04-14-2016, 10:45 AM | #1 |
11
Rep 26
ECU Tuning Options
I can't find a concise thread about this, so I thought I would start one and hopefully people will chime in with information. I assume because the platform is relatively new, and most owners aren't interested in modifying this car, there isn't going to be a lot of real world experience on this. From searching the forums, it appears the following options are currently available:
RaceChip Active Autowerke Velos Dinan ESS Are there any material differences between these options besides price? The M5 folks seem to be very big on the JB4 tune from Burger Motorsports. I assume they make a tune for the X5M, but have e-mailed them to confirm. RaceChip seems to be the most talked about on here, but it also appears to be the least expensive. |
04-14-2016, 10:55 AM | #2 |
3619
Rep 4,532
04-14-2016, 11:15 AM | #3 |
3619
Rep 4,532
No magic in piggybacks. A few things to think about:
1. Fuel, air, spark. That's all it takes to make power. 2. Pump gas will only support a limited amount of No. 1 3. Piggybacks "generally " alter air and the DME adjusts the fuel and spark to match. 4. How the air transition is handled effects how smoothly the power is added and how well the part throttle "feels". Herky Jerky or stock plus. 5. Module and harness quality 6. Bypass options for peace of mind. 7. All can add air (boost) all can make more power all are limited by octane. Good luck. |
04-14-2016, 11:44 AM | #4 |
3619
Rep 4,532
http://f15.bimmerpost.com/forums/att...1&d=1458945550
Install for RaceChip and similar BMS, Velos, etc. |
04-14-2016, 11:44 AM | #5 |
3619
Rep 4,532
04-14-2016, 12:09 PM | #6 |
12984
Rep 18,723
Here is my rule of thumb.
If you want a simple power bump, I do suggest the simple piggy back like RaceChip, Velos, ActiveAutowerke. They all work the same. I don't think the extra connector to monitor the RPM does much on Velos and ActiveAutowerke piggy back tunes. If you want something simple with the warranty coverage, I suggest the Dinan. But, once you are going full blown modding, I do suggest at the very minimum bench flash tune or full on custom tune where they tune the car on the dyno. Otherwise, don't bother with BMS where it still a piggy back with capability to change the variables.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
04-14-2016, 01:37 PM | #7 |
11
Rep 26
Thank you. Is there a reason there is so much price variation among the piggy back units? RaceChip is around $650, AA $1,000, BMS $1,000, Velos $2,000, Dinan $3,000.
Dinan comes with the warranty, hence the premium, but the rest seem to run the gamut for essentially the same thing? |
04-14-2016, 01:52 PM | #8 | |
3619
Rep 4,532
04-14-2016, 09:51 PM | #9 | |
12984
Rep 18,723
Some customer with Supercars will not buy a muffler tagged at couple thousand. I have sold a muffler for Aventador which is just a bent pipe welded together, and it cost $15k. Some Taiwanese company copied it and price tag it at $2000. Guess what, they still buying the $15k. But in BMS case, for over the shelves components, it is marked up way too much IMO.
04-15-2016, 11:39 AM | #11 | |
71
Rep 234
04-16-2016, 10:40 AM | #12 |
3619
Rep 4,532
I hate to keep commenting as I highly value other opinions and hope they keep coming.
I have installed and Vbox tested BMS, RaceChip and Dinan on 3 different engines. They all work. Dinan : Very high quality, smooth power transition, expensive. Works well. Still on the car. Not adjustable. No easy bypass. BMS : Works. Reasonable price. No easy bypass. Adjustable. RaceChip : Very high quality. Smooth power transition. Reasonable price. Adjustable. Works well. Still on the car. Very easy bypass. Last edited by onfireX5; 04-16-2016 at 01:59 PM.. |
04-17-2016, 11:08 PM | #13 | |
23
Rep 71
04-18-2016, 12:25 AM | #14 | |
166
Rep 710
Cars: 2016 BMW X5M. 2017 BMW X1.
Bikes: 2007 BMW F650GS. 2014 BMW K1600GTL Exclusive. 2014 BMW HP4 Competition. 2016 BMW K1300S. |
04-18-2016, 04:58 AM | #15 | |
118
Rep 455
2016 X5 M - Sapphire Black/Aragon Brown, IND Black front/side grilles/side markers 2014 C63, Klassen M52Rs, Eurocharged tune - Gone |
04-18-2016, 06:02 AM | #16 | ||
23
Rep 71
04-18-2016, 06:03 AM | #17 | ||
23
Rep 71
04-18-2016, 07:42 AM | #18 |
3619
Rep 4,532
You can turn off the effects of Dinan and BMS but it does not bypass the module if the module fails. Not a big deal, but I wanted to be able to bypass easily in case of a failure. Failures are very rare but have happened. IMHO they all should come with a simple bypass plug. Internal chip melts, car starts missing just pull over and back to stock in 30 seconds.
04-18-2016, 07:45 AM | #19 | |
23
Rep 71
04-18-2016, 08:05 AM | #20 |
11
Rep 26
Does the racechip impact any of the steering wheel controls or bluetooth functions? I guess more simply put, is there anything the car can't do after installing a racechip piggy back module that it could do before?
04-18-2016, 08:15 AM | #21 | |
3619
Rep 4,532
04-18-2016, 08:16 AM | #22 |
3619
Rep 4,532
Racechip does not effect any controls. Pure stock functions.
