TireRack
      04-29-2016, 09:21 AM   #1
kydiesel35
kydiesel35's Avatar
166
Drives: 2016 X5 35d
2011 BMW 335d  [0.00]
Hey all. I started a thread on the 335d side for a possible aftermarket fix on our dreaded harmonic dampener wear problem. If we can get enough interest Fluidampr will engineer a lifetime fix! Here is the link for anyone interested.
Harmonic Balancer Pulley Fluidampr http://www.e90post.com/forums/showthread.php?t=1255658
Ask me your questions, we need a minimum of 50 people interested for them to begin design and production. Thanks guys!!!
*Update*
Fluidampr release soon...
https://docs.google.com/forms/d/e/1F...=0&w=1
      04-29-2016, 10:44 AM   #2
smass
398
Drives: 06 325i - 10 335i
2010 E90 335i  [0.00]
2016 F15 35i  [0.00]
2003 E53 3.0  [0.00]
2006 E90 325i  [0.00]
Does the E70 have the same issue as the E90?
      04-29-2016, 03:15 PM   #3
kydiesel35
kydiesel35's Avatar
166
Drives: 2016 X5 35d
I would say. The engine is very similar to the one found in 335d just small changes. It seems like the oem balancers are dying around 60k for our 335; but we are also upgrading the turbos and running extra fuel... So that being said IMO if you are stock and under warranty you probably wont need it. But if you are out of warranty and would like to keep the sav around most likely this part will fail in the near future with no warning... These fluidampr are rated to be good over 500k, solid performer as well. Oem dampeners are in the $600 range, we may be able to get a much better product a little less that this price... Hope this helps, thanks.
      04-29-2016, 05:11 PM   #4
mitch808
107
Drives: 2012 X5 35i
In general, the Fluidampers, even though often HEAVIER than stock, actually make the car produce more power (Or perhaps I should phrase it, free up power?)
Those parts if made for our cars, are a very legit piece of gear. Never thought of when compared to a fancy exhaust or tune. But still a solid part to install.
      05-02-2016, 02:18 PM   #5
smyles
1023
Drives: '21 X5
Original is heavy enough (~15 lb if I'm not mistaken), not sure I'd like an even heavier one.
And btw, OEM (Corteco) can be found under $400.
      05-02-2016, 11:16 PM   #6
mitch808
107
Drives: 2012 X5 35i
It's not the weight, but the engineering that goes into it. It's actually a better product than stock, even if heavier.
As seen here:
http://www.motoiq.com/MagazineArticl...velopment.aspx
http://www.motoiq.com/MagazineArticl...dent-Test.aspx
      05-03-2016, 01:26 PM   #7
smyles
1023
Drives: '21 X5
In your link they compare a ~5lb pulley vs <2lb OEM on a rather small 4 cyl engine. I doubt in a M57 application there will be any difference worth mentioning. Just my guess.
But if at comparable price it lasts 3 times the BMW unit, that's enough by itself.
      05-05-2016, 09:26 AM   #8
daltonnnn
Driver
daltonnnn's Avatar
17
Drives: F80 M3, MSM, Clubman S
How do you know when it fails? Vibration from the engine bay?
** Go Navy! **Go SF 49ers!!!** Go SF Giants!!! Go Warriors!!!!!**
      05-06-2016, 03:47 PM   #9
smyles
1023
Drives: '21 X5
Squeaks/screeching sound, intermittent loss of power steering/battery charge, mayhem once it completely splits apart and rips everything in front...
      05-10-2016, 11:43 AM   #10
007_e350
007_e350's Avatar
217
Drives: 335i 2008 MHD'd / x5d E70
count me in
Mods: 7" VRSF FMIC, Forge DVs, RB PCV, BMS Oil Cooler, VRSF DPs, MHD, JB4g5, OFT DIYs: Walnut blasting : Trans Oil at 45k, w Filter at 65k : Diff Oil Flush @ 45k : WP&TS @ 69k : Alternator @ 79k --- E70d Alphabet Soup del 44.4k : JR Stg2.25 tune : Buzzken Catted Exhaust : Trans fluid drain/ fill (3 Qrts), both Diffs fluids flushed Wheels: Style 95s on PSSs (Sold): AG 359s on S04s : 162s on Blizzaks : Rohana RF1 Matt black
      11-29-2016, 12:34 PM   #11
kydiesel35
kydiesel35's Avatar
166
Drives: 2016 X5 35d
Bump.
xbimmers
