01-06-2016, 02:30 PM | #1 |
413
Rep 1,178
My experience on using 0% ethanol 93 gasoline
My M3 used 10% ethanol 93 gas ever since BMW delivered it to me from factory 2 years ago. Today for the first time i experimented on a full tank of ethanol free 93 gas from a BP station. I waited until i was driving on the reserve to get rid of most of my previous gas. I had probably only 12.5% of E10 gas left. After filling up i should be close to pure gasoline.
Here are my raw feelings on driving the car for the next 1 hour highway and city driving. - Is this my car or what ??? Wow. Engine freed up a lot. Throttle response improved, picking up speed is stealthier (more on that below). The engine does not seem to be battling the fuel, it works seamlessly. Engine feels much more refined and better balanced. - The sound is different. I got very accustomed to my engine sound when running E10 and I noticed after running ethanol free that gurgling (guttural) sounds in mid throttle are gone replaced by a much more pleasant jet like engine sound with more deep bass is how i can best describe it. - Engine runs noticeably smoother in lower gears which makes the car much more fun to drive. It will change your appreciation of the car. - I paid 25% higher price tag - $3.27/gal compared to premium E10 cost $2.6/gal at the same BP station - but that is not how you do the comparison you have to compare your mileage. I usually get 16 mpg on E10 in my city/hwy driving. I reset the onboard mpg calculator and over one hour after filling up i watched the mpg number while driving spirited. I crept up from 17, 18, .. all the way to 21 and stayed there and i was doing some accelerations noticeable by other drivers. That is a 23.5% improvement. So effectively i am only paying 1.5% more or 4 cents / gal for ethanol free 93. The engine is much much happier there is no doubt about that. It seems it delivers with less effort so i find myself at faster speed without even lighting up the angry side of the engine. Last edited by Rajmun340; 01-06-2016 at 02:35 PM.. |
01-06-2016, 02:37 PM | #2 |
Rep 38
I wish I could get 93 octane E0% close to me. Did find a pump with 90 octane E0% near me and like you, I did notice a very slight throttle response (not sure it was not a placebo effect) but did sound like the induction noise through the midrange RPMs was different. Ran 10 gallons 10 of 90 octane E0% and 5 gallons of E10% 93 octane. The E0% was a significant premium over local E10% $3.09/gal vs. $2.29/gal. Not sure it is worth it at that price difference.
01-06-2016, 02:44 PM | #3 |
Retired Curmudgeon
2985
Rep 4,047
Interesting. Let's see how things shake out over time.
The following is not personal commentary on you (or an attack), so please don't take it that way. However, to be totally objective we should consider the following: For some real fun, give your credit card to a friend, let them fill your car up for you with one or the other and then see if you can discern a difference. Then do it again and see if you notice a difference or not. Double blind testing (or dyno testing) are objective tests. When you spend more $$$, you want to get "better" stuff. Plus, you expected better performance from the pure 93 than the 10% ethanol 93 and it's exactly what you got. Perfect example of "confirmation bias". Again, not an attack on the OP or a statement of disbelief of his findings, just an objective way to look at this (and any other mod on your car). FWIW, I believe the OP got better performance. Ethanol has less energy content than gasoline, that's not up for debate. I wonder how fast the ECU adapts to different fuels? Hell, I wish I could get 10% ethanol 93 in Vegas at the pumps, but we can't because California. <sigh>
'19 X3 M40 Carbon Black/Oyster, '23 Jeep Grand Cherokee L Summit, Past BMWs: '18 M550i, '18 330 GT, '16 X5 40e, '11 E90M3, '06 X5 4.4, '03 330i ZHP, '02 M3, '97 Z3 2.8, '95 M3 (2x), '94 530i (manual), '92 525i (manual), '88 M3, '87 325iS |
01-06-2016, 03:06 PM | #4 |
Supreme Czar
309
Rep 779
All these amazing changes just from switching from E10/93 to E0/93? Dude, pass the joint my way!
01-06-2016, 03:10 PM | #5 |
5234
Rep 10,616
MPG takes a while to stabilize after reset. Ethanol is about 30% less efficient, so removing its 10% to fuel ratio is worth only a few % mpg improvement.
Butt dynos are of limited use. Would be interested in a real e10 93 vs straight 93 dyno. Doubtful any power differences sufficient enough to feel would show up. |
01-06-2016, 03:15 PM | #6 | |
4985
Rep 11,891
I'm not attacking OP either, but I read that Michael Schumacher was able to tell whether a different fuel was used on his F1 race car. That's coming from a professional driver, consistently driving the same track, on the same day, on the same equipment, in the same conditions...
