04-23-2016, 07:41 AM | #1 |
12
Rep 16
2008 M3 Bearings
I am the 3rd owner of this car and it had been a CPO car. The car has right at 100k on the clock. I bought it with about 95k on it. I was getting ready to purchase a supercharger for it when the ESS Tuning mentioned something about the bearings..... this brings me to you all and new to this forum.... lots of searches and a few calls and ended up with BE Bearings and new ARP 2000 bolts.
I bought the car back in Dec and have been pretty much going through the entire car just to make sure it will last another 100k... Changed every fluid - tranny fluid actually seemed pretty good coming out... Diff fluid... wasn't great - noticed a difference in sound after the change, so that was good. Replaced the water pump... went back to BMW OE on that. Then did an overall inspection... all in all not a bad car. the paint on the nose and hood needs to be redone... lots of little chips. I t was a NJ car so I can imagine a lot of highway sand and salt rock impacts. Anyway - with all that done I decided to pull the bearings... I had 2500 since my last oil change, so I took a sample to baseline the bearings.. I had a track day (SCCA Solo 2) in there so it should be a good baseline. I wasn't really sure what to expect, but I decided not to drop the entire suspension, but rather do the "hang" method. It took me right a 3 hours to get to the bearings... about 8.5 hours to get to engine start and oil level checks. The car still needs to have under car panels put back on..but I wasn't going to be able to sleep if I didn't at least hear the car run. I started right up...warmed up, no noises, rev'd it up and back to 7500 RPM... nothing..but no load, so we will see what today brings but I would have expected it blow up already if I messed something up. The rod side bearings or tops were pretty much toast. The cap side looked fine. Crank was fine. The wear looked pretty typical to all the pictures here on the forum. I had no indication that there was an issue. anyway here are some pictures... I will post some more after I clean up and test drive later today. |
04-23-2016, 08:02 AM | #2 |
420
Rep 1,678
Drives: 2011 MCB E92 M3
Good thing you did them. Might also want to replace those motor mounts if they are worn.
2011 Monte Carlo Blue E92 ///M3 - ESS VT2-625
04-23-2016, 08:04 AM | #3 |
63360
Rep 24,668
Congrats and welcome .
Looks like caught on time ...Good job
"MAX VERSTAPPEN" IS THE 2021+2022+2023 F1 WORLD CHAMPION - #UnLeashTheLion
BPM DEV-Tune & DCT Software-Tune & Servotronic & coding ///Alpine HID Angeleyes ///Oem.exhaust mod. |
04-23-2016, 04:00 PM | #10 |
12
Rep 16
04-25-2016, 06:26 PM | #12 |
12
Rep 16
ok well first really day driving around, back and forth to work, out to lunch and generally driving the living dog crap out of it...I have to say the engine is noticeably smoother and MPG is up. It is running a little warmer on oil temp, but I added MOA and the oil is brand new... so I suppose that is expected... it does seems to cycle a lot more now from just at 210 then go back down...so more movement on the gauge than before....
what are you all using to measure oil pressure with. Do they make an OBD II oil pressure gauge? |
04-25-2016, 06:57 PM | #13 | |
324
Rep 488
Drives: 2011 E90 M3 6MT
04-25-2016, 10:54 PM | #14 |
Retired Curmudgeon
2985
Rep 4,047
Interesting info on the temps.
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
04-26-2016, 08:40 AM | #16 |
5234
Rep 10,616
Are you running the same oil as before? Did you replace the oil pump pickup orings if you disturbed them (not sure replacement needed but I replaced).
04-26-2016, 10:51 AM | #17 |
196
Rep 386
04-26-2016, 12:36 PM | #18 |
12
Rep 16
umm... NO! That comment was about the motor mounts not the bearings! I reused the O-rings on the oil supply tubes - they were super tight coming out and going back in (surprisingly)
The BE Bearings are apparently engineered to use the same 10W60 oil... as I understand it... so I am running the same oil.... I sent the oil I pulled out of the car to the lab, and will run it for about 2000 miles, dump the oil ... hopefully all the crap and contaminates from the old bearings is in the filter.... Then I will run a good 2500 miles on that and resample.... Hopefully be ready to add supercharger by the end of the summer.... if all goes as planned |
04-26-2016, 01:23 PM | #19 | |
196
Rep 386
04-26-2016, 01:46 PM | #21 |
12
Rep 16
Yeah. Thanks...I like it I went with ARP 2000 bolts..can't go wrong with those... I also use 3 torque wrenches... 1st one to do 2 passes at 30 and 40 lbs...second one for 50 lbs final ... 3rd wrench set at 50 as a validation check...over kill....but my OCD won't leave it alone....lol
04-26-2016, 02:09 PM | #22 | |
196
Rep 386
Where'd you get the ARP 2000s? Only place I have seen them available is with the VAC bearing kit. |
