04-13-2016, 06:04 PM | #1 |
88
Rep 401
Warped rotors
Dealership is going to replace my rotors under warranty (at 30,000km). It sounded like they were only replacing rotors though, lots of depth left on pads. Should I get new pads at the same time (even if I have to pay for them)?
04-13-2016, 06:09 PM | #2 |
514
Rep 3,482
No. Just keep the pads on there if they're still good. No sense in wasting money at that point.
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
04-13-2016, 08:14 PM | #4 |
Stop the hate, get a V8
3851
Rep 8,625
Wow, very lucky. Generally speaking, rotors outlast the pads on these cars.
Now: 2017 Corvette Grand Sport, 2021 AMG C63 S sedan
Past: 2011.5 M3 sedan ZCP |
04-13-2016, 08:32 PM | #5 |
514
Rep 3,482
Damn, nice.
BMWCCA:518970 |
04-14-2016, 10:27 AM | #9 | |
DSC Off!
307
Rep 718
You will always get pad deposits when running the OEM pad after your second or third track day. The shaking/judder will be significant but the deposits will wear off within 100 miles of daily driving. Time for track pads.
MCS 1WNR with 600/900 spring rates / Vorshlag camber plates / Apex ARC-8s with MSI studs / Stoptech Trophy ST-60/ST-40 / Cantrell Motorsports Brake Duct Kit / Cobalt Friction XR1, XR2s or PFC-11 pads / UUC Corsa axle-back with Fabspeed HFC and x-pipe / Schroth Quick Fit Pros / HANS Sport II / AA green filter / Coolshirt with large bag / Aim SoloDL with SmartyCam / CSF Radiator
04-14-2016, 01:07 PM | #10 | |
3851
Rep 8,625
"Warping" is not the problem, it's pad deposits. The deposits happen when the pad material overheats and starts to lay down huge chunks on the rotor face. As you press the brake pedal down, you'll feel these vibrations through the pedal and steering wheel. The OEM pads are not designed for sustained high temperatures, and there's only so much cooling available. A race pad can handle higher temperatures, and for longer periods of time., meaning they'll be less likely to leave deposits. And yes, novices do tend to overuse the brakes.
04-14-2016, 01:19 PM | #12 | |
3851
Rep 8,625
It might be a case of them simply using that phrase since the lay-person understands it. Then again, SAs are not always the most technical guys....they're salespeople.
04-14-2016, 01:20 PM | #13 |
Supreme Allied Commander
3857
Rep 54,419
Drives: F80 M3
A runout check will reveal the if the rotors are indeed warped or there is uneven pad deposits.
04-14-2016, 02:32 PM | #14 |
88
Rep 401
The BMW Tech said they measured the rotors and they were out of spec. I have no reason to doubt him as it's costing them money to install new ones. That being said is there visual clues of this pad deposits? I have a few hundred km's on pads and rotors since the HPDE event and there has been no change in the feel of the brakes.
04-14-2016, 02:43 PM | #15 | |
3857
Rep 54,419
Drives: F80 M3
If you start to see pad material being smeared across the rotor surface, that could be an indication of deposits. The rotor surface should be pretty consistent. |
05-26-2016, 07:33 AM | #16 |
88
Rep 401
So the dealership replaced the front pads and rotors under warranty, very nice! I'm going to order some PFC08 pads for the front and rear for future track day events. I'll get them on a week before the event to seat them properly. Will there be any issues city driving them in cold or wet weather? Also, if I upgrade my brake fluid to something like AP Super 600 or Motul RBF600 would there be any issues with this fluid in the winter months (daily driving)?
Thanks in advance for your input. |
05-26-2016, 12:51 PM | #17 | |
3851
Rep 8,625
You don't need them on a week in advance. Just install them before you leave for the track (the day before or whatever). They'll bed-in on the first lap or two. I wouldn't run them any longer than necessary around town, as they'll be noisy as shit and really increase stopping distances. No problems running those fluids year-round. Consider Castrol React SRF -- highest wet boiling point of any fluid. There's a reason race cars use it.
05-27-2016, 09:48 PM | #18 |
84
Rep 147
PFC08's are great. If you ever get deposits, put race pads on and drive for 1-2 weeks. That will clean those rotors up and all judder will be gone. It's nice you got them replaced.
