05-18-2016, 12:16 PM | #1 |
353
Rep 440
Losing pressure
Hello all
My front tyre seems to lose 2-2.5 psi every other week Had the dealer check it out They sprayed it and found no leeks Any ideas ? |
05-18-2016, 12:39 PM | #2 |
591
Rep 710
At 2 - 2.5 ps per week, you won't find it with a leak test in water or soapy water - too slow.
The tire needs to be re-mounted and the wheel rim (where the bead meets the rim) needs to be cleaned spotless. If that doesn't do it, then the tire shop should have a bead sealant they can use. I had to have this done on my Merc.
Sold: 2014 X5 xDrive35d MSport
05-18-2016, 12:44 PM | #3 |
627
Rep 1,181
Could also be the TPMS valve stems. I've had those deteriorate over time and cause slow leaks. Easy thing to check is whether the retention nut is tight enough.
Otherwise, just have the shop install new washers and/or reseat/tighten each one when you remount the tire.
A little mod here, a little mod there...
05-18-2016, 01:01 PM | #4 |
290
Rep 1,547
Agreed on both of the above. A leak that slow could be smaller than a pin-hole. Keep us posted on updates.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
05-18-2016, 06:15 PM | #6 |
Mmmmm…
1150
Rep 2,426
Drives: F15
Could also be fractures in the rim. My friend's car leaks 2-3 psi a week, found a small crack on the inside part of the rim.
05-18-2016, 09:12 PM | #7 |
591
Rep 710
If under warranty and original tires/wheels, yes. And don't back down if you get a reply, "it's within specifications". Tell them it's a safety concern and watch them take care of it.
05-19-2016, 10:00 AM | #8 |
20
Rep 47
Have you checked the valve to see if it seated properly or leaking? The old fashioned way is some spit on your finger, wipe it across the valve (cap removed) and leave a continuous layer across the top of the valve. A slow leak will push a bubble out and break the film. Replace the valve insert if it is an issue although sometimes just giving it a sharp push in and letting it snap out will help it seat.
Every time I check pressures or add air I test the valve is seated properly before replacing the valve cap, just in case. |
