01-04-2016, 09:43 AM | #1 | ||
1718
Rep 5,110
S55 Anti Lag vs F1 "blown diffuser" tech - Possible explanation on S55 ALS?
There has been some discussion and speculation on how the S55 Anti Lag System (ALS) operates.
I remembered that a few years back Formula 1 had a big debate on the "blown diffuser", where exhaust gases was exiting in the diffuser, thereby creating an added downforce by keeping air flow (or in this case, exhaust flow) through the diffuser. Of course this works great under throttle/acceleration, but on the overrun (engine braking) the exhaust flow disappears as the throttle valves close and no air is pumped through the engine and into the exhaust manifolds. F1 engineers at used a loophole in the regulations and programmed the fly by wire throttle valves to be kept open also on the overrun (engine braking). This means that there is still airflow through the engine and into the exhaust manifolds. Various degrees of throttle opening was used by the different manufacturers. The official line why they employed the open throttle on the overrun was to "cool the exhaust valves"... Some teams/engine manufacturers used only "cold blowing" but others used "hot blowing". The difference between them being that the cold blowing only used the open throttle to allow air to be pumped through the engine, while hot blowing also employed fuel injection on the overrun. The fuel added, combined with retarding the ignition perhaps as much as 45 degrees, ignites in the hot exhaust manifolds and creates a hot exhaust gas going to the diffuser. Hot blowing creates a gas flow on the diffuser that is more similar to the gases under acceleration (hot exhaust gases). Reading the technical manuals on the S55 I suspect that a similar strategy is used for the anti lag system. The valvetronic, or throttle valve, is kept open on the overrun (and most likely also on the upshifts on the DCT) creating a gas stream in the exhaust manifold also under engine braking. And thereby spooling the turbos/keeping the turbos spooled. Whether the S55 uses cold blowing or hot blowing I'm not sure of. But BMW has said that fuel consumption increases when ALS is activated, suggesting that some form of hot blowing is taking place. Listen to the second car in this video (Red Bull) and compare that to the "fart" created by the S55 at "off throttle" situations. Here are some different blown diffuser sounds: Here is a quite good article on the blown diffusers and how they achieved this concept: http://www.formula1-dictionary.net/o...e_overrun.html Quote:
An article more about the diffuser concepts, but with a good explanation on hot and cold blowing: http://www.formula1-dictionary.net/diffuser_blown.html Quote:
01-04-2016, 10:06 AM | #2 |
Mlightened
1852
Rep 2,242
Wow, awesome post. Thank you for taking the time. This makes you really miss the old F1 sounds, spine tingling.
Hopefully the retards don't turn this thread into a bashfest of the new F1 cars. |
01-04-2016, 10:25 AM | #3 |
Grand Duke
1540
Rep 1,114
Drives: 2023 M4CSL
18,000 rpm. Crazy.
01-04-2016, 10:47 AM | #4 | |
1718
Rep 5,110
I actually visited Cosworth in 2004, when they where developing the V8 that they raced at 20.000rpm in the 2005 season. I was in their dyno room when one of the first prototypes was running... |
01-04-2016, 09:02 PM | #6 |
38
Rep 123
great post and thanks for spending the time. Bring back the big V10's. There is not enough room on this server to handle the bashing of the new turbo 6 in F1 compared to the older NA cars.
01-04-2016, 09:48 PM | #7 |
21121
Rep 20,741
Drives: 2021 911 turbo
I would not consider 3 liters a "big" engine. But I get what you mean .
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
01-05-2016, 01:45 AM | #8 | |
1718
Rep 5,110
01-05-2016, 01:54 AM | #9 | |
1718
Rep 5,110
I guess all you need to datalog is: MAF Ign timing Fuel consumption If mass air flow is still quite high on the overrun then that means the engine is still pumping air through it and feeds the turbo. If fuel consumption is not at zero on the overrun then some fuel is also injected. Of course it's not nearly as aggressive as on the F1 engines since there isn't that constant farting sound on the overrun etc. Datalogging can be done by a simple app like DashCmd on your iPhone and by using a OBD dongle with a wifi connection to your iPhone (or via Bluetooth if you have a android phone). |
01-05-2016, 08:03 AM | #10 |
2634
Rep 2,809
Yes, I have already confirmed the S55 is using this method as a form of ALS. The remaining question is how much, if any, fuel is injected during these ALS events. I suspect, from extensive datalogging, that there is a slight amount of fuel from the injectors on the overrun delay. If there is fuel, it isn't much (I.e. The delay time is very short and not a lot of fuel is injected). I cannot datalog fuel injector pulse width to know for sure (which is all you need to datalog to know for sure, BTW). Ignition timing goes well south of "0" during these events as well. I can't tell how far below 0* the DME is pulling timing, however, as the datalogs don't log below 0*.
