02-22-2016, 10:24 PM | #1 |
543
Rep 1,338
Drives: Round n' Round
Main Fuse Location Help? /completely lost all power
My dumbass forgot to to disconnect the battery terminal when I was working on the car, I accidently touched a wrench to the positive Battery post under the hood, next thing was a big spark and now absolutely no power to anything.
Anyone know where the main fuse is located (I am guessing trunk area?), amp rating and/or a part number would also be very helpful? thanks in advance |
02-23-2016, 07:32 AM | #2 |
158
Rep 381
Drives: 2022 G82 Xdrive
located underneath trunk center cover.
just happened to find out yesterday but not so sure about amp part. |
02-24-2016, 07:09 AM | #3 |
1594
Rep 3,945
Drives: 2015 M4 MG/SO
There are three fuse box locations, one in trunk area underneath the carpet (Z2), and the front fuse/relay module (Z7) in front passenger side in engine bay behind glove box (you have to remove the plastic cover with the battery positive cover, unscrew three plastic screws CCW 90deg, remove plastic rivet) and the third one is the battery fuse block (Z3?).
In the rear fuse box, there's a paper with some description, but don't think there's anything relevant there. Just thinking out loud, check the battery voltage at the battery with a multimeter. There's an internal battery separating switch inside the LiFePO4 battery that protects it from short circuit by opening, and assuming no fuse/relay/xxx blew, the only way to close it again, is to apply a lithium approved charger to the battery which can detect low voltage (<0.5V) or a booster pack. It is possible that there's no blown fuse, as the hood positive terminal is most likely directly connected to the battery? FYI: always have a wrench protected with insulated tape when working around battery or power posts. Voltage Supply System Last edited by aboulfad; 03-08-2016 at 03:18 PM.. |
02-24-2016, 11:23 AM | #4 |
1594
Rep 3,945
So what happened, Is ur car still dead? And BTW, clicking the appreciate button too many times won't do any good
02-24-2016, 11:37 AM | #5 | |
BimmerPost Supporting Vendor
8249
Rep 18,839
Drives: BMW
You can try powering up the car with a charger on the underhood terminals and read/clear codes through OBD2, which should reset the battery. Otherwise, it will need to be reset at your dealer.
02-24-2016, 11:43 AM | #6 | |
1594
Rep 3,945
02-24-2016, 01:13 PM | #7 | |
543
Rep 1,338
I re connected the battery lead & everything worked... the only remaining issue is now the drivers side window will no longer come down 1/2" as its supposed to when I open the door....so if I close the door with the window all the way closed it it sticking up to high and hits the door frame. Is there a reset procedure for the door window that I can do or must a dealer do that? |
02-24-2016, 01:15 PM | #8 |
543
Rep 1,338
Just FYI in case anyone needs know there is a second fuse box under the hood passengers side along with the one in the truck area
02-24-2016, 01:59 PM | #9 | |
1594
Rep 3,945
02-24-2016, 02:28 PM | #10 |
8249
Rep 18,839
Drives: BMW
It works, same procedures for window initialization since 1999.
