03-03-2016, 11:16 AM | #1 |
36
Rep 127
Michelin Pilot Super Sport 255/35/18 mileage
I am curious what people are getting in terms of mileage out of their Michelin Pilot Super Sport 255/35/18.
I just replaced my tires and got 13,700 miles and the inner tire was showing wire from the rear passenger side. I understand 15,000 miles is very good for these tires. Before I had 245/40/18 Continental Contact DW and had to replace it after 10,000 miles. |
03-03-2016, 07:23 PM | #2 |
122
Rep 2,040
Drives: 2008 135 blk, blk, step
Garage List 1994 Porsche 968 Cab [0.00]
2017 AMG GTS [0.00] 1994 Porsche 968 Coupe [0.00] 1977 Mercedes 450SE ... [0.00] 2008 135 [8.00] |
You must have an alignment type issues, too much toe, etc. Even when i was running max factory camber (3deg) my PSSs went more like 22k miles.
Injen, RR OCC, MadDad Whisper, donut spare, 19x8.5et43fr 19x9.5et45r Volk LE37's, rear fenders rolled/pulled, PSS4S 225/35fr 255/30r, KW V1's, AR coated catless dps, Cross strutbar, CF grills and license plate holder, iCarbon diffuser, ETS black anodized FMIC, M3 control arms, Quaife, ER chargepipe, ForgeDV's, Topspeed Custom Tune, V3sims, Braille, Andrey_GTA rear hub mod, Ebay Mstyle front bumper and performance style side skirts.
03-08-2016, 03:07 PM | #6 |
36
Rep 127
My alignment was off!
For some reason I thought it was normal for Michelin Pilot Super Sport to get around ~15k on the rear which made me think this was normal. I didn't have any drifting while driving in a straight line or steering wheel off center. Lesson learned. Let's see how these Michelin Pilot A/S 3 last me....initial impressions are very good. For "spirited" street driving it is pretty grippy compared to Pilot Super Sport. If Michelin Pilot Super Sport are 10/10...it is 8.5/10 minimum |
03-08-2016, 06:11 PM | #7 |
2046
Rep 25,989
Definitely seems like an alignment issue. 12k seems like a very short life, unless you were having a lot of fun with them.
VMR|Wheels | 714.442.7916 |
03-09-2016, 02:03 PM | #8 |
107
Rep 1,428
I currently have Dunlop star specs, I haven't really been keeping track of wear but it's far from 20k. So now I'm thinking about switching, my only real concern is grip and I live in Houston so I can run a summer all year. So my question is which is better for grip pss or ps2?
03-10-2016, 10:54 AM | #9 |
36
Rep 127
03-10-2016, 10:57 AM | #10 | |
36
Rep 127
I've had Dunlop Star Specs (first version) on another car and I'd say PSS is same if not better grip. Plus it is more quiet, smooth, good in wet, great steering response, and lasts longer. |
03-10-2016, 11:25 AM | #11 | ||
125
Rep 750
Drives: '98 Z3M (gone), '09 135i
03-10-2016, 12:01 PM | #12 | |||
107
Rep 1,428
03-10-2016, 01:00 PM | #13 |
I'm a PC
Rep 168
03-16-2016, 11:22 PM | #14 |
21
Rep 104
I have about 600 miles on mine and the outside shoulders are shot with just 3 track days! The rest of the tire looks mostly new though. I just installed Bilstein coilovers and aligned with more neg camber so hopefully that will help. Good tire though, nothing negative to say about them, just cooked them at the track...
Mods: Cobb Tuner, Cobb turbo back exhaust (high flow cats), Stett intake, ER Chargepipe, ATM Intercooler, Toyo R888 - 225/255, M3 subframe bushings, Bilstein PSS 10 Coilovers.
03-17-2016, 01:02 PM | #15 | |
36
Rep 127
I thought maybe its my driving or the roads I am on but my front tires especially the shoulders show excessive wear in the twisties. Do you hear like a light tapping/clicking noise during hard tight turns? |
03-17-2016, 10:45 PM | #16 |
21
Rep 104
Yea mostly the fronts are shot but the rears have quite a bit of scuff. I don't hear any odd noises from the tires though.
04-02-2016, 02:07 AM | #17 |
33
Rep 208
I am having the same problem right now, right rear passenger is showing threads but i know i definitely could use an alignment. I am on my first set on this car i'm at 14,000 on mine!
04-02-2016, 02:26 AM | #18 | |
European Editor
10596
Rep 22,992
AntonioZ
Do they still even make PS2's ??? The most I have ever gotten out of my rear Mischelin PS3(I'm in Germany) has been almost 30K kms. The least, has been 17K kms. My alignment is perfect. This is what happens when you have a 400+ Hp car and an open diff. Michelin A/S will get much better wear bc the tread wear rating is sky high on those tires. I think PSS are rated at 170 twi while the A/S versoins are up around 490 twi. What I really love best about my Michelin's is even when there is very little tire tread(under 2mm's) these things still grip very well in the rain and cold. Plus the tires never get noisy as they age. Most tires will make all sorts of wheel bearing type noises - at half thread or less. Not the Michelin's - they are magical as far as I am concerned. Dack
04-03-2016, 04:31 AM | #19 |
13532
Rep 8,170
Pilot Sport 2 PS2's have been replaced by Pilot Super Sports, which are apparently getting replaced by the new Pilot Sport 4 tire this year in most aftermarket sizes. Pilot Sport 3 PS3's have also been replaced by Pilot Sport 4.
OE will still be the PSS although there's already an N-rated (OE Porsche) Pilot Sport 4 tire. I think BMW will continue using PSS till Michelin discontinues the PSS range completely (2017-18?) I might be wrong because there's a lot of confusion there... or maybe it's just me who's confused, LOL.
04-03-2016, 02:42 PM | #20 |
Pablo
39
Rep 263
40,000 miles
I have PSS 225/40R18 fronts and 255/35R18 rears that I purchased from Tire Rack in 2012 and am rolling past 40,000 miles of freeway driving and there is still some tread left (car has 82K miles). No flats and even wear. 5 minutes ago I just ordered PSS replacements from Costco website ($920 installed).
BMW PPK V2, M3 26mm sway bar, M3 front control arm kit, M3 steering wheel, BMW 313 wheels w Michelin PSS
10-03-2016, 07:16 PM | #21 |
36
Rep 127
UPDATE:
I replaced my Michelin Pilot Super Sports with Michelin Pilot A/S 3 (non-plus) on 3/2/2016 with 82,937 miles as you can see from my original post date. I was hoping these tires would outlast the Michelin Pilot Super Sports but as of now, 10/3/2016 and roughly 93,000 miles, the rear tires are starting to get close to the wear bars. This seems pretty strange after 7 months and 10k miles for a tire that has 45,000 mile warranty. I know it is cut in half due to the stagger fitment so 22,500 miles. I have started a case number through Michelin and will report back on what America's Tire have to say about this. Looks like the Michelin Pilot A/S 3+ (plus) versions are my only options now as the front still has plenty of tread. |
10-03-2016, 07:17 PM | #22 |
36
Rep 127
And yes I got an alignment shortly after getting the tires installed and another alignment for good measure (I hit a bump and was concerned about alignment). I also check my tire pressure monthly using 36 psi front and rear cold per door jab.
