GimmeanM's Avatar
1449
Drives: 2011 1M (AW)
2020 BMW M2 CS  [0.00]
2018 Toyota Tacoma  [0.00]
2011 BMW 1M  [10.00]
10mm Spacer issues?
Just read this on Turner's site and called and received the same advice from them on the phone. Can anyone confirm that this is or is not an issue? From what I have seen plenty of people run 10mm, so I can't imagine it's a problem...
**A note about 10mm spacers: Any 10mm spacer is considered a custom fitment. The stock hubcentric lip on BMWs can stick out by as much as 11mm. A 10mm spacer will bottom-out and leave a gap between the spacer and the hub which seriously compromises safety. The best way around this is using a larger spacer (12mm and larger do not have this issue) or check that the lip sticks out less than 10mm. In some cases you can modify the hub lip to get the 10mm spacer to fully seat on the hub.
here: https://www.turnermotorsport.com/p-3...tions/?pdk=AwE
I'm on H&R Sport springs with stock size tires at the moment. Plan to go to 255/275 or 265/285 tires in the near future. Turner wanted to sell me 12mm spacers, but I'm pretty sure that'll rub with with either of those tires and my ride height.
Anyone with 10mm front or rear have this issue? Which brand spacers were you using?
Thanks in advance!
-Dave
      05-23-2016, 05:38 PM   #5
arvinz
arvinz's Avatar
325
Drives: BMW 1M VO
I just installed my Macht Schnell spacers this weekend and I'm running stock tire size on Michelin PSS with 12mm front and 10mm back on stock suspect suspension. I am rubbing at the front ever so slightly at almost full lock. I usually notice it when I'm backing out of my driveway that's on a slight vertical incline.
I don't have the revised fender liners so hoping to get those soon and replace the current ones.
      05-23-2016, 06:21 PM   #6
Cursed1
14
Drives: Lots of them
Can you post a picture of your setup with the spacers installed?
Thanks,
Adam
      05-23-2016, 09:06 PM   #7
arvinz
arvinz's Avatar
325
Drives: BMW 1M VO
Thanks,
Adam
Here are some pics. First two are before and after. In the last two I tried to get a decent shot of the slight rub on the fender liners.
https://goo.gl/photos/t1hGMgTGgqSYGuNS7
https://goo.gl/photos/UuowgsiQdbu2RLLo9
https://goo.gl/photos/zMiyA9Hv6Fw4NMJF9
https://goo.gl/photos/W3PcQdofTwULvfMJ8
https://goo.gl/photos/7QstzEyD3y2WAJyz5
https://goo.gl/photos/M1TtzDWfWLqiQqE49
      05-24-2016, 08:41 AM   #8
ALEJANDRO
17
Drives: White 1M 2012
12mm rear and 5mm front for standard set up works great for me.
      05-25-2016, 11:55 AM   #9
balloonsalesman
balloonsalesman's Avatar
48
Drives: 2011 1M BSM
Im running standard wheel/tires with H&R springs, 12mm front and 15mm rear, no rubbing
      05-25-2016, 02:52 PM   #10
robbys3m3
1941
Drives: M3's
this is good info in this thread..thanks for everyone that's posted. my car will be here Friday and ill post pics of the eibach springs with 12/15 asap.
2020 M2 CS, 2018 M3 CS, 2016 M4 GTS, 2013 M3 LRP, 2011 1M, 2011 M3 GTRS3, 2004 M3, 2002 M3, 2000 M Coupe, 2002 M5, 1997 M3, 1988 M3, 2022 STO, 2020 Urus, 2022 TRX, 2022 392, 2021 SVJ, 2018 Performante, 2013 Gallardo 550-2, 2012 Gallardo STS, 2018 R8 RWS, 2012 R8, 2017 G550 4X4^2, 2015 GT3, 2015 Continental GT3R, 1971 Bronco
      06-01-2016, 10:29 PM   #11
GimmeanM
GimmeanM's Avatar
1449
2011 BMW 1M  [10.00]
Just fitted 10mm front and rear from ECS. I'm on H&R springs and OE tire sizes. I think these look good and should give room for wider rubber.
      06-01-2016, 11:10 PM   #12
robbys3m3
1941
Drives: M3's
Looks great!
      06-03-2016, 03:33 AM   #13
wrighty
wrighty's Avatar
50
Drives: BMW 1M
Need to double check 10mm spacers seat correctly as said above they can bottom out. I want to try 12mm all round on mine.
      06-03-2016, 02:58 PM   #14
GimmeanM
GimmeanM's Avatar
1449
2011 BMW 1M  [10.00]
Exactly, That was me that mentioned that. I asked ECS for measurements of the depth of the hub bore before purchasing theirs. The measurements gave proper room and I confirmed when fitting they don't bottom out. Not all spacers are created equally, but I'm sure reputable brands have a better chance.
I measured with calipers on my car and the hub flange depth was 11.75mm.
I went with the 10mm since I'm on H&R springs and think I want to go with 265/285 tires which will hopefully still not rub. (I have the revised front fender liners as well).
      06-06-2016, 06:40 AM   #15
Shooto82
23
Drives: BMW 1m
Can someone explain me what's exactky the issue with running 10mm. I'm using Macht Schnall 10mm all around with PSS 255/275. Anything i should be worried about or to check? Had them for 4 month now .
      06-06-2016, 01:36 PM   #16
arvinz
arvinz's Avatar
325
Drives: BMW 1M VO
I have 10mm in the back and 12mm in front...haven't seen any issues yet, but I've only had them on for 3 weeks now. I am rubbing at the front a little though with stock tire sizes so I ordered the new fender liners..hoping that fixes it.
      06-06-2016, 01:52 PM   #17
GimmeanM
GimmeanM's Avatar
1449
2011 BMW 1M  [10.00]
The issue has to do with the depth of the bore for the hub flange. On some BMWs the flange is deeper (e46 for example is >12mm) which makes it hard to get the required room out of a 10mm spacer. When the bore isn't deep enough the spacer 'bottoms out' on the flange before it actually makes contact with the flat mating surface of the hub. When this happens, you torque the wheel down and it's snug against the spacer but the spacer is not flat against the hub. This obviously gets very bad when the car get driven as the wheel works it way loose as the spacer disintegrates.
On the attached pic imagine that the spacer is not flat against the mating surface of the hub because the flange is preventing it from seating all the way.
      06-11-2016, 10:01 PM   #18
Xccelerate
Back in a BMW
Xccelerate's Avatar
286
Drives: 21 X5M Comp
I have mach schnells on the rears 12MM
21' Donington on Black X5M | Comp | Exec
11' 1M Coupe Valencia 6MT OEM+ 289 of 740
1addicts
