TireRack
      05-03-2016, 12:30 PM   #1
bmwannabe
Drives: 2011 X5 35i MSport
2011 X5 MSport - Lighting Woes
Hi everyone
New to E70 but long time BMW owner. Recently picked up a 2011 35i MSport and it needed a driver's side DRL Lamp replacement due to" Daytime running light/parking lamp" malfunction warning.
My mechanic replaced the H8 bulb for the DRL and reset the Counters but they came back immediately. He tells me i need a brand new Footwell ( FRM ) module + 3 hours of coding to get it working ( $1000 CAD ) - all this for a DRL?
I've done quite a bit of research on this and found links for resetting the counters myself. Also bought the K+DCAN cables needed as I see myself tinkering with this car in the future.
I'm not entirely sure it's the FRM module although im being told its a common issue. but when it happens it usually affects a lot of other components ( Windows, etc.. ) and not just a single lamp.
Apparently you can also get a used FRM module and with the right tools you can re-code the VIN number to match your car and save a few bucks versus going new.
I'm also not sure if it's the FRM or perhaps even a bad lighting module or harness
Any advice would be appreciated on how to go about debugging this.
TIA
      05-03-2016, 03:29 PM   #2
heatmizr
153
Drives: E70 X5 50i M-Sport
Ugh. All for DRL, which I despise. I leave mine off. Are they required in Canada?
Sorry nothing more helpful!
heatmizr [Todd]
g26 i4 e40 - Clean Machine
e70 X5 50i M-Sport "The Boss" Loaded
e90 328i - sold
e36 M3 - Gone to become a track star
      05-03-2016, 03:53 PM   #3
bmwannabe
Yes they're required in Canada - to pass "Safety". Technically I could pull the other bulb so it doesn't look like I only have 1 set of Halos on. but I'd like to fix it if at all possible.
      05-03-2016, 06:39 PM   #4
blue dragon
1192
Drives: '22 Tesla MY + '23 Tesla MY
FRM controls all the lighting, if there are repeated shorts, it will disable the circuit. You need Tool 32 to reset the counters.
A new FRM3 is about 300 US, not sure where you are getting 1k CAD.
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
      05-03-2016, 08:36 PM   #5
bmwannabe
He told me the FRM was $700 CAD - then I checked online I can get it for $320 USD through Tischer. He also said it's a "Lot " of programming work to do the swap - but this is something I would be willing to do myself once my cables arrive
I asked if he reset the counters and he said he did after replacing the bulb, but the code came right back which is why he thinks it's a problem with FRM. He tells me it's a common occurrence on these cars
      05-04-2016, 06:18 AM   #6
blue dragon
1192
Having swapped my FRM2 for an FRM3 when I did my LCI headlight retro, your guy is feeding you lot of baloney.
Here is how I wrote the vin, and then coded the FRM3. In my case I had to change the date since I wanted the FRM to power the corona rings, you will not have to change the date
http://www.xoutpost.com/1006224-post90.html
Tags
drl, footwell module, frm, lighting, ncsexpert
xbimmers
