02-10-2016, 12:00 PM | #1 |
1032
Rep 1,997
need alignment or normal wear?
well, I am pretty sure this is not what you would call normal wear, but I remember reading somewhere in a thread that someone had a similar wear pattern on their rear tires. This set of tires has about 14,000 miles on them, a couple of track days (in the wet), a couple of dry autocrosses, but mostly commuting. the tread depth ranges from about 4.5/32 to 2/32.. both right and left tires are very similar in depth and manner of wear. Car is totally stock suspension wise, just added a tune recently though. it's also been in the 30-50 degree(F) range the last month so traction had been a concern. laying down and viewing from the rear I see some significant wear getting much worse on the outbound side of the tire... not sure if I've been running a little under-inflated as it almost looks a little cupped but that may be an illusion here... the wear bars make it seem like the wear is in a more tapering pattern from inner-outer.
I searched and couldn't find the post about yhe guy with what I remember to be wear in this pattern.. search feature isn't working for me on multiple devices so wanted to start a new thread. pictures are often worth thousands of words ... top=passenger rear; bottom=driver rear thanks for any input!
Gone but not forgotten: '09 STi // '08 335i // '02 M3 // '11 335i // '15 M3 // '16 M3 // '16 Camaro SS // '16 Audi S3 // '18 Boxster 718S // '17 Camaro SS 1LE // '16 M6 GC CP
02-10-2016, 06:50 PM | #3 | |
1032
Rep 1,997
is it worth flipping the tires on the rims? I assume that's not something most people do with inside/outside tires but how important is that REALLY. I just hate being wasteful if I can avoid it. if this is typical, I almost want to run a square setup! that's some pretty crazy wear and so uneven (to me, a non-expert...this is the first set of tires I've replaced due to wear.. forgive my ignorance!!) thanks again!
02-10-2016, 06:54 PM | #4 | |
10785
Rep 8,852
Drives: '15 SO M4/'20 Z4 M40i
Tejas Chapter, BMW CCA, mem #23915, President 27 years, www.tejaschapter.org
02-10-2016, 07:37 PM | #5 | ||
1032
Rep 1,997
it makes me feel a little better seeing it similar on both sides, but like I said, I have never kept a car, let alone an M car, long enough to watch the tires wear all the way down. I'm a newb at replacing tires. that's why I'm seeking your counsel!
02-10-2016, 07:38 PM | #6 | ||
1032
Rep 1,997
02-10-2016, 07:48 PM | #7 |
6580
Rep 5,304
The uneveness isn't crazy but I imagine the wear on the outside is due to your track/autocross events.
You probably want some negative camber if you're gonna continue with the track/autocross events. |
02-10-2016, 08:21 PM | #8 | |
1032
Rep 1,997
i was a little surprised to see this on the rear but I'm glad you all are not alarmed. maybe I need the negative camber for street driving. I'll press on with some new rear tires only for now and check whatever I get at shorter intervals to see how they are doing. I can make adjustments as needed. thanks for the input!
02-10-2016, 11:00 PM | #9 | |
14
Rep 27
