04-26-2016, 09:21 PM | #3 |
2383
Rep 3,729
Drives: 2018 M2
Neutral with E brake
04-26-2016, 09:34 PM | #5 |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Always leave the car running for a faster getaway.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
04-27-2016, 12:53 AM | #10 |
25
Rep 217
04-27-2016, 01:25 AM | #11 |
369
Rep 1,887
Drives: '20 M5C, '09 M3 DCT Coupe
+2 There is no point putting it in neutral. Once you shut the engine off neither clutch is any longer engaged anyway. I don't bother with the e-brake unless I am parking someplace that isn't flat. So, in my garage for instance, I just come to a stop and push the button to shut down the engine. That's all.
M5C 20% tint, Xpel full front, partial sides and rear. Spacers, 15mm front, 12mm rear. Turner Motorsport Oil Cooler Guard.
M3: Active Autowerke filter, Dinan underdrive pulley, Dinan full exhaust and software, 3.45 Differential, Springs, Brakes, Dinan/HRE wheels, 275/30-19 w/10mm spacer, 295/30-19 w/3mm spacer, painted front reflectors, 30% tint, Escort 8500i & Lidar Jammer, LUX H8 V5 halos, Euro rear foglights, 3M ClearBra. |
04-27-2016, 02:42 AM | #12 |
94
Rep 298
I always use the handbrake in case the transmission parking lock should fail.
“Automatic Parking Lock This is the first time that an integrated automatic parking lock has been used in an M vehicle. When the engine is turned off, there is no mechanical connection between engine and drive wheels (clutches are at zero pressure and disengaged). There is no parking lock button on the selector lever of the M GWS. The parking lock position is determined by the M DCT electronics. The parking lock is engaged with the use of a parking lock electromagnet. This electromagnet is built into the gear selector switch housing and is activated directly by the M DCT electronics. It transfers its movement (stroke) to a Bowden cable. The parking lock Bowden cable transfers the movement directly to the external parking lock lever on the transmission and then to the inner parking lock lever. The parking lock disengages hydraulically in the transmission. To engage the parking lock using the electromagnet, the parking lock hydraulic components must be at zero pressure. The parking lock will always be automatically engaged once the engine has been turned off, except in "N". When in "N" the parking lock is engaged: • when vehicle remote control is not in the ignition lock (Comfort Access) • when removing the remote control from the ignition lock • 30 minutes after the engine has been turned off. Note: At the carwash, before stopping the engine you must deliberately shift to "N" and leave the transmitter in the ignition lock. (With Comfort Access it must remain in the car or be inserted in the ignition lock). Emergency Release of Parking Lock In an emergency, the parking lock can be released by operating the emergency release mechanism. This is achieved releasing the mechanical connection between the GWS and M DCT. (See “Service Information”) If the parking lock is released the vehicle may roll. Note: The emergency release is described in detail in the Owner's Manual for the vehicle and in the Repair Instructions.” |
