04-19-2016, 09:45 PM | #2 |
11586
Rep 12,728
its a thing you have to do so the car recognizes the battery. not sure why the car actually needs it, but it does.
Instagram; @roastbeefmike
04-19-2016, 09:50 PM | #3 |
594
Rep 4,488
It's called battery registration, not a battery registry, but as roastbeef said, it's important to do. There's an official detailed explanation as to what exactly it does, but basically the car's electronics adapt their operation based on how old they know that the battery is, so when you replace it, you have to register it so those components change their operation accordingly to take advantage of a fresh battery. My wife's Mini once wouldn't close the sunroof properly when the engine wasn't running, which was a symptom of a weak battery. Replaced the battery and no change. Registered that battery, and presto it started working correctly. So while it's not the case that your car won't be able to use a new battery at all until it's registered, it might not work quite right until it is.
'16 Cayman GT4 (delivery pics, comparison to E92 M3 write-up)
Gone but not forgotten: '11.75 M3 E92 Le Mans | Black Nov w/ Alum | 6MT (owned 5/2011 - 11/2015) |
04-19-2016, 10:09 PM | #4 |
Rep 46
I just got my battery replaced (2011 E92) last week and the car needed 4+ hours with the new battery (after it was registered) to re-learn the systems - error codes, comfort access, etc.
04-19-2016, 10:25 PM | #6 | |
594
Rep 4,488
04-20-2016, 03:53 PM | #7 |
Woof!
352
Rep 1,323
Drives: '11 M3 ZCP LeMans Blue
It has to do with the so-called "smart" charging system (which allows the alternator to charge the battery as required at times when it is most efficient to do so). The age and past history of the battery is taken into consideration to determine max charging rates, priority to charge Vs. conserving alternator load, and other considerations. There are times when BMW goes overboard on snazzy features and I'm sure many would prefer an old-fashioned "dumb" charging system without the added complexity and cost. IMO, a truly smart charging system should be able to figure out the state of health of the battery in the act of charging it and monitoring voltage rise, as many intelligent chargers do these days for maintaining R/C hobby battery packs. If BMW had finished the firmware for its charge management, they could have made "battery registration" unnecessary-- or at worst requiring a user operable Reset command from the I-Drive (especially given a new battery installation with the same amp-hour capacity).
04-20-2016, 04:27 PM | #8 | |
Track Whore
542
Rep 1,640
From the internetz:
04-21-2016, 06:09 PM | #10 | |
594
Rep 4,488
04-21-2016, 08:36 PM | #11 | ||
376
Rep 2,526
