02-26-2016, 07:10 AM | #1 |
122
Rep 595
Software update with BMW ConnectedDrive.
Has anyone had issues trying to get the USB card read thru the USB port on the center console bin?????
I had and m4 days ago and never had this issue. It won't read the update from the USB card? |
02-26-2016, 07:40 AM | #2 | |
11
Rep 124
However, after my last service my firmware is newer than what is provided on the update site so you should verify the bin file you are using is actually newer than your current firmware. IIRC the error it throws in this case makes that not obvious. |
02-26-2016, 09:39 AM | #4 |
250
Rep 748
Should where? Compare the version you downloaded, and version you already have. If your car has a HIGHER version, then there is nothing to update.
Ones drove a Reliant Robin. )))
02-26-2016, 09:42 AM | #5 |
Rep 23
I recall needing to use a USB 2.0 (vs. USB 3.0) stick to update my wife's 2011 BMW. While I anticipate this shouldn't be an issue with a newer car, it might be one more thing to check to be sure.
02-26-2016, 09:54 AM | #6 |
250
Rep 748
I used USB3.0 on my car and it works just fine. USB3.0 is backward compatible. However my car did not like one usb stick ( 2.0 if it is matter). That usb works fine in my computers but car did not like it.
