02-15-2016, 03:39 PM | #1 |
1103
Rep 7,063
MPE Installed: Ruined my X5; am I crazy?!
Installed it last week waiting on black finishers from Ben (Yes he can get em and paint for you) Only drove it about 100 miles and thus far I am not enjoying my quiet luxury SUV now.
Let me explain myself. It sounds badass on the exterior cannot complain one bit. But the interior may need sound insulation tape. Between 1700-2000 rpm in comfort mode I am experiencing drone at load (Highway speed pulling/passing). Now before anybody says stop being anal with reading countless threads I'm surprised nobody commented about it. When kept in sport or sport + (never needed use) there is no problem since it keeps itself over 2000rpm when passing or you miss that pitch of the exhaust from a standstill. Now for the resolution which I am in need of help. My car has no space saver in the boot. So it is an empty hollow space that needs to be insulated with black foam tape or needs a space saver in the trunk to help seclude exhaust noise into my cabin. Because sport mode isn't exactly activated every time I start my truck Taran.j
E90 Build Thread (SOLD) http://www.e90post.com/forums/showthread.php?t=809436
F15 Build Thread (SOLD) http://f15.bimmerpost.com/forums/sho....php?t=1064084 |
02-15-2016, 03:53 PM | #2 |
110
Rep 525
does that mean that without the finishers, the exhaust terminates before the bumper outlet? so the pipes dont protrude past the bumper?
i have a drone in the same range only when in comfort. eco pro-sport-sport + all fix the drone by keeping it out of that range....i HATE drone.... i love HELLA LOUD EXHAUST. im satisfied. sounds like your stuck with that drone on that exhaust, its just the nature of it...then again i am in sport+ almost always unless my GF is in the car, then its Sport with only the chassis tightened, not transmission.
02-15-2016, 03:59 PM | #3 | |
1103
Rep 7,063
I completely agree with you just have to deal with it. But reading and watching cabin videos I knew it was too good to be true haha
02-15-2016, 03:59 PM | #4 |
290
Rep 1,547
Performance exhaust...nature of the beast my friend. Just get in the habit of running around in Sport mode...first thing I do when I fire it up, boom...sport mode. It should get slightly better once the tips are on, as the sound will exit from behind the vehicle, not under it.
2014 BMW X5 xDrive 35d M Sport Mineral White
2011 BMW 135i M Sport Space Grey 2007 Suzuki GSX-R 750 |
02-15-2016, 04:02 PM | #5 |
478
Rep 1,363
http://www.amazon.com/gp/aw/d/B00020...ywords=dynamat
People use that if they have expensive audio equipment to keep road noise out or if they have a loud exhuast. I used it in my g35 when my exhaust had a lot of drone. The best way I can describe it is a rectangular foil pad with a tar like substance applied to the back. It has a wax paper backing that you peel off. The correct way to apply it is to remove the carpeting in your car and the slap the tar side directly onto your panels. I didn't want that messy stuff all over my car so I just spread out the pads (with wax backing attached) in my spare tire well. Since you're only covering a small Surface area, your not going to catch all the noise, but with the small amount of exhaust from he MPE, I think it should do the trick. |
02-15-2016, 04:04 PM | #6 |
290
Rep 1,547
+1 for Dynamat...great product.
02-15-2016, 04:17 PM | #7 |
1103
Rep 7,063
Exactly what I was thinking of lining the trunk storage compartment after removing that grey carpet liner since it's just hallow down there.
02-15-2016, 07:49 PM | #8 |
3240
Rep 5,066
Wow, first I've heard of this issue on a MPE. I'm perfectly happy with mine but as with anything, not everyone is the same..
2015 F15 X5 35i Msport Space Grey M Performance parts MPPK, MPE
02-15-2016, 07:57 PM | #9 | |
1103
Rep 7,063
But hopefully installing the tips to protrude out of the bumper instead of my old ones. Installing some Dynamat I'm hoping for some reduction. Second step will be buying a space saver spare since I'll be changing to non run flats soon anyways. To fill up that dead space.
02-15-2016, 07:59 PM | #10 |
12971
Rep 18,716
Drone is subjective to each individual.
The older you get, the stronger you will become sensitive with lower frequency and less sensitive to high frequency, hence how our parents always complaining with our bass thumping speaker, yet they are listening to their music with a maxed out treble setting.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
02-16-2016, 08:26 AM | #11 |
5450
Rep 8,815
I think the main reason why you are getting drone is because you don't have the tips for the mufflers yet and its being let out into the spare tire cavity of the car.
While i'm not a huge fan of the way my MPE sounds on the road either it does not drone at all. Asiding from the popping in Sport mode nobody even knows I have an exhaust on the X5. Alan
02-16-2016, 10:24 AM | #12 | |
110
Rep 525
02-16-2016, 10:37 AM | #13 | ||
1103
Rep 7,063
The passenger side is my main issue. The driver side one sits fine
02-16-2016, 01:43 PM | #14 |
4440
Rep 5,733
Drives: '24 iX50; '23 i4 M50
I don't have drone with mine either
I love the sound
'24-I20 iX 50; '23-G26 i4 M50; '22-G82 M4Cx*;20-G05 M50i*; '20-F82 M4CS*; '18-F80 M3CS*; '18-F80 M3CS*; '18-F85 X5M*; '18-G01 X3M40i*; '18-F80 M3ZCP*; '17-F80 M3ZCP*; '15-F15 X5*; '15-F82 M4*; '12-E92 335is*; '11-E70 X5d; '11-E89 Z435is*;'09-E89 Z435i*; '08-E92 335i*; '06-E90 330i*; '05-E83 X3*; '04-E83 X3*; '03-E46 325Ci* *retired |
02-16-2016, 03:14 PM | #16 | |
1103
Rep 7,063
Yeah that's going to be my next report
02-16-2016, 03:24 PM | #18 |
3240
Rep 5,066
Mine was installed last summer, so its been a while but I don't recall any droning at all the first day with eco-pro, comfort, and sport settings. Just recently when I was driving in Eco- pro just to see how much gas I would save, I did notice a slight drone ( I think because in Eco pro the RPM is in a lower range than other driving modes). But even this slight drone wasn't an issue for me.
02-16-2016, 05:41 PM | #19 |
478
Rep 1,363
I didn't read your original post carefully enough. Didn't realize you didn't have the tips on yet. I had the same experience on my old car when I couldn't decide on what style tips I wanted
It was loud as hell inside but once I put some tips on, inside noise became much more tolerable. Once you get your tips in the mail, you probably won't even need the dynamat. |
02-16-2016, 05:57 PM | #20 | |
1103
Rep 7,063
02-18-2016, 06:30 PM | #21 |
Rep 49
I just got my car back with the MPE/finishers and the drone is barely noticeable to me. It could be that I have 3rd row seats, but hopefully the finishers help you.
02-19-2016, 09:29 PM | #22 |
#dubspec
6336
Rep 5,201
i have zero drone.
LCI ///F80 M3 Individual Atlantis Metallic / Black Full / Carbon Cermics / 6MT
MPE / M Performance & Carbon package / KW v3 / 20" HRE R101LW / 20" HRE 527s / Michelin PSS / 20% tint / 3d Design / Streckenn splitters / OEM GTS hood / EAS Carbon seatbacks / Carbon RKP sideskirt / Bootmod3 / M Performance Tri color alcantara / AWE S Flow instagram: @ dubsesd |