22 Phytonic/Coffee X5 45e (CoVID-free)
08 Speed Yellow 911 GT3 Sharkwerks 12 AW/Cinnamon X5d Sports Pkg (retired) 14 AW/Beige M6GC ZCP, MPE, V2 steering wheel, vorsteiner (retired) 08 SSII/Black E90 M3 (retired) |
01-06-2016, 03:16 PM | #7 |
50
Rep 368
I've experienced the opposite, tuned on 91 with ethanol, cause that's all that was available. Then dyno again at home few days later on 94 with no ethanol.
End result; had to take timing away Last edited by Cidle; 01-06-2016 at 04:31 PM.. |
01-06-2016, 03:21 PM | #8 | |
413
Rep 1,178
What is subjective is the words that I used to describe how the engine runs on E0 but there is no doubt at all, the difference is unmistakable for the driver. A double blind is not prescribed. |
01-06-2016, 03:22 PM | #9 |
3431
Rep 6,771
Drives: 2016 BMW i8
Garage List 2012 BMW e92 M3 [0.00]
2021 BMW X5M [10.00] 2015 Porsche 991 Tu ... [10.00] 2015 Porsche 991 GT3 [10.00] |
Interesting. On the dyno I made a little more power on 91 octane (e10) pump plus 2 gallons of e85 than I did on (ethanol free) MS109 race gas mixed with some pump gas to blend to 96-97 octane with maybe e5. I've experimented with a lot of different fuels and didn't notice any of the attributes the OP mentions about my car behaving any different with lower ethanol contents.
Too bad we can't get e0 93 in Cali. Heck we can't even get 93 octane.
Current BMWs: 2022 X5 40i, 2016 X5 50i
2015 Porsche 991 Turbo S 1979 Porsche 911 Turbo (930) a couple others IG: longboarder949; YouTube: https://www.youtube.com/channel/UCT1...eoFBszPIK0gf9w |
01-06-2016, 03:23 PM | #10 |
368
Rep 1,198
Drives: 2021 F87 M2c. LBB, 6mt
I have never used ethanol laced gas in my M3, and (knock on wood) have not experienced the gas related issues i have read about on this form. The only gas I have put into my car is BP 91 octane E0.
2021 F87 M2c. Long Beach Blue over black with blue stitching. 6mt, executive package, slick top.
01-06-2016, 03:47 PM | #11 | |
413
Rep 1,178
My car is stock. |
01-06-2016, 04:32 PM | #12 |
3431
Rep 6,771
Drives: 2016 BMW i8
Hey sounds like your car likes it. If I were you I would do something like 5 tanks of e0 93 and then go back to e10 93 and see if you feel a difference again.
01-06-2016, 08:24 PM | #13 | |
Rep 38
01-06-2016, 11:11 PM | #14 | |
Retired Curmudgeon
2985
Rep 4,047
FWIW, I can get >21mpg (per OBC) per tankful cruising between Vegas and Phoenix or Tucson at some not so legal speeds and with aggressive 2 lane passing maneuvers. In the summer. With the AC on. No problem. If Phoenix traffic is iffy, then it can all go to heck very quickly and I'll stare at 18mpg all over again like on my daily commute.
01-06-2016, 11:38 PM | #15 |
1571
Rep 8,076
Drives: 11 E90 M3 Individual
I've used E0 91 octane. I did get 3mpg more on that tank otherwise it ran the same.
E85 is not like regular gasoline grades since it is not regulated. Gasoline is tightly regulated by federal and state agencies for quality and emissions. So E85 may be E60, E90 or something else. Proceed with caution.
2018 F30 320iX Melbourne Red
2011 E90 M3 Monte Carlo Blue 2004 E46 M3 Imola Red 2000 E36/7 Z3 Steel Blue |
01-07-2016, 09:45 AM | #16 |
550
Rep 1,148
Drives: 2008 BMW M3 Coupe
Garage List 2015 Jaguar XJ [0.00]
2015 Jaguar XF [0.00] 2014 VW GTI [0.00] 2008 BMW M3 Coupe [0.00] 2007 VW Passat 2.0T [0.00] |
The use of ethanol in fuel has nothing to do with energy conservation or clean air. It takes as much energy (and oil) to produce a gallon of corn-based ethanol as you can produce by burning it as fuel. The push to use it has everything to do with federal subsidies for corn. It is a travesty foisted upon us for absolutely no good reason, and it should be eliminated. Take away the subsidies and ethanol becomes less attractive economically than oil.
