04-26-2016, 07:42 PM | #1 |
Rep 1
Headed to buy an M3 this weekend! (hopefully)
Hey guys,
I've been a long time lurker around these forums. I've been using the e90post forums to help me through my woes for a long time and now I am hoping to take advantage of the m3 forums! I am headed out to look at a 2009 E92 (white for those that care :P) with about 50K miles on it. I was wondering, are there any specific E92 issues that I should 100% be looking for up front? I am familiar with buying cars in general, but just wanted some of the M3-specific insider knowledge. Thank you! |
04-26-2016, 08:21 PM | #3 |
2383
Rep 3,726
Drives: 2018 M2
Take it apart and check out the rod bearings. While your in there check the throttle actuators, idle control valve, DCT oil pan if applicable, oil leaks,M perm exhaust cracks if applicable. You know the usual CRONIC problems that cars tend to have
I know I'm forgetting more |
04-26-2016, 08:23 PM | #4 |
5234
Rep 10,616
None you can determine from a test drive or inspection. Throttle actuators are an eventuality. $800 each (2) and 3 hours labor. Rod bearings are a possibility and an unknown and the only way to know is to inspect and to get in there you have done the labor to change them so you should -- $500 to $1000 parts and 8-16 hours labor. All fluids on a 7 year old car should be changed but probably have not --$500. BMW does minimal maintenance.
04-27-2016, 08:39 AM | #5 |
376
Rep 2,526
You state E92-specific issues...as opposed to E90? Forgive me if I'm reading too far into your lines, but the only E92-specific issue I've heard is the weather lining along the top of the driver's and passenger's window. It tends to crack and/or become rough, allowing air to leak through and make a whistling sound when driving at freeway speeds. Try treating it with a rubber/vinyl restorer first before deciding to replace them. Each side is around $100 for new lining if I remember correctly.
04-27-2016, 08:45 AM | #6 | |
469
Rep 1,320
04-27-2016, 05:47 PM | #7 | |
52
Rep 263
R3DVelvetM3
04-27-2016, 06:20 PM | #8 |
4985
Rep 11,891
wait, rod bearings is an issue? I had no idea.
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
04-27-2016, 08:44 PM | #10 | |
81
Rep 734
Do your due diligence, do a PPI as suggested. Have some spare money aside for fixes, maintenance, and mods. Couple that comes to mind is Throttle Body Actuators (tend to fail around the 50k-70k mark). These babies are $1k a pop, the S65 engine in the e9x M3 takes 2 of them. Some mentioned Rod Bearings, if you wish to do it as preventative maintenance, shouldn't run you too much either (<$3000). Expect to do all major maintenance too (spark plugs, battery, brake rotors and pads, oil, coolant, brake flush, tranny + diff fluid, power steering fluid etc etc) Most of these parts will have a M tax on it so expect to pay 20-50% more than your regular 3 series. Cheers!
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
04-27-2016, 09:03 PM | #11 |
875
Rep 611
Drives: 2013 M3 coupe' 6mt
Be sure the break in service was done at 1200 miles. Engine, trans, rear end. With a known rod bearing issue this first service is critical.
And the 37500 service that many dealers don't do because the obc says its too early. And IMO only buy a car with mods from a private party.
memories: '71 2002 (new), '72 Bavaria, '74 2002tii, '00 540i Sport |
04-28-2016, 08:52 AM | #12 | |
Pingu
237
Rep 484
04-28-2016, 08:56 AM | #13 | |
Supreme Czar
309
Rep 779
04-28-2016, 01:01 PM | #15 |
935
Rep 1,930
If you are in the market and if you are looking at the car yourself w/o a PPI, I suggest you get the carly for bmw app. It will tell you if the car has any ghost codes you might not know about.
04-28-2016, 01:24 PM | #16 |
2383
Rep 3,726
Drives: 2018 M2
How much is a PPI? Cuz a Carly app plus dongle will be over $100 and be useless if he decided to not buy A BMW
04-28-2016, 01:30 PM | #17 |
514
Rep 3,482
The one where you put clown midget tears in the diff, trans and engine to keep things lubricated. It also just happens to be my go to, multi purpose lube.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
04-28-2016, 01:36 PM | #18 |
514
Rep 3,482
PPI for my E46 was 125 in 2009.
BMWCCA:518970 |
04-28-2016, 01:52 PM | #19 | |
968
Rep 1,612
There was one person up in San Francisco that knew about clown midget hookers but those were only in the trunk and they were self-lubricating... |
04-28-2016, 01:59 PM | #20 | |
3274
Rep 6,723
OP I'd hit up Tim P via PM and ask for a VIN check. He can send you a service report. I paypal'd him some money for his trouble. |
04-28-2016, 03:14 PM | #21 | |
2383
Rep 3,726
Drives: 2018 M2
