02-22-2016, 11:30 PM | #1 |
77
Rep 359
Spacers...safe?
I have read some people doing serious damage to their cars with spacers.
Anyone tracking/drifting running spacers? Why are people having issues? Quality? I have also read that a 12mm spacer is safer than a 10mm spacer on our hubs. how can that be? I believe both fully fit the hub and extend a hub centric ring. any insight? |
02-22-2016, 11:59 PM | #2 | |
167
Rep 403
Quoting from https://www.turnermotorsport.com/t-w...yclopedia.aspx Hubcentric Fitments All BMWs use hubcentric wheels. When mounted to the car, the wheel rests on a lip instead of the wheel bolts or studs. The lip contributes to the strength of the wheel and the wheel cannot safely be used without a lip. The wheel bolts are not strong enough to support the weight and loads generated through the wheel. The lip is usually 9-10.5mm in depth and the new spacer must have its own lip. Turner and H&R Spacers with their own integrated hubcentric lip are: 10mm, 12mm, 12.5mm, 15mm, 18mm, 20mm, 25mm, and 30mm. * -- Note that H&R and Turner Motorsport each make a 10mm hubcentric spacer but due to interferences between the spacer and lip, it's best to leave this to specialized applications. See below for more detail. 10mm Fitment Notes You must be very careful when fitting 10mm spacers to any BMW. Since the depth of the hubcentric lip will vary, you risk bottoming out of the spacer before it sits flush with the hub. This will leave a gap between the spacer and the hub, seriously compromising the strength of the spacer. The lip on the car must be shaved down so the 10mm spacer will fit flush on the rotor hat. I fitted 10mm spacers and they seated correctly for me. But I've yet to track them... Karl.
Stock – 997.2 C2S Coupé • Carrara White / Cocoa • Adaptive Sports Seats • PDK w/SC • PSE
Mods – Front 996-GT2 and Rear 997-Turbo Brake Ducts • 3rd (center) Coolant Radiator • 10mm/15mm Spacers |
02-23-2016, 12:42 PM | #3 |
California-bound
385
Rep 1,480
It's fine. I use a 5mm spacer front and rear without issue.
Streets of Willow: 1:27.7 CW 11/15/15; 1:29.5 CCW 8/15/15 |||| Autoclub Speedway ROVAL (CCW): 1.52.6 - 12/2/17
Willow Springs - Big Willow (CW): 1:35.8 - 3/31/18 |||| Buttonwillow #13 (CW): 1:59.3 1/27/18 https://www.facebook.com/JakeStumphRacing |||| http://www.youtube.com/user/RaceMeMZ3 |
02-23-2016, 05:07 PM | #5 |
828
Rep 2,232
02-23-2016, 06:07 PM | #6 | |
77
Rep 359
Ok to be clear: 5mm and below for flat spacer and then 12mm+ for hub centric spacers is safe for any kind of driving. correct? Anything above 5mm you're bushing it with barely getting a hub, and and anything below 12mm you'r risking flat fitment, correct? |
02-23-2016, 06:46 PM | #7 | ||
223
Rep 542
02-23-2016, 08:58 PM | #8 |
827
Rep 3,856
Never had an issue with VAC Motorsports 10mm spacers. Buy quality
https://store.vacmotorsports.com/vac...mws-p3459.aspx |
02-23-2016, 09:32 PM | #9 | |
223
Rep 542
02-24-2016, 08:47 AM | #10 | |
2289
Rep 12,565
Drives: Z4 M, X5, GX460
02-24-2016, 03:50 PM | #11 | |
77
Rep 359
02-24-2016, 04:23 PM | #12 |
30
Rep 160
Drives: 2010 128i
I run H&R 5mm spacers on the front of my car and have raced for years on them with no issues. Take a look at different spaces available. I don't think my 5mm completely covered the centric ring on the hub, and there is a chamfer cut into one side of the spacer so that it sits flush up against the rotor. Make sure you put the chamfer IN so it sits flat.
Some of the thicker spacers have a counter sink cut into the backside w/ a chamfer so the centric ring on the hub goes completely in and there is a new centric ring on the outside of the spacer. The TMS spacers are the same as the VAC ones. http://www.turnermotorsport.com/p-43...lications.aspx Buying extended wheel studs for whatever size spacer you buy should go w/o saying. I AutoX with a guy that rans a setup like this on his evo for massive spacers. His wheels have not fallen off yet.
02-24-2016, 08:58 PM | #14 |
827
Rep 3,856
Not sure what you mean. The 10mm spacers I use from VAC have plenty of lip on them.
02-24-2016, 09:04 PM | #15 | |
827
Rep 3,856
02-24-2016, 09:06 PM | #16 | |
2289
Rep 12,565
And that is based on YOUR experience but that may not be the case for someone else. The question isn't about the specs/tolerances to which VAC or others build their spacers. It's how yoru CAR's hub lip may be different than someone else' BMW. |
02-24-2016, 09:10 PM | #17 | |
827
Rep 3,856
02-24-2016, 09:21 PM | #18 |
2289
Rep 12,565
BINGO
02-25-2016, 11:36 AM | #19 |
828
Rep 2,232
02-25-2016, 12:32 PM | #20 | |
30
Rep 160
Drives: 2010 128i
If you are only getting the vib above 70mph that might just be a wheel balance issue too.
02-25-2016, 06:38 PM | #21 | |
828
Rep 2,232
