03-11-2016, 08:26 AM | #1 |
32
Rep 92
Exhaust valve delete kit
Hey guys, does anyone know a UK source for the JCR designs valve delete kit, or something similar?
I don't feel the need to be able to switch the valves open or closed and just want them open full time. I'd like to keep things tidy and like the male/female plugs that come with the JCR kit. Anyone done this in the UK? |
03-11-2016, 01:23 PM | #2 |
763
Rep 948
Hi, I have fitted this kit, its first class and works perfect, the noise from the stock exhaust is transformed, you can have it default open and OEM when activated, comes from the US in 5 days and around £150 plus import tax, I was £21 for tax, its good quality and fitted in 30 mins, you can drop the rear heat sheild and tuck the cable away, it's very neat, might be of interest to you, cheers John
http://www.cgprecision.com/cms/index...und-controller |
03-11-2016, 02:01 PM | #3 | |
876
Rep 1,319
03-11-2016, 02:14 PM | #4 |
763
Rep 948
With you on this Simon, that would do the trick, the CG also works just great, John
03-12-2016, 03:12 AM | #6 |
642
Rep 1,700
By having the valve open all the time, are you reducing low end torque? Does there need to be some back pressure with the valve closed?
I've noticed with my capristo exhaust on the Porsche, which valve controlled, it picks up better from a dig with the valve closed and then boosts more and has a noticeable surge when the value opens. I have a sport mode which keeps valves closed at low back pressure and then opens the valves when back pressure increases, at about say 3/4K rpm, or open all the time for really loud sound! My boost pressure reading only increases and you feel it when the valves are closed and then open during wot.
Current - 2016 McLaren 650s Spider, Aurora Blue
Current - 2016 Range Rover Sport SVR- Black Current- 2018 Aventador S. Nereid blue Gone - 2016 F80 CP, 2015 991 Turbo S, 2016 LCI M135i. 2015 F10 CP M5. 2015 X5, 2012 E92 CP M3. 2009 E92 335i |
03-14-2016, 10:44 AM | #7 |
32
Rep 92
Yeah thats what I was planning, the thing with the kit I mentioned was it came with the male/female plugs to make sure dirt and water doesnt get into the plugs.
03-14-2016, 01:39 PM | #8 |
876
Rep 1,319
The plugs can easily be protected by either a good tape, or by cutting the fingers off a rubber glove, and slide it over the connector.
