02-21-2016, 01:38 PM | #1 |
15
Rep 50
do f10 m5 wheels fit f13 m6
i have a pair of bbs fi for my f10 that i sold now i purchased an f13 m6 i want to know will those rims fit ??? help plz
02-21-2016, 08:01 PM | #3 |
371
Rep 915
Drives: ///M's
They will fit but you probably need to add 10 or 12.5mm spacers
02-21-2016, 08:22 PM | #5 |
15
Rep 50
02-21-2016, 09:39 PM | #6 |
Plenipotentiary
2614
Rep 3,046
Good quality spacers are perfectly safe. The fronts (if you have the FI-R 20x9.5 ET28) are ok as is. The rears (if the FI-R 20x10.5 ET28) will fit and clear the strut, but will sit further in than the OEM wheels. Will need a 10 - 15mm rear spacer for aesthetics.
02-22-2016, 01:49 AM | #10 | |
Plenipotentiary
2614
Rep 3,046
Awful. It's very difficult to tell visually, but the distance between the wheel faces on the OEM setup is slightly wider in front than in the rear. 10.5ET28 on the rear is 9mm further inside the body and is enough to be visually displeasing. Will they clear the strut? Yes. There is quite a bit of inner clearance even under full compression (though not near as much as a non ///M. Rear axle carrier on Fxx M5/M6 is carried over with little modification from E6x M5/M6 with shorter output shafts so the geometry is a bit different below the upper mounting points) Would I suggest it or put it on my car? Nope. Just looks wrong. |
02-22-2016, 02:42 AM | #11 |
Plenipotentiary
2614
Rep 3,046
This very early F10 M5 Prototype is about the same visually as the 10.5ET28 appears on an M6. The camouflage panels bring the body width to within a couple of millimeters of the production M6. The front fenders are also not extended under the camouflage and approximate the front appearance as well with the camouflage panel thickness applied.
02-22-2016, 10:39 AM | #12 | |
1125
Rep 6,071
If you are talking about the custom rims then you need to make sure the offset is in range.
Current : 2020 F92 Black Sapphire M8 - ZF8
Gone : 2018 F80 Mineral Gray M3 - 6MT Gone : 2016 F82 Austin Yellow M4 - 6MT Gone : 2013 F13 Sakhir Orange M6 -7DCT Gone: 2013 F13 Alpine White 650i -ZF8 |
02-22-2016, 10:53 AM | #13 |
51
Rep 95
02-22-2016, 05:33 PM | #14 | ||
Plenipotentiary
2614
Rep 3,046
02-22-2016, 10:45 PM | #15 | |
15
Rep 50
and the rear are 20 x 10.5 28ET i dont mind putting spacers to make it look nicer i just want to make sure they will fit being said i spend 9grand on them and just sold my m5 id like to use them on my new m6 im not good with rims and offsets and that stuff im clueless lol |
02-22-2016, 10:46 PM | #16 |
15
Rep 50
02-23-2016, 09:25 AM | #18 |
51
Rep 95
You have one life to try them all, beauty of cars is you can get another one if its not for you. Silverstone is a pain to clean from denim transfers etc, I use to have an E93 M3 interlagos blue on bamboo, and I would be cleaning the seats day and night..
02-23-2016, 01:20 PM | #19 |
1316
Rep 2,349
