BMW X5 and X6 Forum 2014-Current
      05-12-2016, 01:44 PM   #1
X5MSD
X5MSD's Avatar
353
Drives: X3 40i M Performance
Eibach springs
Hello all
I'm thinking of lowering my car
Need some feedback from owners
How much stiffer is the ride
Body roll
How low did you go
Do you have adjust the geometry
Thank you
      05-13-2016, 04:51 PM   #2
BMW - BEKTAS
BMW - BEKTAS's Avatar
16
Drives: X5M
Hi.
I lowered mine two days ago with Eibach. It's 2cm lower. The kit came with two front springs. I don't have springs rear. I contacted BaanVelgen and they said that back should be lowered at my dealer. So had to go to my dealer and they programed rear end to be lower 2cm.
I decided to put on Eibach because of too much body roll for me. Before I drove 200km/h couple of times and the car didn't feel stabile. Now it's great. And the stiffnes is not an issue in my opinion. But I do have 20" Michelin non RFT tyres.
Hope it helps
      05-13-2016, 06:04 PM   #3
TOPEC
<3 Flat Four
217
Drives: 335is LM Blue
So u just went to the dealer n told them u need the rear to be 2 cm lower n they did it no questions asked?
I wonder if this is something that can be done with a coding cable or only with a special tool.
      05-13-2016, 07:52 PM   #4
SlammedR8
SlammedR8's Avatar
521
Drives: 2019 X5 40i/2020 R8 V10 Spyder
Same...my understanding is that you need the links to lower the rear?
Current:
2019 BMW X5 40i - Carbon Black/Tartufo Individual Leather
2020 Range Rover HSE - Black/Black
2020 Audi R8 V10 Performance Spyder 6MT - Ascari Blue/Black
      05-13-2016, 09:23 PM   #5
TOPEC
<3 Flat Four
217
He said the dealer "programmed" it so I assume he has air suspension in the rear. And since technically the rear air suspension self levels then it should be doable with a computer to adjust the static height... But what tools to use.
      05-13-2016, 10:46 PM   #6
BMW - BEKTAS
16
Drives: X5M
Hi.
Yes I have air suspension at rear. No issue with dealer for doing that. I paid for programming. The front springs were installed at home. Asked for links at BaanVelgen and they answered I should go to my dealer.
The ride is great. Not to stiff and more stabile when cornering.
      05-14-2016, 03:28 AM   #7
X5MSD
X5MSD's Avatar
353
I think I have air suspension, I have a 3rd row
So it's just the fronts
Thanks for your input
      05-19-2017, 01:54 PM   #8
F15Fan
28
Drives: X5
any pics
      05-19-2017, 05:51 PM   #9
///Monkeyballs
33
Drives: E36,E46,F15,F86
hello,i got my lower with H&R 1.3 all around,if you car have air bag at the rear the springs kits should come with 2 front springs and 2 rear links that u can adjust it.
      05-19-2017, 06:14 PM   #10
///Monkeyballs
33
x5 photo spring kit
x5 photos
      05-28-2017, 06:44 PM   #11
Installsplus
Ultimate Driving Machine E92ESS625 M3/G05 X5 Msport 40i Individual
Installsplus's Avatar
459
Drives: 2011 E92 M3 DCT/ESS 625 kit
I also went with eibach and absolutely love the ride. Less body roll in comfort mode and even better in sport. I also have a set of H&R springs for vehicles equipped with rear adaptive suspension if anyone is interested.
"The Ultimate Driving Machine"
2011 E92 M3 supercharged ESS 625
2016 F15 X5 Msport 35i
      05-28-2017, 11:28 PM   #12
F15Fan
28
Drives: X5
which one of these options gives a less raked appearance? I have seen some h&r where the car looks super raked. I want a stance similar to the x5m...
      05-28-2017, 11:53 PM   #13
r33_RGSport
r33_RGSport's Avatar
12971
Drives: G09 XM, G05 X5 40, 991.2 T
The Eibach or AC Schnitzer will give you the same look as the X5M.
Do you have self-leveling rear suspension or not?
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      05-29-2017, 09:15 AM   #14
F15Fan
28
Drives: X5
I do have the self leveling (50 with 3rd row) - do I need links or will the reprogram work?
      05-29-2017, 09:48 AM   #15
r33_RGSport
12971
You will need links for the rear.
The kit of the spring will comes with the links set.
Unfortunately though, Eibach USA didn't bring in the set for self-leveling suspension.
So your only option will be AC Schnitzer spring.
      05-29-2017, 04:12 PM   #16
stewy604
stewy604's Avatar
290
Drives: 2014 BMW X5 xDrive 35d M Sport
You can set the rake however you like it, since the rear links are adjustable and really just "trick" the vehicle into its ride height for the rear.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey
2007 Suzuki GSX-R 750
xbimmers
