05-03-2016, 07:37 AM | #1 |
206
Rep 650
Rubbing/grinding while turning tightly.
My car was parked for the winter. I took it out early March and replaced my 220s with AG 359s with a slightly more aggressive offset.
I started noticing that when I turn tightly at slow speed (like in a parking lot) I get a rubbing or muffled grinding noise seemingly coming from the rear of the car. It seems to be happening on both left and right turns. The weird thing is I try to repeat the noise after I have just heard it by completing the same turn, but the noise isn't there anymore, making it very difficult to duplicate the problem. Mind you, the noise keeps happening randomly,yet on a daily basis. That noise wasn't there last year. Before I bring it in, id really like to have an idea of what the problem could be, and furthermore, be able to replicate the issue... Could it have anything to do with the new offset wheels? I wouldn't think so, because we're talking about less that 10mm either side, but it's the only real change between last year and this year.... Thoughts are most welcome. Thanks
Today's gains far outweigh tomorrow's losses.
05-03-2016, 07:47 AM | #2 |
506
Rep 1,385
have you recently changed your diff fluid?
2011 E90m3 ESS G2, active auto x pipe, RK FULL E85, DD
2015 X5M Bootmod3, Downpipes, Mineral white-The wifes DD 1994 300zx 2jz Swapped slicktop- The toy/track car |
05-03-2016, 07:52 AM | #3 |
206
Rep 650
I had it changed early last year by the dealer. But later in the year, the drive shaft differential seal was replaced due to a small leak. I assume they refilled the diff after the repair. There was no noise after the fix that I can remember.
My first thought was diff fluid, but with what I just wrote above, plus the fact I can't immediately duplicate the problem, it made me wonder if it could be something else.
05-03-2016, 07:56 AM | #4 |
287
Rep 562
If there is no physical rubbing from the new tires (inspect for rub marks), it's likely the differential. The noise is normal, but if you do not like it, you can have an additive put in there that will make it go away. It decreases the friction in the LSD.
05-03-2016, 08:37 AM | #6 |
184
Rep 656
I would not suspect the 359's to rub in the rear... Mine don't rub in the rear and I have spacers in the front... Probably time to do a diff fluid change to the special BMW formula or redline's formula...
05-03-2016, 09:10 AM | #10 | |
206
Rep 650
05-03-2016, 09:53 AM | #11 | |
376
Rep 2,526
05-03-2016, 09:57 AM | #12 | ||
206
Rep 650
I'll try and listen from the outside, that's a good idea.
05-04-2016, 02:34 PM | #13 |
4467
Rep 7,111
The diff grind in a way I don't think you'd confuse with tire rubbing. Mine grind a tad every morning first turns just to go away after started to warm up. Makes me feel good as I know it works (changes fluid 14month ago).
Grind continue also after car warmed up? Last edited by Helmsman; 05-04-2016 at 03:29 PM.. |
06-19-2016, 05:33 AM | #15 |
206
Rep 650
It's still there. I'm assuming it's the differential as everyone points out...
I hear it once in a while, nothing seems broken on the car...
06-20-2016, 11:49 AM | #16 |
198
Rep 466
Records from the previous owner of my car show the same symptoms. BMW replaced diff fluid of a different viscosity and solved the problem.
06-20-2016, 01:05 PM | #17 |
Supreme Czar
309
Rep 779
06-20-2016, 09:24 PM | #18 |
27
Rep 162
BMW Service bulletin: SI B33 01 02
http://www.m3post.com/forums/attachm...2&d=1322027419 |
