02-07-2016, 03:02 PM | #1 |
Full Potato
338
Rep 410
Offset and Brand Question - Help
All,
Looking into new summer wheels and using my stock 19's as my winter set. I like the overall offset when stock wheels are used with 12/15 or 15/18 spacer set ups. Would like to run 305's in the back and 255 or 265 up front. Ideally I'd find a better quality wheel with similar looks to the Enkei Raijin in black with a deeper concave look. Raijin is posted below. Any ideas? Will also be installing a KW HAS kit at the same time on the adaptive M suspension. Not going much lower in the rear but maybe 1" or so in the front to clean that up a bit. |
02-07-2016, 08:32 PM | #2 |
708
Rep 1,405
I'll recommend getting something and/or matching with forged wheels. The only wheels that comes to mind or is close to the Enkei you mention above will be the BC Forged RS 40 check the link below. Now regarding the width and offset you can pick pretty much anything with them, including the finish brush or matte/flat colors..
I hope it helps !! http://www.bcforgedwheelsusa.com/RS-40.php |
