01-13-2016, 07:36 PM | #1 |
129
Rep 346
VFF-102 20", 265/30 or 275/30 PSS? Help!!
Hi guys,
Sorry to be a pain on a trivial matter, I'm about to pull the trigger on some 20" Vorsteiner VFF-102 in Carbon Graphite and i have spent almost a week going between tire widths. The wheels measure 20 x 9.5 and 20 x 10.5 for the front and rears respectively! Vorsteiner themselves recommend 265/30 Front, 295/30 rear, but i have seen all sorts run on these. I will be going for Michelin PSS. For the rears i have settled on 295/30 (up for debate) as i like the beefy look in the rear and there should be no clearance issues but fronts I'm debating between 265/30 & 275/30. The roads here in the UK are terrible and so I'm looking to also swap my H&R sports springs for KW HAS so please bear this in mind! What do you guys run and what would you recommend? How (if at all) will the handling be affected between the two? Im new to changing wheels so i would like to gain the most out of handling characteristics. Will i really notice a 3mm increase in the sidewall between 265/30 & 275/30? Many thanks, and sorry for the super long-ass message. Here's the car for your viewing pleasure!
01-13-2016, 07:49 PM | #3 |
Supreme Leader
2284
Rep 6,548
Drives: G80, 996GT2, 996TT, 991RS 356b
Here is a car that we did a couple months ago on VFF 102 275/30/20 front
The car below is on the HAS kit as well, but is running a 3mm spacer up front. With the HAS kit you will need to run the 265/30/20 to clear the large perches.
SupremePOWER
1562 Kimberly Ave Fullerton CA 92831 Contact: sales@supremepower.com :: Shop# (714)632-1951 Sales & service of BBS Street & Motorsport products. BBS Highest Volume Dealer 2015 thru 2022 All the top brands at the prices and service you can count on. Professional installation. |
01-13-2016, 07:56 PM | #4 | |
129
Rep 346
What would you guys as a shop, recommend and why?
01-13-2016, 10:13 PM | #5 | ||
710
Rep 1,405
01-14-2016, 01:12 PM | #6 |
236
Rep 838
I've been thinking about the HAS kit for my M4 but I saw in another thread that 275/35/19 (which I currently have on the oem front 19's) wont work with the HAS. This car pictured is running 275 fronts with a 3mm spacer and it works. Wondering if you know if a spacer will work with the HAS on the oem 19's w 275/35/19 up front. Thanks
19 MBB M5C
16 Yas MarinaM4 (gone) 05 E46 M3 HPF/ProEfi Stage 2.25 (Gone ) |
01-14-2016, 01:14 PM | #7 |
236
Rep 838
what do you mean you cant run 275? The picture is a 275 front with a 3mm spacer. Looks like that works to me.
19 MBB M5C
01-14-2016, 02:04 PM | #8 |
BimmerPost Supporting Vendor
2921
Rep 21,727
Here is our car
We are running 275/30/20 and 295/30/20 dropped on KW clubsports. Wh have the Pirelli's which might run a little narrower than the PSS's so I would say its close with a HAS kit and spacer. I would lean more towards a 265 if you go with the PSS's.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM Last edited by kevin @ eas; 01-14-2016 at 02:14 PM.. |
01-14-2016, 05:27 PM | #9 | |
129
Rep 346
Yeah i think 265 it is then as ill be going for PSS! The reason I'm switching from H&R to KW HAS & 20s is mainly for ground clearance! I am hoping it helps, do you have any idea or could you measure how far the front is off the ground on your AY M4? This is mine currently:
01-14-2016, 05:34 PM | #10 | |
129
Rep 346
