TireRack
      04-18-2016, 01:45 PM   #1
cbakking
15
Drives: E70-X5M
X5M Steam after carwash from front bumper driver-side
for X5M, is this normal? saw steam coming out after getting car washed but the weird thing is only from driver-side below headlight not the other side, I'm seeing some sort of radiator on both sides.... worry if driver-side radiator thing is getting over heated for some reason?
Attached photo where steam is coming out after carwash.
      04-18-2016, 01:59 PM   #2
X-static
Drives: 2011 X5M Melbourne Red
Intercooler, they work like radiators for the turbos, so contact with cold water could produce steam. If it continues or is excessive, then you probably have a loose clamp.
      04-18-2016, 03:18 PM   #3
cbakking
15
Drives: E70-X5M
Ok, that make sense carwash (cold water) contacting radiator but shouldn't it for both side? or Passenger side one is for something else (not turbo cooling?)
      04-18-2016, 03:49 PM   #4
X Driver
X Driver's Avatar
Switzerland
70
Drives: X5M Black Fire Edition
One side (driver side) is auxiliary engine water radiator and other side is oil cooler..
Intercooler is in the middle..
      04-19-2016, 03:43 PM   #5
cbakking
15
Drives: E70-X5M
Thanks for the info!!! didn't know right and left side served different cooling.
xbimmers
