03-05-2016, 05:01 PM | #1 |
166
Rep 860
Mobil 1 No Longer Makes Motor Oil for Many BMW's
As crazy as this sounds, apparently it's true.
Mobil 1 0w40 European Car Formula used to state on the back of the bottle that it met BMW's Longlife-01 spec. I went to order some more 5 gallon pails from Amazon, and I noticed the following review: "I bought this for my BMW 330i as it is supposedly an LL-01 approved oil. However, it it NO LONGER an LL-01 approved oil and the pictures listed are incorrect. The new front label no longer has BMW listed and the rear label listing the chart of which manufacturer is approved no longer has BMW as well. I bought this oil as I recently read online that M1 0W-40 was losing the BMW LL-01 accreditation, however, Amazon has already switched over to the new stock but has not yet changed their picture." Sure enough, I used the "find the right oil" feature on Mobil 1's website, and when I entered my X5 (a 2011 50i) I received the following response: Based on what you've told us, your vehicle manufacturer recommends a 0W-30, 0W-40, 5W-30 or 5W-40 viscosity and oil that meets BMW Longlife LL-01 or BMW Longlife-01FE. We currently do not offer any motor oils in the United States that meet these specifications. I also own a 2016 M235, and the same message appeared when I entered that car. Sounds like Mobil 1 European Car Formula is no longer being marketing in the United States. |
03-05-2016, 08:17 PM | #2 |
Tuned ///M Cars Only
140
Rep 334
Drives: '21 F87 M2C |'20 F97 X3MC
I use Liqui Moly 5W-30 for my 35i. Cousin uses Castrol TWS 10W-60 for his M.
03-05-2016, 11:00 PM | #3 |
209
Rep 1,044
I stopped caring what BMW recommends when they started ignoring engine bearing clearance recommendations from manufacturers. I've also personally seen the top ends of two different M54 engines, one used OEM Castrol, the other Mobil 1, and the engine that used Mobil 1 was unquestionably cleaner. Oil change intervals and mileage of both cars similar. Another thing, BMW has had some very interesting oil weight suggestions, specifically with the M models, that have contributed to excessive engine wear. Add this all up and you can see why I stopped trusting "BMW recommended" oil options
03-05-2016, 11:06 PM | #4 |
209
Rep 1,044
03-06-2016, 10:00 AM | #5 | |
166
Rep 860
03-06-2016, 10:18 AM | #6 |
209
Rep 1,044
Unless the European Car Formula has changed here in the states, then I wouldn't expect a different outcome. Since switching to the European Formula and changing the weight for my E46 I've seen a good reduction in oil consumption and the top end seems to be pretty clean. My oil change intervals are 7500.
03-06-2016, 12:09 PM | #8 |
Rep 45
Or Mobil chose not to certify it to the BMW standard, for whatever reason. I use M1 0W-40 on our E46 and a 911. I like having a common oil, which I buy in bulk at Walmart. The E46 is pushing 200k miles and I'll likely stock with Mobil 1. It may be irrational, but I just don't care for Castrol oil.
2013 E70 x35d
2004 E46 Sedan 2009 997.2 Cabriolet |
03-06-2016, 12:25 PM | #9 |
19
Rep 51
I only run liqui moly 5w-40 in my 4.8, ran castrol bmw oil and the new shell bmw oil 5w-30 and it doesnt compare, will always end up going back to liqui moly
03-06-2016, 12:30 PM | #10 | |
166
Rep 860
Mobil no longer offers the same product. The formulation of what they offer for sale in the U.S. now is significantly different, and does not meet the BMW LL-01 spec. If you are interested in the technical details regarding what has changed, you can find some forum threads about this at bobistheoilguy.com. |
03-06-2016, 01:28 PM | #11 |
209
Rep 1,044
Well, I wasn't aware that Mobil finally went to GTL, I had read a while back they were going to possibly get a GTL plant so if anything this is good news!!!! Wondering if they will be moving all of their automotive engine lubricants to GTL.....
In comparison to PAO, the GTL product that Mobil 1 is producing will actually have higher quality ISO paraffins which is the lubricant base stock. If anything we'll see more companies going this route than not and with increased environmental and efficiency pressures on manufacturers it'll only be a matter of time before BMW tests and approves GTL products. The downside to GTL, cold flow/CCS (Cold Cranking Simulator).....of which most people wouldn't have any issues except for those in very cold climates. Even then, additives can be introduced to improve the performance. In my opinion this is good news and if you do enough research and studying I think you'll agree. If anything this is yet just another reason why I could care less of "BMW approved" labeling. |
03-06-2016, 01:42 PM | #12 |
166
Rep 860
Are you saying that BMW tests and certifies oil rather than the oil manufacturer certifying that their product meets BMW's spec? And are you saying that GTL products actually already meet BMW's LL-01 spec, and it's a matter of BMW getting around to testing them, or are you saying you expect BMW will change their spec to include GTL products?