wfdeacon881105.00 |
01-07-2016, 10:46 AM | #17 | |
Supreme Czar
309
Rep 779
http://www.pure-gas.org/ is your friend. No puregas above 87 around here, so E10/93 it is. |
01-07-2016, 11:10 AM | #18 | |
Rep 38
http://www.ethanolrfa.org/wp-content...pdatedLogo.pdf |
01-07-2016, 11:46 AM | #19 |
81
Rep 734
I have been using E10 gasoline and E0 gasoline consistently and i can tell you in the M3, it makes little to no noticeable difference in terms of power and efficiency.
I live in Canada, and the US border is only "quick" 20mins drive away from where i live. I used to visit US almost weekly to pick up items i purchased online at a post office when CAD is almost a parity with USD (I missed the good deals and the savings on cost of shipping a lot... CAD is super crappy now @0.7113 USD). When i am there, i always filled up at the local Shell/Chevron which only offered E10 92 octane. I track my fuel mileage on fuelly, and with doing that for almost two years, i averaged around 17mpg (i drive 90% city, 10% highway approximately). When CAD turned into sh*t, i started fueling up locally at the Shell/Chevrons over here Canada side. Shell offers E0 91 octane and Chevron offer E0 94 octane at basically all the locations. Been putting in both of those for about year and a half now, and the fuelly tracker averaged around 17.5mpg. The better fuel economy could be due to many factors. Power wise, many locals claims that Chevron E0 94 octane produces the best results, but i honestly cannot tell the difference at all whether on streets or track. As previously noted by another member reply, if you did consistent testing with the same vehicle, same track, same conditions, you might be able to slightly differentiate E0/E10 with the M3, but for DD, i really didn't see the difference. HOWEVER, that is not to say that on some vehicles it makes a huge difference. On my previous tuned E90 335i, because of its boosted nature, running gas with E10 is preferred. Many ran it with mixture of E85 and yield much better results on dyno and track. Fuel economy obviously suffered due to the fact that it burns ethanol much faster. On my garage queen a old 94' Acura NSX, i did similar tests as well to run E10 vs E0, and boy did the E0 make the car run "better" in terms of power. Older cars were never designed to run Ethanol, and the NSX loves pure gasoline much more and is quite noticeable in terms of power (could be placebo) and mileage. (get around 10%-15% more per tank based on fuelly!!). Personally, i will run E0 if i had the choice because why not (unless cost is a concern). Chemically it produces more oomph than Ethanol mixed gas, and i never liked to idea of Ethanol in gasoline to begin with. Run a longer test as suggested by many and report back! Cheers! =D
94' NSX - Garage Queen
97' Integra Type R - Track Warrior (Sold) 01' BMW E39 M5 (Sold), 2x 02' BMW E39 M5 (Sold & sold) 08' E90 M3 6MT - DD 13' W212 E63 AMG Wagon |
01-07-2016, 06:28 PM | #21 | |
413
Rep 1,178
** Update **
-cold starts: Driving off on very light throttle i was accustomed to some mild hesitations in 1st gear on a cold engine which i have easily learned to eliminate with the clutch. There were some mildly embarrassing moments when i was new to the car. Giving more gas or releasing the clutch avoids this (6MT). I have to go through a pedestrian area to the access the road or I may not have notice that. I never questioned this with E10 93 from day 1. With E0 93, instantly gone ! After a cold start, the engine will not hesitate no matter how light the throttle pedal, even trying to induce the hesitations. For me this is solid improvement. -I have not had a chance to test extended hwy mileage but given the 17 to 21 mpg jump for mixed driving, 25-26 mpg hwy may not be too far fetched. -Car feels like it lost weight, no more sluggish sensations in suburban areas driving where I had to give minimum 1/2+ throttle to get what i want. On E10 the car is a Jekkil and Hyde, it's either lazy or angry not much in between. With E0 there is a continuum of responses, more resolution and definition not that threshold where you feel oh there it is.. the engine is much more cooperative and refined. Improved throttle response is definitively there. I can see how on a track this would be beneficial (1MOREMOD). - Quote:
01-07-2016, 07:56 PM | #22 | |
413
Rep 1,178
People like us driving a performance car should be more circumspect and consult independent studies. |
