04-25-2016, 08:25 AM | #1 |
Rep 40
Weird e92 M3 6MT issue encountered today
Some things to explain the car...
2008 e92 M3 6MT with 56k miles I was sitting in the driveway this morning and was in a bit of a rush, so I hopped in my car and started it up with the clutch depressed, after about 5-10 seconds with the clutch still depressed I put the car into reverse and suddenly the clutch pedal went limp (very little to no force pushing back on my foot) and the car started to progress backwards. My foot never left left the clutch and was depressed since I started the car. My foot was still slightly pressing the brake as I was getting ready to move over to the gas to start backing up. The only way that I can describe this was it was as if someone unhooked my clutch cable in that instant and eased it out, this was by no means a rough instant (clutch cable did not snap or anything) it just eased off of it until it was completely engaged as my foot had the clutch pedal pushed all of the way down. Since it was clear the clutch was not working I pressed the brake harder to stall my car and when I restarted it the problem was gone and it drove like normal for the rest of my commute. If anyone has experienced this or have heard of this happening/knows why it happened please let me know. Thanks |
04-25-2016, 10:30 AM | #3 |
550
Rep 1,148
Drives: 2008 BMW M3 Coupe
Garage List 2015 Jaguar XJ [0.00]
2015 Jaguar XF [0.00] 2014 VW GTI [0.00] 2008 BMW M3 Coupe [0.00] 2007 VW Passat 2.0T [0.00] |
04-25-2016, 10:34 AM | #4 |
Stop the hate, get a V8
3851
Rep 8,625
Agreed, visually inspect and make sure you have no leaks, then change the fluid and bleed the system.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
04-26-2016, 09:18 AM | #6 |
15
Rep 75
04-26-2016, 09:59 AM | #7 |
541
Rep 979
When my clutch wore out the same sort of thing happened to me. You might need a new clutch. With that mileage and age, its about time. Get prepared as you will also need to replace the flywheel as they no longer make the 2008 version.
Harrop Supercharger, BPM Tune, K/W Coil over kit, Stoptek BBK, Magnaflow exhaust, ear to ear grin everytime I drive... |
04-26-2016, 11:48 AM | #8 | |
86
Rep 541
Clutch is pretty young and shouldn't need replacing so soon, unless it's had a lot of wear/abuse with stop/start/launch history. I've had BMW clutches in all M generations go twice as far as yours. When you are driving in the car now, be very aware of any actions/responsiveness/"feel" for shifting, engagement, etc. This is for your safety as well as diagnosis. Last edited by hlmiii; 04-26-2016 at 11:57 AM.. |
04-26-2016, 09:08 PM | #9 |
103
Rep 251
I had this happen once - about a week after changing brake fluid with a power bleeder. It worked fine for a few days and then did almost exactly the same thing to me. I checked everything, didn't find anything obviously wrong and when I tried again it worked normal. It's worked fine since, although I started it in neutral for several weeks after out of caution. I wrote it off to getting a bubble of air somewhere it wasn't supposed to be.
