03-23-2016, 04:28 PM | #1 |
912
Rep 1,850
Bushings...expensive as hell no longer?
After looking around the powerflex site I was totally shocked by the price of bushings. They are really expensive!! So here's a quick plan I came up with that any mechanically-minded individual can use to produce their own sick bushings:
I don't own a lathe, so unless I come across one on Craigslist that fits my budget I'll buy the crappy mini lathe from Harbor Freight and return it in the 90 day window. This is $550, but it's returnable so essentially just worth my time. I shop at harbor freight all the time since there's one right by my office, so no, I don't feel bad about using their generously provided return policy. Some bushings may be larger than what the chuck can hold but that won't be a problem since they all need hollow centers anyway and they can be mounted and turned that way. Looking around online, polyurethane rod, from www.usplastic.com, is: $73.23/36" for 1.5" diameter $109.34/36" for 2" " $200.57/36" for 3" " Now, 36" of poly rod makes a LOT OF BUSHINGS!! So the economics of this seem like a total no brainer especially if I can sell some extras out of the stock I make for myself. Cost of the metal inserts is minimal. |
03-23-2016, 06:33 PM | #2 |
840
Rep 2,402
It's absolutely ridiculous what they charge for a hunk of polymer.
While you have to pay for shipping, look at strongflex. Much more reasonable for chunks of poly.
'02 S54 M3 (500/500 GC/Koni)
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) |
03-24-2016, 12:53 AM | #4 |
912
Rep 1,850
If anyone has dimensions for more or less any bushing, please add them to the thread. First, specify the name and location of the bushing. The relevant dimensions would be, size of fastener going thru the center, diameter of the part that's covered during install, length of the part covered during install (if it has grooves for lube, diameter of the higher part), and diameter and length of any parts that sit exposed when installed. If that sounds confusing I can make a diagram.
With this information anybody who visits the thread can easily turn their own bushings and subvert the disgustingly overpriced, low volume aftermarket. Last edited by The Wind Breezes; 03-24-2016 at 01:22 AM.. |
03-24-2016, 06:27 AM | #7 |
840
Rep 2,402
I paid roughly $40 or 50 to ship TS and control arm bushings for our X1 and 135. Somewhere around $180.
'08 N54 135 (JB4, DCI, BMW PS/Bilstein B6s, H&R M3 FSB, Strongflex FCABs) '14 N55 X1 (JB4, BMS DP, BMS Intake, Alpina TCU reflash, H&R Sports, Bilstein B6s, E93 M3 RSB, Strongflex FCABs, baby seat) '08 N54 535xi touring (Bilstein B6s, Downpipes, MHD tune, baby seat) Last edited by PrematureApex; 03-24-2016 at 08:11 AM.. |
03-24-2016, 06:32 AM | #8 |
912
Rep 1,850
03-24-2016, 08:13 AM | #9 | |
840
Rep 2,402
Made a couple posts: http://www.1addicts.com/forums/showthread.php?t=1236485
04-07-2016, 03:01 AM | #10 |
C2H5OH
3916
Rep 2,145
I would say the center bore depends on the steel pin being used.
I would never trust bare plastic to a bolt. It will ware and develop slop, in some cases much faster than you want. Also, thanks for being that asshole. I just love it when I go to buy something, open the box and it's fucking used. Now I have to waste more of my valuable time to go back and get a new one. I'm not taking chances on someones used shit. They obviously returned it for a reason that I don't care about. I pay for NEW parts. |
04-07-2016, 05:29 AM | #11 |
463
Rep 476
Drives: e46 M3, e82v8 (s65 swapped)
i live in russia, and i'm making a lot of different parts on cnc, lathe etc.
in our economical situation (rub to usd/eur currency) it's a lot cheaper, then producing poly bushings in us or europe. but even after that, i've stop all my tries to produce them. to make really good stuff needs a lot of money, more than you can imagine |
04-07-2016, 07:55 AM | #12 |
1495
Rep 3,148
You're crazy if you think you can just buy the lathe and expect it to spout out parts. Requires a LOT of skill, time and tooling to get things done, I own a 7x14" mini lathe myself.
Invested hundreds of dollars worth of tooling and spent a lot of time learning techniques etc using it. Great tool and has helped me a lot when working on cars. Machine has paid for itself. But it is slow to make even simple parts, especially if they have to be accurate. Whiteline makes most bushings for the car and theyre not that expensive. e.g subframe bushings: http://www.ebay.com/itm/Whiteline-KD...UAAOSwoudW-B-n
04-07-2016, 08:26 AM | #13 | |
840
Rep 2,402
Cutting poly also isn't going to require a ton of tooling, and isn't tolerance critical. I used to be an SAE guy living in a machine shop in college. Freshman get all the lathe work. No experience, and they pick it up pretty quickly. Cutting bushings/rod end spacers/etc. within a matter of a couple hours after showing them the ropes and having them learn through trial/error. But anyway, if he wants to save money, and perhaps even enjoys the DIY/satisfaction of it, I say go for it.
04-07-2016, 02:37 PM | #14 | |
912
Rep 1,850
Just popping in since this was updated, otherwise I have no updates for this thread. |
04-07-2016, 02:53 PM | #15 |
827
Rep 3,856
Doesn't whiteline make them even cheaper than powerflex? http://www.whiteline.com.au/do_segue...ehicle=2004-ON
$300-400 for all your control arm bushings front and rear. What do you expect to get your cost to after trial/error, and get all the parts perfect for the car? |
04-07-2016, 03:51 PM | #16 | |
912
Rep 1,850
