02-29-2016, 11:26 AM | #1 |
250
Rep 748
F15 oversteer or understeer?
Question is in title. I searched all over and cannot find a definite answer. So, by design, does F15 oversteer or understeer? Thank you)))
Ones drove a Reliant Robin. )))
02-29-2016, 02:07 PM | #2 |
12971
Rep 18,716
artem123 , most of the street car are aligned for Understeer since it is much2 easier to control by novice driver.
So, the answer would be understeer.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
02-29-2016, 02:13 PM | #3 | |
250
Rep 748
02-29-2016, 02:42 PM | #5 |
250
Rep 748
Thank you.
02-29-2016, 07:35 PM | #6 |
591
Rep 710
I'm going to research this one. Neither makes sense and both equally dangerous. Lawyers would love to get hold of a manufacturer who states their vehicle is biased one way or another. The correct answer, I would bet, is neutral or balanced. Environmental factors will dictate whether you have under or oversteer.
I spent 11 years at Road Atlanta teaching people how to get out of both situations in their Porsches. Hell, in an older 911/930, you had both conditions inherent in one car, depending if you were accelerating or decelerating. One of the reasons Porsche went back to 4WD and put an engine in the middle of a car (Cayman) was to get proper balance. That thing is on rails. Panamerica - balanced. Cayenne - balanced. Boxster - balanced. M3/M5 - balanced. I've pushed my X5 and it's balanced - the front does not push and the rear does not step out. I cannot imagine BMW designing an X5 to push (understeer - keep going straight losing all input from the steering). Imagine coming to a decreasing radius turn on a hillside or mountainside road. You enter too fast, turn the car - bang - understeer and off the edge you go. If anyone has proof (and comments from forums don't count), I would like to read it. I googled it quickly and found comments in popular car magazines state that cars are designed to be balanced, but either condition can happen given poor tire tread, road conditions, road camber, tire temp, and so on. I always set my cars up to be 100% balanced by corner balancing the weight of the car and using adjustable sway and coil-overs. Anyway, please let me know what you find.
Sold: 2014 X5 xDrive35d MSport
02-29-2016, 08:54 PM | #7 | |
250
Rep 748
PS. Another "top tier" engineer from the same company told me that Treg's transmission is sealed and never needs a oil change in it, while Bentley publishers manual clearly stated that 60K or 6 years transmission fluid change is a must...
02-29-2016, 10:46 PM | #8 | |
591
Rep 710
I've been reading some of my suspension books and on-line articles and best I can tell, nearly every passenger vehicle (no brands were mentioned) is designed to be neutral (or balanced), but because there are so many variables, and handling is not linear, some cars will have slight understeer and some will have oversteer. As I stated earlier, environmental factors will dictate which way the car breaks - front or rear. So as far as I am concerned, these are neutral. As for the tranny, one of my customers is ZF in Gray Court, SC. At this facility, they make trannies for Ranger Rover, VW and Honda. I know some of the people at ZF in Germany as well, and all of the "car guys" in each of the factories state, ALWAYS change the fluid at 30,000 miles - full stop, period. These are the same people who see the returns that come back from dealers and are disassembled for analysis. So, when the majority of employees who work at ZF tell me to change the fluid, regardless of what BMW states, I'm doing it. For some reason, 30,000 miles seems to be a magic number, including my Ford Powerstroke and my SL550. Every 30k, Merc and Ford recommend flush and fluid replacement. The X5 will get the same, keeping in mind, I own, not lease.
03-01-2016, 06:15 AM | #9 | |
Herr Oberst
244
Rep 531
In normal daily driving, you should experience neither out of your X5, though if you were to overcook a flat corner by a large margin, you might notice it a touch.
'15 X5 35d
'16 740i |
