02-16-2016, 10:52 PM | #1 |
100
Rep 341
What is this piece I found in the trunk?
SOLVED!
I found this piece rolling around in the trunk of my M4 cab. I looked everywhere and I can't figure out where it came off of. There is no part number and the only writing is "ABS,TPE" The raised part in the centre is some kind of high density rubber with little grip. It looks like it's suppose to hinge on to something... My dealer doesn't know where it goes and the BMW tech doesn't know where it goes.. Is it even from the car? Thanks in advance! Last edited by e82m_van; 02-17-2016 at 01:14 PM.. Reason: solved |
02-16-2016, 11:02 PM | #2 |
66
Rep 863
Check http://www.realoem.com lol
02-16-2016, 11:07 PM | #3 |
Sunburned
238
Rep 1,097
Drives: '16 F83 M4 Convertible 6MT
its a TP holder for the passengers!
lol JK srsly i have no idea.
2016 M4 Convertible 6MT - SO/SO
2013 535i 6MT MSport - Retired 2011 Z4 SDrive35i 6MT- Retired |
02-16-2016, 11:12 PM | #4 | |
100
Rep 341
I'm actually in the process right now of going through realoem |
02-16-2016, 11:30 PM | #5 |
68
Rep 101
Clearly that is the Left blinker fluid reservoir cap. You should have two of them, one on the Left, your's is obviously missing its cap, and one on the Right. They are hard to see and are located just aft of the rear deck speakers on the M4's. On the M3's they're a bit trickier to locate as you have to remove the trunk ballast panel directly behind the rear seats.
As I'm sure you're aware, blinker fluid has an extremely low enthalpy of vaporization and therefore will likely require a top off. I'd strongly suggest the Motul RBF Factory Line fluid! Best of luck and happy motoring! |
02-16-2016, 11:34 PM | #6 | |
100
Rep 341
02-17-2016, 12:45 AM | #7 |
Sakhir Smurf
314
Rep 594
Drives: Plaid, F82 M4, E46 M3, Sequoia
excess weight
2015 M4: Sakhir on Sakhir | M-DCT | Adaptive Suspension | Lighting | Executive | Cameras | HK Sound | Full Leather
2004 M3: Laguna Seca Blue | SMGII | Basic track mods: 18" Square setup on R888s / Performance Friction rotors / SS Lines / Ground Control Street/Track Kit / DTC-60 Pads NASA NorCal Instructor |
02-17-2016, 07:51 AM | #11 | |
122
Rep 595
02-17-2016, 08:25 AM | #12 | |
29
Rep 90
02-17-2016, 01:12 PM | #13 | |
100
Rep 341
Thanks for pointing me in the right direction! It was the left side holder for the windscreen which gets folded behind the rear seats! |
