ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Wheels and Tires
  TireRack
      03-02-2008, 10:19 AM   #1
Ripinto
Ripinto's Avatar
Drives: M3 Convertible
Torque specs for wheels
Does anyone know how many pounds of torque are recommended when tightening the bolts on the wheels of a 3.0i BMW z4?
Thanks.
      03-02-2008, 10:41 AM   #2
nyczyang27
nyczyang27's Avatar
31
Drives: z4 3.0si / 328xi
120 NM - 88.5 ft pd
2007 Z4 3.0si Step/Premium/Xenon/HeatedSeats/AutoTop/M6Wheels
2007 328xi Step/Premium/Sport/Xenon
      03-02-2008, 11:15 AM   #3
Ripinto
Ripinto's Avatar
Thanks nyczyang27
      03-02-2008, 12:57 PM   #4
jmillet
jmillet's Avatar
64
Drives: 2023 Hyundai IONIQ 6 SEL AWD
110N*m to 130N*m
TIS calls out 120N*m plus or minus 10N*m. That's 81ft/Lbs to 96ft/Lbs. Most 1/2 inch drive clicker-type torque wrenches aren't that accurate anyway so pick your number somewhere in the range.
Jim Millet
2023 Hyundai IONIQ 6 SEL AWD Ultimate Red
SOLD: 2007 BMW Z4 M Coupe Imola Red
      03-02-2008, 11:02 PM   #5
Zeddy4Me
Zeddy4Me's Avatar
South Korea
24
Drives: 09, AW E90 M3 6MT
always have mine at 85 lbs
      03-02-2008, 11:23 PM   #6
BlackSapphireZ
97
Drives: 22 GLE 53 Coupe
90ft-lbs is pretty standard
I like mine tighter though
2022 GLE 53 Coupe
      03-03-2008, 01:34 PM   #7
mPlasticDesign
mPlasticDesign's Avatar
684
Drives: BMW 230i Msport w/LSD
Location: Astral Projecting: ∞ 23.516 -122 02.625 0242.101 ĕv'rē-hwâr'
88ft-lbs
      03-03-2008, 05:12 PM   #8
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
Drives: 2007 M Coupe
1 million ft-lbs!!! hahaha JK
07 ///M Coupe (Premium Package) Black Saphire Ext. Imola Red Int.
Best Website EVER!
      03-05-2008, 09:34 AM   #9
Ripinto
Ripinto's Avatar
Thanks for all your replies. Very helpful.
      03-10-2008, 02:31 AM   #10
Mug
Drives: 2010 Audi S4
Always better to have tight nuts then loose nuts
      05-05-2008, 07:51 AM   #11
CalZ4M
CalZ4M's Avatar
Drives: 2007 Z4M Coupe
Always tighten when wheels, etc are cool. Never when hot.
      05-05-2008, 01:48 PM   #12
Reach
gone baby gone
382
Drives: 2016 F80
Dammits reply was clearly the most helpful. Seriously what value does that add?
Just piling on, I keep my wheel torque wrench at 85lbs, and also remember to tighten them in a star pattern to help avoid them loosening over time. More force is NOT always better, as you can be damaging the lug or its seat in the wheel if you over-tighten it. If you do that, they are eventually going to work loose anyway. Or the worst case scenario, which is shearing off a lug.
      05-05-2008, 03:21 PM   #13
ianbiz
Back in a BMW
ianbiz's Avatar
205
Drives: 2015 335i Msport
Originally Posted by ///Metak View Post
88ft-lbs
+11111111111111111111111111111111
Ian
      06-10-2008, 07:31 PM   #14
RichardTS
RichardTS's Avatar
Drives: 335i E92 & Z4 M
I would presume that the torque spec is for dry (no oil) threads. Since the whole purpose of torque is to tension the stud, wet (oily) threads can result in as much as 40% more tension than dry. Depending on the design factor, this may cause the bolt to fail in shear when tightening.
If your bolts are rusty, it is ok to clean them up with some oil - just make sure you dry the threads before tightening.
      06-10-2008, 10:05 PM   #15
GP20
95
Drives: Z4M, F80 M3, 991.2 GTS
Bad idea to keep your torque wrench at 85lbs constantly. You want to set it back to 0 after you use it, or the torque wrench will fail prematurely.
2019 Porsche 911 4 GTS
2016 BMW M3
2008 BMW Z4M coupe
      06-11-2008, 08:15 AM   #16
Dammmittt
My favorite sign.
Dammmittt's Avatar
South Korea
169
I hadn't seen this post before.
Best Website EVER!
zpost