2016 BMW ///M4 ZCP - President / Master Calibrator | JordanTuned, LLC (www.jordan-tuned.com)
IG and Twitter: @CaryTheLabelGuy |
01-05-2016, 08:25 AM | #11 | |
1718
Rep 5,110
Have you logged MAF to see how much air, if any, that is pumped through the engine in these situations? It might not be the same method as the F1 engines used, but it would be interesting to see if the S55 keeps throttle partially open (or use valvetronic) to pump air through the engine, like the F1 engines did, and how much air is going through it if so. On my DashCmd app which, is just a handy and easy to use, not a pro datalogging tool, I get ignition timing below 0 deg. I also get fuel consumption and fuel flow, which should at least give a slight indication of fuelling. Last edited by Boss330; 01-05-2016 at 08:32 AM.. |
01-05-2016, 08:35 AM | #12 | |
2634
Rep 2,809
Yes, the throttle plate is remaining open during these ALS events, it is clear as can be in the datalogs. I cannot log MAF, unfortunately. Terry at BMS doesn't give the ability to log MAF but MAF isn't really all that relevant to the question as we already know for sure the throttle plate is remaining open. The real question is how much, if any, fuel is being injected during the ALS events. I am trying to get ahold of a factory scan tool to see what I can observe during these events to finally put this question to bed. I'd also like to see how the DME is altering cam angle as well as what Valvetronic is doing during these events as well.
IG and Twitter: @CaryTheLabelGuy Last edited by CaryTheLabelGuy; 01-05-2016 at 08:42 AM.. |
01-05-2016, 10:24 AM | #13 | ||
1718
Rep 5,110
Reason I'm asking is that on valvetronic engines it's usually intake valve lift that regulates air flow, the throttle valve is there just as a back up if valvetronic should fail. As I am sure you know, valvetronic varies intake valve lift, acting like a throttle valve. Lift can be varied from between 0,300mm at idle, and on the overrun, to full lift of 2,5-3mm (which I guess varies between engine types). And some direct fuel injected engines also run under what is called a stratified charge. Stratified charge is a condition where there is a surplus of air compared to fuel, the throttle valve is usually completely open under these conditions. In effect the engine operates like a diesel engine with excess air and open throttle. It's the amount of injected fuel that regulates the power output. As we all know, fuel and air needs to be at a stochiometric ratio to ignite, so how can a direct injection engine run with a air/fuel ratio of 20:1 and higher? This is the beauty of direct injection, when fuel is injected directly in the combustion chamber. They manage to create a pocket of air/fuel where there is a stochiometric mixture. My point is that a open throttle on a direct fuel injected engine, and especially on a valvetronic engine, doesn't necessarily mean that much... Could you possibly check if the throttle valve isn't open at all times? And even with a fully open throttle valve on the S55, it doesn't mean there is airflow through the engine. Valvetronic could be at minimum valve lift on the intake valves and thereby cutting airflow... MAF is a very important factor in my opinion to figure out to which extent the S55 uses this feature, if at all. Last edited by Boss330; 01-05-2016 at 02:35 PM.. |
02-15-2016, 08:11 PM | #14 | |||
2634
Rep 2,809
I didn't see this post until now and I never addressed it when it was posted. So here goes:
As for the S55 and N55, they run normal 14.7:1 AFRs (stochiometric). I've never once observed my S55, for instance, run leaner than 14.7 once AFR stabilized at light and medium loads as well as idle. Some DI engines do utilize stratified charge like the Mitsubishi GDI, for instance. Stratified Charge is mostly used in N/A engines, however. Quote:
02-16-2016, 12:24 AM | #15 | ||||
1718
Rep 5,110
03-11-2016, 12:03 PM | #16 |
1718
Rep 5,110
Just read an article about the facelifted Porsche 911 Turbo S.
One of the changes was to increase throttle response and is called "dynamic boost". Under dynamic boost the throttle valve stays open for up to two seconds after the driver lifts off the throttle pedal. So, Porsche now definitely use "cold blowing" as a method to decrease turbo lag/increase throttle response. |
03-11-2016, 03:24 PM | #17 | |
2634
Rep 2,809
Thanks. |
03-11-2016, 04:25 PM | #18 | ||
1718
Rep 5,110
But I found this press release from Porsche: http://press.porsche.com/news/release.php?id=963 |
03-11-2016, 04:38 PM | #19 | |
163
Rep 387
03-11-2016, 04:49 PM | #20 | ||
1718
Rep 5,110
That part wasn't mentioned in the EVO article, so I didn't pick up that piece there. |
03-11-2016, 05:19 PM | #21 |
2464
Rep 3,803
03-11-2016, 07:10 PM | #22 | |
707
Rep 886
Cool thought, but in short, the answer is no. That will not work on our cars. They are completely different executions of an antilag concept.
2015 M3 - AW 6Spd w/ CCB
MCS 2WR Dampers, Spec Twin Disk Clutch, MaxPSI CH, F80Paul Ethanol Tune, 3.5in DPs |
