BMW X5 and X6 Forum 2014-Current
      02-25-2016, 11:09 PM   #1
MrTookies
MrTookies's Avatar
458
Drives: 2011 E90 328i, 2015 F15 35D
Rheingold Help/request Tja
Guys I just installed the ECE M-Steering wheel with the TJA module and now have issues getting it to work, throwing error codes...VO coded everything though saw in another thread that I need Rheingold to calibrate the module. Where do I get this from and how do I calibrate the module? Thank you so much for the help, i been trying to figure this out all day now...going crazy
      02-26-2016, 08:32 PM   #2
MrTookies
MrTookies's Avatar
458
Originally Posted by PlayTookies View Post
Guys I just installed the ECE M-Steering wheel with the TJA module and now have issues getting it to work, throwing error codes...VO coded everything though saw in another thread that I need Rheingold to calibrate the module. How do I calibrate the module? Thank you so much for the help, i been trying to figure this out all day now...going crazy
NOBODY ?
      02-26-2016, 08:59 PM   #3
wdimagineer
wdimagineer's Avatar
358
Drives: 2015 X5 M
Do you have a copy of Rheingold and compatible ICOM adapter handy? That's Step 1.
Current: 2015 X5 M - Donington Grey/Mugello Red - DINANTRONICS Stage 2 + Free Flow Exhaust - Bimmerpost Featured!
Past: Bimmerpost Featured 2014 X5 xDrive50i · 2014 Jeep SRT · 2013 Tesla Model S P85+ · Bimmerpost Featured 2013 F10 M5 · 2012 550 xDrive · 2011 M3 ZCP
      02-26-2016, 09:02 PM   #4
MrTookies
MrTookies's Avatar
458
@wdimagineer
Rheingold ISTA/D yes, ICOM? Not familiar with the acronym. I need a different adapter then I use for FDL/VO coding?
BTW do you have all the FDL coding items that need to be changed? I went through bimmerfest and saw some but is there a actually a list. I think I got the VO items that where needed...
      02-27-2016, 12:21 PM   #5
CFoote
180
Drives: '22 M5CS, '00 M5, '06 Z4M
2022 M5CS  [0.00]
2001 BMW 740i  [0.00]
2006 BMW M Roadster  [0.00]
2012 BMW X6 3.5i  [0.00]
2006 BMW 325xi  [0.00]
2017 BMW 540xi  [0.00]
2000 BMW M5  [0.00]
2001 BMW X5 4.4i  [0.00]
You should really speak to a pro, it takes months to learn and understand how all of this stuff works. I would suggest you check with a shop that has a Autologic system, Autologic can actually code/program modules that BMW NA/BMW dealerships will refuse because the option codes are not on the build sheet.
Otherwise you need to find someone in your area willing to code your vehicle, unless you plan on spending the time to do it correctly and understand what needs to be done, there is no 'quick and dirty' method behind coding/programming these vehicles.
Even if we gave you a copy of Rheingold, you need a front-end program to run it correctly, its nowhere near as simple as you think.
Chris
'22 M5CS, '06 Z4M, '01 X5 4.4i, '00 M5, '05 Acura RL, '12 X6 3.5, '01 740, 08 335xi, '17 540xi (yes they all are still with me)
      02-27-2016, 12:23 PM   #6
MrTookies
MrTookies's Avatar
458
Originally Posted by CFoote
You should really speak to a pro, it takes months to learn and understand how all of this stuff works. I would suggest you check with a shop that has a Autologic system, Autologic can actually code/program modules that BMW NA will refuse because the option codes are not on the build sheet.
Chris
Thanks for the help completed everything in the last 24h with some remote help thanks dmnc02
      02-27-2016, 12:25 PM   #7
CFoote
180
2022 M5CS  [0.00]
2000 BMW M5  [0.00]
Smart move! Trust me, I am pretty good with this stuff but even some advanced stuff I leave to people who have spent years to take the time to understand
      11-30-2016, 01:46 AM   #8
ThunderTiger0806
Drives: bmw x5
Hi PlayTookies
how did you resolved TJA retrofit could you guide me out of trubles.
thanks
xbimmers