03-06-2016, 03:28 PM | #13 |
209
Rep 1,044
When I say tests and approves, I mean BMW will do it internally to see how GTL products will perform on their engines, for all we know BMW could possibly be already testing or not....its hard to speculate. Since GTL originates from natural gas this is indeed a new type of formula and given that the lubricating properties of GTL are positive I'm sure BMW would, at the least, consider it for particular applications. My thought is that it will be a different certification than LL-01 spec since its a different quality of lubricant base stock but I could be wrong. I'm just not sure how they will view GTL vs others (ie: comparing apples to apples) when it comes to certification. I'm sure there is someone on here or on the oil forums that would have better insight or is familiar with the cert process that can shed more light.
In the end, if GTL proves to be as beneficial as the tests show, I don't see how a manufacturer couldn't consider it if costs are the same. |
03-06-2016, 06:57 PM | #14 | |
Rep 45
2013 E70 x35d
03-07-2016, 10:11 AM | #15 |
Rep 86
what are the differences? i am looking to switch my oil to something other than BMW. was planning on going castrol edge professiona 5w-30 or liqui moly. please provide feedback. thanks
03-07-2016, 03:46 PM | #16 |
19
Rep 51
I used to work at bmw and the master techs and shop foreman swore by liquimoly. It is allso bmw LL-01 certified and With 5w40 its a little thicker so it wont leak and runs really smooth and quiet. There probably is more expensive oil that is better like motul but liquimoly i personally feel is better than castrol, mobil1 or the new bmw shell oil.
When i first bought my 4.8 - 2 years i opened up the valve covers and there was a lot of metal shavings from the premature wear of the VANOS due to lack of oil changes. Especially with the v8s the temperature runs hotter and breaks down the oil and seals faster. I replaced all the gaskets and the coolant exchange pipe and was still burning half a litre every 3000kms. Once i changed over to liquimoly i havent burned a drop and there isnt anymore wear that i can tell. Currently pushing almost 190k on the odometer and still pushing strong. I also change my oil every 6-10k instead of the 26k bmw recomends for long life oil. $40 for 5 litres here in toronto so for americans its probably pennies on a dollar. Last edited by fourpointeight; 03-07-2016 at 03:51 PM.. |
03-07-2016, 05:16 PM | #18 |
19
Rep 51
Personally i prefer liquimoly, all the tests they do and comparison videos on youtube prove it.
But i agree thicker oil is most likely the reason for less oil consumption. But any oil rated LL-01 that doesnt break down fast with heat would be sufficent. Just avoid non LL-01 oils if you dont plan on changing it every 3000 miles. Ive seen people using normal synthetics in our bmws and it was thinner than water by the time it was ready for an oil change. Bottom line is that we're all owners that want our vehicles to last the longest possible with as little problems as possible. So from the best of my knowledge previously being a bmw employee im giving this community my honest thoughts on what i believe in and works for me.
MODS: K&N drop-in air filters, USMILLWORKS adjustable plate mount, aerodynamic kit, vinyl wrapped gloss black interior trim, one off custom rear trunk spoiler, tinted tails, magnaflow free flow mufflers, H&R 1.2" Lowering springs with adjustable links +many more
03-07-2016, 05:20 PM | #19 |
15
Rep 109
For 2010 X5M what kind of liqui Moly oil would be best? Top Tec 4200 5W-30? there's no liqui Moly 10W-60 for M's?
http://www.liqui-moly.de/liquimoly/p...oiladb=web.nsf |
03-07-2016, 05:28 PM | #20 | |
19
Rep 51
http://www.amazon.com/Liqui-Moly-202.../dp/B00CPL918E
03-07-2016, 05:30 PM | #21 |
209
Rep 1,044
I hope you weren't referring to the YouTube video comparing Mobil 1 vs LiquiMoly where the Mobil 1 caught fire. Its one thing to make an opinion from professionally done tests vs uncontrolled consumer tests you find on YouTube.
The fact is LiquiMoly is a great oil, but Mobil 1 0w-40 is equally as good. No one has yet to scientifically prove which is better so either option you can't lose. Of course the new debate will be how the Mobil 1 GTL product does against the competition. Lastly there's a lot more to oil break down than just heat. With typical BMW engines found in M vehicles, oil consumption is the norm to a certain extent but in some cases with consumption means the introduction of fuel. Fuel particulates can aid in the oil break down process among a list of other variables. Unfortunately when it comes to oil nothing is just black and white. Btw I used LiquiMoly for my M5s and Mobil 1 for my non M vehicles so I'm not biased towards either. |
03-07-2016, 07:16 PM | #22 |
19
Rep 51
No no, theres videos of how liquimoly is able to lubricate faster and breakdown slower etc etc. But everyone is entitled to their opinions, BMW recommended castrol because they had a contract with them, obviously they wouldnt recommend any other brand. Now they recommend their own brand made by shell. Its profitable for them and that really is all it is.
Mobil 1 has always been a great oil same with redline, royal purple, liquimoli, motul etc. All good for different applications. Now that mobil1 stopped being BMW LL-01 approved we dont know if it will be a different formula. Therefore people are scared about whether its good or bad for our cars anymore. So the best option is going with an oil that is recommended by other fellow members.
