KEEP M3POST ALIVE BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER LINK! |
04-11-2016, 12:34 PM | #1 |
61
Rep 453
Te37 help
Considering purchasing some te37 and had a few questions. Tires setup I want to run is r888, at least for the rears 100%. My goal is to have the most optimal traction so if I can put a wider tire that would be best.
Looking for 295/35/18 for rears, if I'm looking at 10.5 in the te37 what's the best offset to choose ? I read anything under et25 will rub. For fronts I'm not positive on size yet but probably 265/40 or 265/35. Want to get the te37 in a 9.5. What would be the best offset for a "flush" fitment? Really don't want to run spacers. Thank you for the help |
04-11-2016, 12:39 PM | #2 | |
469
Rep 1,320
04-11-2016, 12:40 PM | #3 |
147
Rep 959
You can go with the +22 offsets. Rear may rub a little depending on if you're lowered. Can be solved by adding a little camber.
2011 e92 ///m3 zcp - jzb/fr
ED 6/29/10 |
04-11-2016, 01:09 PM | #4 |
348
Rep 414
I ran 18x10.5 et 20 rears with a Hankook rs3 in the rear 285/35/19. I was extremely low in the rears and the rubber was just tucking. I feel as if a 295 in a semi slick would rub if you were dropped on coils. This is just my personal experience from my alignment setup and tire specs.
If you were not on coils that is another story and it may fit... Also a little extra camber may fit. Here is a picture of 285/35 rs3 As a track dedicated setup I would say a 285 rear and a 265 front would be perfect with absolutely not fender modifications needed (I ran a 18x9.5 front et22 with a 265) |
04-11-2016, 01:12 PM | #5 | ||
61
Rep 453
04-11-2016, 01:14 PM | #6 | |
61
Rep 453
04-11-2016, 01:16 PM | #7 | |
61
Rep 453
04-12-2016, 12:39 PM | #9 | |
348
Rep 414
et35 is on the conservative side, and yes you may have to run a spacer or risk rubbing the strut. Id look into a Macht Shnell stud conversion kit front and rear, so you can run regular lug nuts and have the possibility to run virtually any reasonably sized spacer you want. |
04-12-2016, 12:45 PM | #10 |
514
Rep 3,482
Honestly, I'd wait for a set with +22 front and +20 rear offsets
2011 e90 M3 Space Grey DCT ZCP- eAs, BMW Performance, Agency Power, Macht Schnell, iND, Milltek, Volk, Challenge, Stoptech, Ohlins
BMWCCA:518970 |
04-12-2016, 01:19 PM | #11 | |
61
Rep 453
04-12-2016, 01:56 PM | #12 |
514
Rep 3,482
When I get my car back I'll have to look. I'm running 285 continental DW's and they don't rub. I'm thinking I can afford 5mm more in front and behind the current tire.
BMWCCA:518970 |
