03-24-2016, 12:37 PM | #1 |
33
Rep 219
Stock Radio Signal is Garbage
I just picked up a 09 135i with the standard sound package. I noticed that the radio signal has quite a bit of static. Does anyone have a solution for this? To me the radio quality is better in my 2002 forester, this should not be.
Please help, or point me in the right direction if a thread already exists. |
03-24-2016, 03:17 PM | #2 |
C2H5OH
3915
Rep 2,144
I get no static at all and I'm ~40 miles from the nearest broadcast tower.
I would say there is a problem with yours and that you may want to return to where you purchased it from and see if they will help/repair/diagnose. |
03-24-2016, 04:56 PM | #4 |
86
Rep 541
First things, first. Start with the basic, the easy, the most likely and the least costly issue. Assuming the basic design doesn't change (I'm not with my 1M right now to verify), try this:
There is a multiwire connection at the lower left base of the window. The wires there are all small gauge with small connectors that are subject to much temperature, UV and vibration. The antenna connection develops oxidation which significantly reduces signal strength while introducing noise into the signal. FM and AM signals are vulnerable and suffer; a filter will not help at all in such a situation.See also - http://www.m3forum.net/m3forum/showp...6&postcount=12 Assuming no prior mods and/or work with the electronics, the age of the vehicle and exposure to sun are factors causing a reception problem. |
