02-28-2016, 05:09 PM | #1 |
278
Rep 217
Washing cars in the rain :)
I wanted to test my new pressure washer and soap cannon and my wife just got back from a quick trip down to Portland, OR to visit our daughter in her 1 week old X6 so I tried to get a quick wash in before the rain started. The car just had CQuartz Finest coating applied so I was extra careful. Pressure Washer – Kranzle K499TST MTM Hydro Long-Range Detergent Foamer Attachment Pair of buckets with grit guards, microfiber wash mitts, microfiber towels and microfiber waffle towels. Stihl backpack leaf blower Just as I was finishing up drying as much of the car as I could with the leaf blower it started raining so I pulled the car into the garage and pat dried the rest of the car. I pulled my 2009 335i Coupe out to use up the rest of the soap and it started pouring so I put on my rain coat and finished quickly. Love the pressure washer and foam cannon. The pressure washer will also be used to clean our stamped concrete patio and tile roof which is why I went high end. It is a beautiful unit but I did need to install an additional 20 amp circuit in my garage. This was when we first brought it home last Friday night. |
02-28-2016, 05:17 PM | #2 |
12
Rep 169
Looks Awesome!
I have the Kranzle 1122 and the foam cannon as well. I use a Master Blaster for drying (have to use a 20amp circuit for the Master Blaster). My coating is OptiProPlus and the water just flies off when drying. One tip is that the filter in the form cannons can get clogged pretty quickly; I now fill up the bottle with plain water before cleaning up and empty it in the pressure washer to clean all the shampoo out of it. |
02-28-2016, 05:39 PM | #3 | |
278
Rep 217
The paint coating does make washing much easier and an electric pressure washer with quick connects is fast to set up, simple and efficient to use. I was surprised how quiet it runs. The back pack blower works well but it makes it a little tough to get above the car and blow down even on a step ladder. |
02-28-2016, 06:24 PM | #4 | |
12
Rep 169
You might want to check out the DP Turbo dryer from Autogeek - it's not too expensive and would make drying above the car much easier. |
02-28-2016, 08:52 PM | #5 |
278
Rep 217
Thanks for the hit to my wallet, master blaster ordered.
02-29-2016, 03:53 AM | #7 |
Mmmmm…
1150
Rep 2,426
Drives: F15
I miss having a garage to put a pressure washer. Now living in an apartment I am at the mercy of those terrible pressure washers they offer at those "self-service" car washes.
Sometimes a regular wash doesn't work. Right now my front bumper is covered with bugs. I can't just use a towel since that would really scratch the paint. |
02-29-2016, 08:45 AM | #8 | |
12
Rep 169
There are a couple of products that I have found to work really well for me for this in between washes: Auto Finesse Citrus - Bug and Grime Remover. I purchased it at Detailer's Domain. Ultima Waterless Wash. I purchase this at Autoality but it is also available at Autogeek and Autopia. I spray both on the bumper, let it sit for a minute and wipe off gently with a quality plush microfiber towel and it leaves no scratches. |
02-29-2016, 08:46 AM | #9 |
12
Rep 169
02-29-2016, 08:48 AM | #10 |
12
Rep 169
02-29-2016, 05:06 PM | #11 |
71
Rep 315
03-02-2016, 12:00 AM | #12 | |
Mmmmm…
1150
Rep 2,426
Drives: F15
03-02-2016, 09:42 PM | #14 | |
12
Rep 169
FYI - AF Citrus Bug Remover works best if you liberally spray the bugs and then hold the microfiber towel over the stains and let it soak for a minute or two and then gently wipe, repeat as necessary until gone. The Ultima Waterless Wash can then be liberally sprayed over the entire area or bumper in this case and use another quality microfiber towel to gently clean the area. The Ultima WW has lots of lubricity which will prevent scratching or marring if used properly with a high quality plush Microfiber. |
